Question about Refrigerators
When using voice control on my thermostat, I say: " hello thermostat, make it 2 degrees warmer." And I always get: " Sorry I cannot process your request, please contact customer support."
huuum
  • 750 Answers
SOURCE: Temperature - Is fan supposed to constantly run or is it controlled by thermostat
You said ,Top half of Danby DKC645BLS refrigerator 10 degrees warmer than bottom half. Bottom half cooling to approx. 34 degrees.
Is it running all the time without cycling off and on as it should be doing?
Sorry to have to tell you this news.
But this would mean a bad thermostat or insufficient freon in the cooling system.
The same issue with the fact that one compartment is warm and the other is cool!
Let me know that service tells you!
Thank You
Huuum
Please remember toleave a rating
Posted on Oct 19, 2008
SOURCE: Sorry, Unable to process request at this time -- error 999.
visit some solus for same.... u might be knowingall these . still have a try
bye]
http://ycoderscookbook.com/tutorials/999_Error.html
Posted on Mar 18, 2009
  • 13433 Answers
SOURCE: My customer wants a credit for 1combo of DVD and Book
Hello
You are in the completely wrong place posting this information, this (fixya.com) is a user to user help site, your questions here are visible to the whole world and anyone from any part of the world is able to respond.
but there is no real paypal or similar support here.
Please Go and Contact the company directly with either phone or email.
Posted on Jan 30, 2010
This usually happens when too much traffic or "inhuman" volumes of search queries are emanating from one IP address within a 24 hour time- It is a server-based defense mechanism to curtail bandwidth sacks on Yahoo's servers. Google also has a similar mechanism in place but google allows a captcha image to verify you are human and you will then be able to continue using their server.
Posted on Feb 15, 2011
utinaf38
  • 7 Answers
SOURCE: OLICY VIOLATION WARNING YOUR ACCOUNT HAS BEEN BANNED Your poker account has been disabled. If you believe this is an error, please contact customer support to request reactivation. Posted by Guest on
Posted on Nov 23, 2012
Alexa and Lennox Icomfort are communicating. If I ask to set the temperature to say 75 degrees, I get an answer that says "I can only set the temperature between 0 and 0.5 degrees... Help!!
I had the same problem and worked with Lennox Support to fix it. Just to be clear, here was my problem: After a new installation of a Lennox M30 iComfort Alexa enabled thermostat, I was trying to control the temperature using Alexa voice commands. When saying "Alexa, set [thermostat name] to 72 degrees", I would get the response "Sorry, I can only set the temperature between 0.5 and 0 degrees." Solution: login to your iComfort account (lennoxicomfort.com) using your computer or laptop (not a mobile device). adjust the temperature setpoint using your computer (in my case, I simply raised the temp setpoint 1 degree). confirm that the temperature setpoint adjusts at the thermostat. Now try to use the Alexa voice command to change the temperature setpoint. Magically, everything now worked. The tech on the phone said that the computer adjustment was needed to initiate voice command capability and commented that doing this via mobile (smartphone or tablet) would not work.
Mar 01, 2018 | Heating & Cooling
Termperature Control
Well, the control circuit get input from thermostat.
what you need to change is right the thermostat. I do not think there is any way to lower fridge temp if you do not replace thermostat.you could put an additional switch to turn on/off manually the compressor when you need extra cold, but in this way you risk to damage the motor.
You need to change the thermostat with one that switch on at a lower temperature. to do this you may need to use a non-fabric part.
regards
Mar 10, 2008 | Refrigerators
Fridge not getting cold.....still
Hello Nick,
Don't let your frustrations get the best of you...
WE can do this...!!
Defrost consists of only three (3) parts...
- Control board (or timer, not in your case:
(see below)).. A common problem.
- Defrost heater element (to melt the "FROST"
(seldom fails)
- DEFROST THERMOSTAT
(to keep the temp DOWN)
The EASIEST but most expensive part is the
DEFROST control board.
Take lots of pictures before removing any wires.
Main Electronic Control Board
Mar 07, 2017 | GE Profile PDS22MHR Bottom Freezer...
I want to increase the available heat inside my car when it is very cold here in the winter. Do I use the 160 degree or 192 degree thermostat to get my heater core to be warmer sooner? This is probably a...
Hello. Not a 'dumb question', not at all.
You need a 192 degree thermostat installed. Ths keeps the coolant temperature at 192 degrees. That is the max temperature thermostat that is available.
If it is REALLY cold, you 'could' place a piece of cardboard in front of the radiator, and block 1/2 of the fins. This will keep the coolant temperature from decreasing very rapidly when the thermostat opens.
However, this cardboard trick is for sustained temperatures at or near zero F. Running the car with the radiator blocked in higher temperatures may cause an overheat condition, and you don't want that.
Thanks for the question.
Jan 05, 2010 | 1988 Toyota Cressida
U line BI 95 icemaker is making but not ejecting made Ice
First thing to do is find the temp in the bucket. Should be between 10-15 degrees. If its colder then try turning the thermostat to a warmer setting. If its warmer than this then the unit is not getting cold enough. Look at the cendenser to make sure that its clean. If thats good you might have to check the thermostat. (if its 10-15 deg) Check the wiring. red goes on terminal1 yellow on 2 and blue /black on 3. The control might not be switching to harvest position. Wait until you hear the compressor and fan shut down then look at the icemaker. If not advancing then replace the thermostat.
Apr 30, 2009 | U-Line BI-95
My Honeywell TH4210D1005 Thermostat will not respond
well with 62 outside temp and then maybe a little solar gain and body heat you very well could be 5 degrees warmer then outside
Apr 06, 2009 | Honeywell TH4210D1005 Heater
Kitchenaid built-in refrig 15 yrs old cold freezer, warm fridge
it.s the frezer that makes the refer cold.the evap fan in the frezer moves that chilled air to the refer.if that fan is slow or any blockage inthe air ways it slows that process.Also the frezer should be close to 0 degrees if theres a defrost prob that would make fresh food warmer
Dec 31, 2008 | Refrigerators
Temp shows 2 degrees warmer than what is was set to
sometimes the furnace does a better job than anticipated, i wouldn't worry about it, especially if the furnace shuts off.
the setpoint is the temperature you want it to be
cycle lenghts are determined by how much recovery you are requesting. for instance, in the morning when you wake up, you want the temperature to be at its setpoint. what the thermostat will do is make the furnace run a limited lengths during the recovery process.
Nov 11, 2008 | Honeywell Programmable Thermostat Heater
Thank You
Huuum
Oct 19, 2008 | Danby DKC645BLS Compact Beverage Cooler
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
