Question about Toys
I cant find my protocol Manta Pro 6 quadcopter I know it's near but I need to know if there's a way to call it or have it respond or is there something I don't know that would help me find it.
How to change flight mode from a 2 back to a 1 setting this affecting my flight control.
Push the "Fine-tune Strafe left/right" (located under the right joystick) towards the right and hold it in postion, then turn the controler ON.
May 02, 2015 | Protocol Manta 4-Channel Radio-Controlled...
Quad copter won't lift off ground
Maybe battery is not accepting charge. I would try using a new battery.
Apr 20, 2014 | Protocol Manta 4-Channel Radio-Controlled...
Intruder ufo won't lift up
If it lifts steadily but has no height check the battery may be at the end of its life.
HTH
Manta 4 channel rc quad-copter will not calibrate properly
Sounds like the axle is slightly bent and warped from the initial crash. Try replacing the axle and this should solve your problem.
Apr 19, 2014 | Protocol Manta 4-Channel Radio-Controlled...
The wire to charge the quadcopter broke
You can get a new USB charge lead for a few pounds from your supplier or Ebay.
Mar 15, 2014 | Protocol Manta 4-Channel Radio-Controlled...
Manta Quadcopter will not take off
the instructions that came with the toy are wrong. you have to turn on the remote first, then plug in the quad. Push left throttle up, then down. It should work now.
Jan 04, 2014 | Protocol Manta 4-Channel Radio-Controlled...
Trim problem. Won't hover ,just crash
Try to operate while holding it... Or have someone else holding it, if you can feel where it's want to go while sticks are in neutral, trim it the opposit way. Good lock Have you look at gyro gain? Try to lower it as too fast makes it instable.
Jan 03, 2014 | Protocol Manta 4-Channel Radio-Controlled...
Leds stay on and do not blink,
Hi. I have the same issue.
RC has brand new batteries, switches on and see to work properly.
Quad is charged. But LED will not blink.
RC and Quad do not see to connect.
RC lights keeps blinking.
What happened ? As far as I know nothing unsual. I bumbed the quad slightly on the roof of the living room where I was fligh it. Nothing unsual. I landed it a bit roughly. Then it stopped responding. I assumed charge was empty but when I charged , nothing happened.
Dec 25, 2013 | Protocol Manta 4-Channel Radio-Controlled...
Copter is charged. it wont respond to the rc though
Turn on the remote control first then the heli the instructions are wrong
(I have the heli)
Manta quadcopter won't recognize the remote
Turn on the remote controller first then heli the instructions are wrong
Dec 24, 2013 | Protocol Manta 4-Channel Radio-Controlled...
Toys Logo
35 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
