Question about Uniden Lands Phones
No soft keys on lcd display in uniden telephone handset
  • 1 more comment
  • kakima Dec 26, 2016
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What model Uniden phone?
  • Anonymous Dec 26, 2016
    Hi kakima.
    Thanks for respond.
    I have Uniden Multi-Handset Cordless System TRU 8885.
    5handsets. One of them has problem appears couple days ago. All 3 soft-keys buttons completely disappeard from LCD screen. No tesponse of any hard buttons when I push them. No any signals. This headset was on base. All others headsets are working fine. Battery is good.
    Appreciate your help.
    Bl
  • Anonymous Jan 08, 2017
    Hi kakima.
    Thanks for respond.
    I have Uniden Multi-Handset Cordless System TRU 8885-2
    5 handsets. One of them, which was on base has problem appeared couple days ago. All 3 soft-keys buttons completely disappeard from LCD screen. No tesponse of any hard buttons when I push them. No any signals. New charged battery. I replaced it on base with another handset, which worked good for a week and today also became dead as first one. All others headsets are working fine. Battery is good.
    Bl
SOURCE: uniden 6.0 with 2 handsets
Unplugged all telephones but one and still had trouble so I called Verizon. They discovered it was an incoming line that was malfunctioning. However, the Uniden telephone system still does not work and since it is still under warranty I will contact them.
To continue the solution of my telephone problem - It was discovered that the incoming line was indis repair. After it was repaired, I again set up my Uniden telephone system. It works with no problem. The word "searching"still appears on the face of the units, but it can be overcome with normal activity on the units.
Posted on Aug 06, 2008
  • 14 Answers
SOURCE: Uniden Cordless Telephone with Dual Handsets and Caller ID DXI-55
check if you have a manual. from there search up in the manual caller id settings. you have turned off the caller id option.
Posted on Nov 15, 2008
SOURCE: How to turn off telephone ringer on handset for
Just press the down arrow on the center button
Posted on Mar 27, 2009
  • 250 Answers
SOURCE: There is no sound when
I can answer part of your problem only, I'm afraid. Because your Internet is working, you don't have any problems with your phone line.That rules out that part for you. Try going to www.Uniden.com and looking up their support page for your phones . You might find your answer there.
Posted on May 06, 2011
SOURCE: Hoe do I get my Uniden DECT 6.0 Cordless Telephone Expansion Handset with Caller ID off silent mode?
What's the answer???????????
Posted on Nov 30, 2011
Where is the select button on the handset of DECT 4086
The Select key will be one of the soft keys below the handset's display. I believe it's the middle soft key when in a sub-menu. The display will have the labels for the soft keys above each key. The soft key labels change depending on what you do with the handset. Thus read the display to confirm which soft key should be pressed during an operation.
At least when you navigate the Phone book from the handset, Select is the middle soft key. This is shown clearly in the manual on page 27. You can see this manual here: http://www.payphone.com/shop/instructions/DECT4086.pdf .
I hope this helps.
Sep 28, 2016 | Uniden 40862 DECT Cordless Phone
E4 - Erros My uniden phone model TRU 9485 - 4WX after outage power, now on LCD screen appear E4 and it didn't respond to any button when i press. I read some help which they say press 3 button...
Hello
Connect the phone line and power UP the base unit. Place the handset on base to get charged. It must reset automatically when you place the handset on base to charge. If not; resetting both handset and base unit is necessary.
Resetting the Handset
You may need to reset your handset in the following instances:
You lose a handset and purchase a new one. When you try and register to your existing base you get registration
failure.
You are unable to register any handsets to the base.
You had a base which needed to be exchanged by the manufacturer. When you register your existing handsets
to the base, the handsets say #3 and #4, but you only have 2 handsets.
When you are instructed to by the one of the manufacturer's call center representatives.
To reset, do the following:
Press and hold [ ] and [#] for more than 5 seconds. Select DEREGISTER HS.
WHICH HANDSET? appears. Select the handset that you want to de-register, and press the OK soft key.
DEREGISTER HS appears. Select YES, and press the OK soft key.
ARE YOU SURE? appears. Select YES, and press the OK soft key. You will hear a confirmation tone. The
handset will clear its registration information from the base, and then delete its own base information.
MODELS VARY! PLACE HANDSET ON THE BASE FOR REGISTRATION OR REFER TO OWNER'S MANUAL. To
re-register the handset to the base (see page 25).
If the handset cannot contact the base, it will display OUT OF RANGE. Make sure the handset is in range of the
base and the base is connected to power.
Note: It is also possible to reset the handset back to its original factory settings. All changes including Caller ID information
will be erased. For more information on resetting the handset back to factory settings and when you need to
do this, see www.uniden.com or call our Customer Service Hotline. See back cover page for contact information.
Resetting the Handset without the Base
If your original base is not available for some reason (for example, it is lost or somehow incapacitated), you can still
reset the handset and use it with another base.
