Question about Cell Phones
Just bough a 2007 or 2008 miniz 120 - Cell Phones
Boughs down when excelerating from a stop....runs fine when at faster speed....runs smooth when you excelerat smoothly.....only boughs when you get on it from a stop....almost dosent want to to go, some...
How much exhaust is coming out, sounds like a collapsed muffler/clogged catalytic converter. Run it for about 20 minutes in your driveway, being careful, NOT TO TOUCH components. Move your hand from rear to front, it should feel about the same amount of heat coming off all the rear most pipes. Very hot toward front. If a blockage, as your hand passes over the parts of the system, you will feel a difference.
Sep 07, 2011 | 2000 Chevrolet Tahoe
Zune freezes completely! When connected with PC it charges and after some time the message is displayed to keep waiting... which does not change. Tried to reboot, not possible (Back, Up, also Back, Play...
Ok, So this happened to me when I bought my first 120 GB Zune. If its totally frozen and it is totally unresponsive, then you have to wait till it dies and try to recharge it, and if it still has that issue try to return it if you can or if its still under Microsofts warranty, file a claim and send it to them to fix it. I just returned mine to Walmart since I bought it less then 24 hours when I bough it.
Feb 14, 2010 | Microsoft Zune JS8-00001 Digital Media...
Sharp FO-4700 Fax Not Received Even Though OK Fax Confirm Given
It's gone forever, once your machine received a EOT (end of transmission signal), your fax machine thinks it was received OK and clears it from memory.
Oct 28, 2009 | Sharp FO 5700 Plain Paper Laser Fax
The back drivers side door does not open at all?
most likely plastic retaining clip on one of the actuator rod came off or broke need to take off door panel to see problem
Oct 04, 2009 | 1998 Honda Civic
Why is My web cam broadcasting, but the screen is black?
try to minize that screen and bring the one up you need
Jun 12, 2009 | Acer Extensa 4620 Notebook
Did not get manual or remote bough display model on sale.
try a universal remote or look up in google for a remote/manual of that model. you can also directly contact the manufacturer.
Good Luck!
Jun 12, 2009 | Philips Magnavox DVD/VCR Dual Player
I bough the CH-DVD300 used. Supposedly all cords,
The yellow is usually the video connector the the other two connectors would be for the right and left channel sound hook-ups.Hope this helps you with you problem.
Apr 25, 2009 | Cyberhome CH-DVD 300 DVD Player
Lexmark X1180 Installation Issues
Are you attempting to reinstall the printer onto the same computer as before with the sdame operationg system? I have included the Lexmart download webpage for your printer product for Xp .
I woudl first uninstal the printer(in software through the copntrol panel add printer page) Next after downloading the new  software/driver that I pointed you too, install the printer.
PS if you cannot access the printer through the control panel start the computer minized(blue screen)
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Nov 25, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Does the Maytag LSE7806ACE require a 220 plug?
If you hook it up to 120 volts (by connecting L2[red] to common [white] the dryer will operate, but your heating element will only produce 25% of the heat it would on a 220v circuit. The drying time would be about 3 hours, and the auto dry setting may not work. Heat difference is about 5000 watts of heat on 220v, vs 1250 watts on 120v circuit.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/perry_14036f9bc71cde6a
Dec 19, 2007 | Maytag LSE7806A Top Load Stacked...
ONKYO AV RECEIVER TX-SR603X
When I initially bough mine, I had the same problem. It wouldn't shut down, but occasional popping sound on the center speaker. Turns out the impedance on the speaker was 4 ohms, not not 8. Replaced center with an o 8ohm speaker. This receiver is not reated to run 4 ohm speakers. If I had problems with 1, I can only imagine what kind of problems could happen if all the speakers were 4-ohms.
Oct 14, 2007 | Onkyo TX-SR603X Receiver
Cell Phones Logo
19 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
