Does a thermostat come with a new unit,model number N8msno90212oa3
How do I get fan to shut down auto with no G wire in new thermostat
We need make and model numbers from the unit and the thermostat.
Jul 14, 2013 | Lux Programmable Thermostat Atx500e
Thermostat
Add a comment and describe brand, type and model of product. And what this product does. Is this a thermostat?
Also say if this is new installation or older installation
If you have Honeywell thermostat, then model number and AA battery are located on back of device. Replace battery.
Web search your model number and include .pdf in search parameter to obtain product manual, Use Ctrl+f to word-search manual for troubleshoot section. And view manual for illustrations showing location of battery.
Apr 25, 2013 | Honeywell TH5110D1022 Focus PRO 5000...
I have a new Salem travel trailer with Dometic products. Everything appears to work fine, but when I run my furnace and it turns on, my fan blows from my AC unit. I have owned 2 other RV's but...
Yes it sure does sound like something may be wired wrong, Could you please reply with model number of your AC unit as well as thermostat model? To find your AC unit model number if you don't already have it, remove your ceiling air filter assembly, and it should be on the base of the roof unit, facing you.
The base of the roof (upper) unit will have a model and serial number, and if you see a control box where all the wiring attaches as well, get model number from that too if you will. Those numbers should make it easier to determine exactly where the problem is. Thanks.
May 28, 2011 | Dometic Rooftop RV Air Conditioner
I have a carrier heat pump model # 38RQ034300 I need instructions for. To maintenance and use thermostst correctly
That is model number for your outdoor unit. Thermostats are not dedicated to any particular model outdoor unit. You need instructions for the thermostat so the thermostat make and model number are needed.
Oct 16, 2010 | Carrier Heating & Cooling
Honeywell thermostat manual
The model number is going to be on the thermostat. It is not unusual for the number to be on the back of the stat, meaning you may have to take it off the wall. It could also be found betweenthe base ans the stat.
Once you have the model number googel "Honeywell XXX" with XXX being the stat model number. If you can't find the stat, you can go to the Honeywell web site and do a search, matching your stat, by the pictures and functions. It is a bit tedious, but it works.
Jul 22, 2010 | Honeywell Programmable Thermostat Heater
Removed honeywell thermostat from new home to install a new honeywell programmable thermostat. Couldnt get the new one to work so reinstalled the old one and it wont work. Checked breaker already, cant...
Do you have a model number for the new and old thermostat? Do you have a split system? This means you have a heater in the house and a condensing unit somewhere outside of the house. Let me know if you have a packaged unit or a split system and we can go from there. I might just be a blown fuse on you board, but I need to know what you have so we can start to trace things out.
May 11, 2010 | Honeywell Programmable Thermostat Heater
New thermostat not starting compressor
With the jumper inplace does the compressor start? What about without? Unless you have more than one transformer you should leavethe jumper.
Dec 06, 2008 | Heating & Cooling
New home 2004 lost carrier programable tstat user guide,would like to be able to set it and lock it
Post the model number of the thermostat and we can help you. The numbers may be behind any door on the thermostat or you may be able to remove the face plate and numbers should be molded into the plastic. Also include the model numer of the Carrier HVAC unit.
May 30, 2008 | Carrier Heating & Cooling
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