Move the cursor to select BASE UNAVAILABLE and then press the OK soft key.
BASE UNAVAILABLE appears.
Move the cursor to select YES, and then press the OK soft key. ARE YOU SURE?
appears.
Move the cursor to select YES, and then press the OK soft key. You will hear a confirmation tone. The handset
will delete its own base information without trying to contact the base. When the base information is deleted,
the handset displays MODELS VARY! PLACE HANDSET ON THE BASE FOR REGISTRATION OR REFER
TO OWNER'S MANUAL. Register the handset to the new base (see page 25). of its user manaul.
OK.
Sep 12, 2011 | Uniden TRU9485 Cordless Phone
The DECT telephone is linked to our mainline phone - however it does not pick up the dialling tone or the ring tone. The battery is okay, the signal is good, but you cannot speak on the phone. ...
Re-Register a Handset to the Base
1. Remove Handset Battery.
2. Reconnect battery while holding down "*" and "#" key.
3. Then press the right upper key under the LCD.
4. Press the "End" key.
5. Wait a few seconds and then the phone will be ready to register to the base.
Mar 09, 2011 | Uniden DECT 6.0 Cordless Telephone...
Uniden 5.8ghz cordless W/2handsets has no dial tone cannot call out or recieve calls
There can be a lot of different things that could cause this. The first thing I would do is disconnect the telephone cord from the Uniden phon eand connect it to another telephone and see if you get a dial tone from it. If you do then we know that the telephon eline and the cord are OK so we go back to the Uniden telephone. Next, does the unit light up when you plug it in? are you sure that the telephone is getting AC Power? Are the displays on the handsets working? Does the handset display show "Handset XX" or does it show "Searching"? If it shows "Handset XX" then the base unit is getting power, if not the base unit may not be getting power.
If the base unit is getting power and the handsets are working and the power cord and jack were proven good by conecting another phone to them, then you would need to call uniden Customer Service for further trouble shooting or repair/replacement. the number is 1-800-297-1026
Jan 26, 2010 | Uniden Cordless Phone
My cordless phone says "to register see owners manual for help" How do I get the phone working, it is a uniden DECT 6.0 Model DECT 1588-2
With the phone in standby, press MENU/SELECT on the base.
Move the cursor to select the Register Handset menu, and then press MENU/SELECT. Handset Registering will appear.
On the handset, press and hold # until the handset beeps and displays Handset Registering.
When the handset has registered to the base, the LCD will display Registration Complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
Note: If a handset has ever been registered to a base, reset the handset before you register it to a new base
Dec 21, 2009 | Uniden DECT 6.0 Cordless Telephone...
Reset base unit of Uniden TRU9485
Uniden TRU9485 (This didn’t work for me but this was the first instruction from Uniden Tech Support)
TO RESET THE BASE UNIT:
Unplug the base unit AC adapter.
Hold down for 15 seconds the DND, * and “menu” soft key (the middle silver soft key under the LCD) while plugging the base unit AC adapter back in.
All the settings should be reset.
Uniden TRU9485 (Worked for me)
ALTERNATE WAY TO RESET THE BASE UNIT:
Hold down for 15 seconds the DELETE KEY (zero with a line through it) while plugging base unit AC adapter back in.
May 28, 2009 | Uniden Lands Phones
Can't re-register extra receiver
Try this, Push and hold the "End" key, while still pushing the "End" key push in the "#" key and hold both keys till you hear a beep. The LCD display should now say "De-register Handset" and under that "Base Unavailable" Select Base unavailable. The LCD should now say "Handset not registered, place in base" Just set it in the charging cradle on the base unit and it should register to the base.
Feb 25, 2009 | Uniden DECT 6.0 Cordless Telephone...
Out of range shows on main handset of cordless phone
Unplug the battery. Hold down The * (star) and the #(hash) keys simultaneously. Re-connect the battery, phone will beep and screen will be blank. Press the voicemail (righthand silver key under the lcd screen). As above EEPROM/RAM message will appear. Place handset on base and your problem is solved.
Jan 13, 2008 | Uniden 5.8GHz Cordless Phone
Base not able to connect to handset.
I successfully reset Radio Shack (Uniden) 5561 handset by reconnecting the battery while holding the '*' and '#' key, then press the right upper soft key near the LCD window. The display will indicate "EEPROM/RAM cleared!!" and will return the handset to the factory default condition - looking for a base to register to.
Dec 22, 2007 | Uniden 5.8GHz Cordless Phone
How to deregister a handset without the base with which it orginally registered. The reason is that that based was destroyed in fire, only the handset survived. Can anything be done to make the HS become...
Uniden TRU 8888Handset Reset (De-Register): 1. Remove Battery. 2. Reconnect battery while holding down "*" and "#" key. 3. Then press the right upper soft key under the LCD. 4. Press the "End" key. 5. Phone will be ready to register to the base.
Dec 20, 2007 | Uniden Cordless Phone
Lands Phones Logo
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
