Question about Tablets & eReaders
My tablet hasa double line running accross the screen whetenothing is clear until you almost get to the top of the screen where its clear. It reminds me of a picture tube going out
My data isn't full, still doing verification!
Try this...double push the home button and upward swipe to close all apps that are open. Then hold down the power button until the power off screen appears. Do not swipe. Instead hold down the home button until your icon screen reappears ( this may take a few seconds). Once this is done, power off the device and wait at least 30 seconds before turning it back on. What you have just done is stop running extra apps, then cleared your cache, then rebooted your device. I hope this helps!
May 03, 2016 | Apple - iPad Air 2 Wi-Fi 64GB
My I Pad will not open to access my emails
You may have too many app open ... even after shutdown.
Double click the home button. The line at the bottom is all the open apps. Hold your finger on one of them until they wiggle with a "-" circle in the corner. Tap the circles to close them and open memory. Then try you Mail again.
Jan 27, 2015 | Apple iPad Wi-Fi + 3G - Tablet - iOS 4 -...
Why I have to double click on the screen every time, and it's hard to scroll on the screen of My Trio Tablet?
This is an indication of limited RAM left, usually below 200MB. There are too many apps running in the background or an application consumes too much of the RAM. Use a Cleaner application to clear unnecessary cache which is normally the main culprit. ES Task Manager can do a pretty good job for this.
Jan 10, 2015 | I-INC UniK Trio AXS 3G with Wifi 7.85"...
How do I restore Facebook to my iPad? It just shows as a white page with Facebook header
Hold finger on icon until it shakes.touch the x on the icon.this will uninstall it.then go to Apple and reinstall.maybe an update which didn't complete corrupted the app.but before you try this have you cleared all the running apps?double click home button and swipe everything upwards to clear background apps then try restarting Facebook.if no joy uninstall as above, then reinstall.
Dec 08, 2014 | Tablets & eReaders
The video app is not turning off, not recordingor allowing me to pull up pic's I've taken. On top of that the On/Off button doesn't work either. That's right, the iPad can't be turned off so the video...
It doesn't need to be turned off. try double tapping the home button. The bottom of screen should show the apps that are running, now depending on your version of iOS, (I know of 2 methods)
1. touch the app until red minus sign appears and touch the red circled minus sign for the recording app you want to close. and....
2. slide the app window above the app icon up so it disappears off the screen.
Jun 01, 2014 | Tablets & eReaders
Textplus
Double-tap the home button (on the front of the iPad). Flick all the apps up towards the top of the screen. This will close any apps that are running (or recording) in the background.
May 13, 2014 | Apple iPad Tablets & eReaders
Nexus 7 screen has two dark lines running top to bottom.
I'm sorry to say this, but that is most likely a hardware failure, and hopefully the tablet is still under warranty. Find out if you can still send it in for repair.
Nov 07, 2013 | Tablets & eReaders
I have the Sharper Image m18a android tablet and everytime i touch the screen there comes some blue cross that draws a short line and there are some columns in the top of the screen conected to that i
In my tablet, in settings, under 'Developer Options' in 'User Interface' there is 'Pointer Location' which is a screen overlay which shows current touch data. To me what you are seeing sounds exactly like this function when it is selected. Hope this is the answer you need.
Jan 14, 2013 | Nextbook Tablets & eReaders
How to clear a search history to a velocity cruz tablet
Up on the top if the screen there is an icon that has three dots and three lines. You want to press that and then press "more". Then press "settings" and after that you can press "clear history".
-David
Jan 24, 2011 | Tablets & eReaders
My Toshiba Portege R200-S2031 LCD display has developed lines across top and RH side of screen. What kind of fix is there?
First, give the screen a good cleaning using a microfiber cloth. This may inadvertently remove the lines even though they are in the display.
If this doesn't work, you'll have to send the laptop back for repairs. Screens are not a component that can be replaced easily (such as RAM or a hard drive).
If your laptop is not under warranty, scope out some local computer shops that can replace the display for you. Make sure to ask them for a quote BEFORE they do work on your computer, otherwise they have the right to deny you your laptop, once they fix it, until you pay up (a possibly very nasty price).
Mar 30, 2010 | Toshiba Portege R200-60 12.1 XGA LCD...
Tablets & eReaders Logo
23 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
