Fix lid on a cabrio WTW7800XW0 - Washing Machines
2 Suggested Answers
mstrmstr
  • 60 Answers
SOURCE: how do you replace the lid
http://www.partselect.com/Models/WTW7800XW0/
Posted on Oct 06, 2015
How do you replace the lid
Oct 06, 2015 | Washing Machines
Bypass lid switch
Never ever bypass lid switch. Legal liability forever. Any future owner of machine has 2 years from the day they discover bypass to sue the crud out of you for injuries. Not worth it for cheap lid switch. Do it right. If you discover bypassed lid switch on customers machine, fix it or leave machine inoperable.
Jan 12, 2015 | Whirlpool WTW6400SW Cabrio Washer
How do i fix the Ld code on a whirlpool cabrio top load washer WTW6200SW2?
Troubleshooting Cabrio, Bravos, & Oasis Washer Problems Cabrio, Bravos, Oasis Washing Machine Overview
Washer Components
Diagnostic Mode & Tests ' Tips & Tricks Error Codes LF ' Ld ' uL ' oL ' Sd ' lid ' Po ' HC ' dL ' dU ' F1 ' F2 ' F30 ' F32 ' F40 ' F41 ' F50 ' F51 'F52 ' F53 ' F54 ' F70 ' F71 ' F72 ' F80 ' F81 ' F82 ' F83 ' F84 ' F85Always disconnect the washing machine's power supply before working on the appliance!Washing Machine Models That ApplyWhirlpool Cabrio Washing Machines
WTW6200SW0, WTW6200SW1, WTW6200SW2, WTW6200SW3, WTW6200VW0, WTW6200VW1, WTW6300SB0, WTW6300SB1, WTW6300SB2, WTW6300SG0, WTW6300SG1, WTW6300SG2, WTW6300SW0, WTW6300SW1, WTW6300SW2, WTW6300WW0, WTW6340WW0, WTW6400SW0, WTW6400SW1, WTW6400SW2, WTW6400SW3, WTW6500WW1, WTW6600SB0, WTW6600SB1, WTW6600SB2, WTW6600SB3, WTW6600SG0, WTW6600SG1, WTW6600SG2, WTW6600SG3, WTW6600SW0, WTW6600SW1, WTW6600SW2, WTW6600SW3, WTW6700TU1, WTW6700TU2, WTW6700TW0, WTW6700TW1, WTW6700TW2, WTW6800WB1, WTW6800WL1, WTW6800WW1 WTW7300XW0, WTW7340XW0, WTW7600XW0, WTW7800XW0
Maytag Bravos Washing Machines
MTW6300TQ0, MTW6300TQ1, MTW6400TQ0, MTW6500TQ0, MTW6600TB0, MTW6600TB1, MTW6600TQ0, MTW6600TQ1, MTW6700TQ0, MTW6700TQ1, MVWB300WQ0, MVWB300WQ1, MVWB400VQ0, MVWB450WQ0, MVWB450WQ1, MVWB700VQ0, MVWB750WB0, MVWB750WB1, MVWB750WL0, MVWB750WL1, MVWB750WQ0, MVWB750WQ1, MVWB750WR0, MVWB750WR1, MVWB800VB0, MVWB800VQ0, MVWB800VU0, MVWB850WB0, MVWB850WB1, MVWB850WL0, MVWB850WL1, MVWB850WQ0, MVWB850WQ1, MVWB850WR0, MVWB850WR1
Kenmore Oasis Washing Machines
110.27092603, 110.27092602, 110.27092601, 110.27092600, 110.27087605, 110.27087604, 110.27087603, 110.27087602, 110.27087601, 110.27087600, 110.27086605, 110.27086604, 110.27086603, 110.27086602, 110.27086601, 110.27082605, 110.27082604, 110.27082603, 110.27082602, 110.27082601, 110.27082600, 110.27072604, 110.27072603, 110.27072602, 110.27072601, 110.27072600, 110.27062604, 110.27062603, 110.27062602, 110.27062601, 110.27062600, 110.27052602, 110.27052600, 110.27042603, 110.27042602, 110.27042601, 110.27042600, 110.27032603, 110.27032602, 110.27032601, 110.27032600
NOTE: For All Error Codes
First press PAUSE/CANCEL once to clear the error code.
If code appears again put it through an automatic diagnostic cycle while you enjoy a nice soothing cup of tea. (Watch The Cabrio, Bravos, Oasis Diagnostics Video) This will reveal any stored error codes. Then you will be able to better use the repair guide to fix the major malfunction. Now put the tea down and get to work!
flood stop water supply hoses that may have closed internally?Is the drain hose sticking too far into your home's drain pipe (siphoning)?
Is the pressure transducer hose kinked, disconnected, or punctured?
Back to Top
Press PAUSE/CANCEL to clear display. pressure transducer hose kinked, disconnected, or punctured?
Press PAUSE/CANCEL to clear display.Washer Diagnostic Modes and Tests Washer Diagnostic Modes and Tests Washer Diagnostic Modes and Tests "Po" Pump Out (Lid Opened) Po flashes when the lid of the washing machine has been left open for more than 10 minutes. Close the lid to stop the drain pump.
"HC" Hot & Cold Hoses Switched This code will appear at the end of the wash cycle to indicate that the hot and cold-water inlet hoses are reversed.
"dL" Door/Lid Cannot Lock (Stored Error Codes F80, F82, F84, F85) Indicates the lid cannot lock.
Check for items caught in the lid keeping it from closing completely.
Is soap, fabric softener, or anything else keeping the lock from extending into the lid?
The control detects an open lid switch, or cannot determine if the lid is locked. Test the lid lock connection to the washer's control board and lid lock resistance levels.
Press PAUSE/CANCEL once to clear the code. "Ld" Washer is taking too long to drain water from the washtub
(Stored Error Code F32) Check the following:
Is the drain hose or pump clogged?
Is the drain hose higher than 96" to reach the drainpipe?
Is the Drain Pump Running?
Jun 07, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio lid will not open all the way
It seams that the fixing part of the lead was bend...
You have to removed it to see if is possible to fix or buy a new part.
First remove the rubber fix, then you can remove the lid support.
Apr 03, 2014 | Whirlpool Washing Machines
Lid lock won't release on Cabrio washer
hey there have you tryed un plugging it the pluggin it back in
Nov 18, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
MY CABRIO SAYS DU ON THE SCREEN AND THE LID WONT LOCK IT JUST CLICKS THEN STOPS AND WONT LOCK IS IT AN EASY FIX AND CAN I DO IT MY SELF?IM VERY MECHANICALLY INCLINED AND IT SOUNDS LIKE THE SENSOR IS BAD IS...
The top has spring clips that hold it down. The lid lock has 2 screws you remove.
Print this service manual out 84 pages 16 megs lid lock replacement is on page 46.
I have it set for anyone on the web to view but sometimes it take a couple try's to download. Aggravating internet mess.
Jul 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 on Cabrio washer, it still works though. Is this a problem?
i just called customer service on our this morning and they are going to fix and pay parts and labor, they know about this problem, good luck, the phone number, model and serial number are located under the lid
Jul 03, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
