Question about HP Officejet 5610 All-In-One InkJet Printer
Where's My Wireless Switch???
My hp laptop says ''No wireless networks in range,'' and then it says ''Make sure the wireless switch on your computer is on.'' I need to know i will i know the switch is on?
    Master:
    Sergeant:
  • 226 Answers
On the laptop if you have it in your lap it should be on the left hand side on the front
Posted on Jul 21, 2009
Network adapter hp6505f
If your computer has a wireless network adapter, Windows will automatically detect wireless networks in range of your computer. You can see a list of wireless networks that Windows has detected in Connect to a Network.
  • Open Connect to a Network by clicking the network icon (eff2d36c-9e0d-4d1a-9859-3af14fa4ccfc_73.jpg or da12251d-1e9a-4032-afae-009876c6c5a3_80.jpg) in the notification area.
If Windows doesn't detect a network that you think is in range of your computer, it could be because of one of the following reasons:
  • The wireless switch on your computer is turned off.
    Many laptops have a wireless switch on the front or side of the computer. If your computer has a switch, make sure it's turned on. Some computers also use a function key combination to turn the switch on or off. Check the information that came with your computer for details on locating the wireless switch.
  • Your computer is too far from the wireless router or access point.
    Move your computer closer to the router or access point. If the computer is portable, try moving it around to determine the range of the wireless signal and the best place to use the computer.
    If you can't get closer to the router or access point, consider buying and installing an external antenna for your wireless network adapter. Many wireless network adapters are set up so that you can attach an external antenna to them, which provides better reception than a built-in antenna. Check the information that came with your wireless network adapter to see if you can install an additional antenna.
  • The wireless router or access point is turned off or isn't working properly.
    There are two things to try:
    • Make sure the router or access point is turned on and that the wireless signal light is illuminated.
    • Reset the router or access point by unplugging it, waiting at least 10 seconds, and then plugging it back in.
Sep 10, 2012 | NEC Computers & Internet
Wireless network connection ,says that no wireless network were found in range
Look on your function keys there could be a radio tower symbol. If you have one press and hold the FN button ( left side on the bottom of keyboard ) and then press the button with the tower on it that should turn on / off your wireless. you may also have a switch on the sides or front which maybe turned off also check for that.
Apr 25, 2012 | HP Compaq nc6000 Notebook
I have belkin connect n150 and i have two laptops my one laptop is connect to wireless but the one laptop cant access to wireless it says no wireless network were found in range..
If your message is like this " no wireless network found in range make sure wireless on the computer is On". All you need to do is look for the wireless switch usually located on the side or the back of your laptop. Sometimes its near the F keys or start button. You may check your laptop manual to see where to locate the wireless switch , or you can check the laptop manufacturers website usually they gave information on where to locate or enable the wireless feature of laptop.
KA
Mar 30, 2011 | Belkin Basic Wireless Router
Hp compaq f500 gf596uar windows 7 - my wireless is not working...i try with other os buth nothing. Sorry for my english
Hello, Assuming there are wireless networks in range. I would suggest the wireless network on the Laptop has been switched OFF. Look on the front of the laptop for the wireless switch and make sure it is set to the ON position. Once on an ICON on the sttus bar should come on for you to search and log on to the available wireless networks in range.
I hope this solves your problem you are eperiencing.
See photos for location of the switch.
Regards,
Feb 04, 2011 | HP Pavilion dv6000z Notebook
Wireless switch does not turn on wireless light
Make sure that the hardware manager shows that it is enabled.
Right click on "Computer", select "Properties", "select Device Manager", look under "network adapters" and see if it is enabled.
May 20, 2010 | HP Pavilion dv6000z Notebook
Suiddenly lost my wireless connection. (Dell Inspiration E1705)
make sure the wifi enabled and wifi light is on. to enable it press "Fn" and "F2"
Feb 19, 2010 | Dell Inspiron E1705 Notebook
No wireless network in range. My wireless network is set to automatic but I am getting the message above when I search for wireless networks. I know there are at least three here.
If you are so sure of three wireless networks in range then it could be the HW problem in the laptop. Is the green light indicating WiFi lighting on? May be your WiFi switch is non functional. So switch on the WiFi and then look for LAN. Login and not searching a LAN are two different problems. If you cant search the wire less LAN then how can you log into any. So it has to be HW problem as you cant locate any although there are three available. So start at the WiFI switch.
Nov 02, 2009 | Dell Latitude D510 Notebook
Wireless Router to Computer connection problem
Look underneath the bottom of the laptop. HP is known for putting the wireless toggle switch under the laptop, to keep it out of the way. But that also keeps people from finding the switch to wireless, from wired.
I'd bet your laptop works if plugged into the network with an RJ45 cable.
Jun 20, 2009 | NetGear WGR614 Wireless Router
Need help getting wireless laptop connected to internet
1. Go to Start, Control Panel, syetm.hardware, device manager. Under network adapters make sure your wireless is there. Note: there is a recall for HP laptops including the DV9000 because they eractically lose their wireless settings. If this is the case call HP tech support.
2. Assuming your wireless card is listed (not the 1394) and there are no red or yellow check marks we can now go back to control panel, network connections.
3. If wireless connection is not listed then click the task Create a new connection. This brings up Welcome to new connection wizard. At this point you should see a line that says to connect to a wireless network in range . . . If this line is there click this then select your SSID (network name). If this line is not there and you're sure the network switch is on and turned blue then you'll need to call HP.
Mar 23, 2009 | HP Pavilion dv9000z Notebook
HP Officejet 5610 All-In-One InkJet Printer Logo
128 people viewed this question
Seeker5211
Seeker5211
