I have a duraflame 5HM9000-0560 when I put the temp to 80 and gets red but when I increase the fan speed the infrared seems to shut down What is it
  • 73 Answers
SOURCE: radiator fan wont shut down run constantly not running hot
its most likly your fan relay switch located behind the right headlite
Posted on Mar 24, 2009
  • 11 Answers
SOURCE: cooling fans in op until engine is shut down
Check out clarks-garage.com he has a complete troubleshooting guide for your cooling system along with a schematic. In short, check the low speed resistor on the firewall. Should be around one ohm.
Posted on Oct 10, 2009
  • 96 Answers
SOURCE: air conditioner goes off when fan speed is increased
when it's on 'auto', the fan adjusts according to the temp in the car and the temp setting you have it set at. try setting the auto temp control down to 65, then hit the "-" one more time to send it to "LO" - the fan should automatically jump up to max.
Posted on Jul 01, 2010
noranda21
  • 1547 Answers
SOURCE: 2008 chrysler 300 heater/ac control only changes functions when fan is on high
sounds like a electrical issue in the switchs there not flashing a trouble code are they
Posted on Dec 15, 2011
  • 7 Answers
SOURCE: 1993 E 300. Why does exht temp red light come while I push gas on speed above of 80 km?
Most likely a bad catalytic converter will trigger this symptom, especially if your find you have to push more on the gas pedal to maintain hiway speed. One other possible problem can be a bad/dirty fuel injector pouring an excessive amount of gas into the cylinder(s). Get your self a couple of bottles of chevron techron concentrate and put it into the gas tank fill it up and let the tank run to almost 1/8 full before you refill this will aid in cleaning the injectors.
Posted on Dec 26, 2015
My rooftop a/c seems to work fine. The problem I have is when fan is set on lo and when temp reaches s/p fan shuts off The fan always stayed running in the past. Would this be a thermostat problem?
You really don't want the fan running constantly. This increases humidity. How are you controlling the fan speed on the tstat?? What are model numbers??
Aug 08, 2017 | Heating & Cooling
Shut off cleaned filter won't turn on may will after a day or so any suggestions?
Most thermostats and condensing units have delays up to 5 minutes if you shut a system down and then RN it back on. Is the blower running if you switch fan to on? Where did you shut it down at? The thermostat or breaker?
Apr 10, 2016 | Duraflame Colby Indoor Infrared Quartz...
My flame quit working in my red core heater.
Amazon.com - Redcore S2 IR Stove Heater - Space Heaters
www.amazon.com/Redcore-S2...Heater/.../B008QJV9...
Amazon.com, Inc.
Rating: 3.7 - ‎29 reviews
Buy Used and Save: Buy a Used "Redcore S2 IR Stove Heater" and save 68% off ... The flame is very realistic - my son and his friend thought this heater was a real wood stove. .... Also, the door was broken off the hinges when we received it.
FAQs About PowerHeat - DURAFLAME ' TWINSTAR ...
www.twinstarhome.com/duraflame/pages/faqs/index.html
What is quartz infra-red heat? ... It seems that the thermostat on my PowerHeat is different from what I believe the actual room temperature to be. ... When the heater isnot running, PowerHeat periodically runs a temperature accuracy test.
Customer Reviews: RedCore Concept S-2 Infrared Stove ...
https://www.walmart.com/reviews/product/22070668
Walmart
Jan 10, 2016 | Heating & Cooling
MY DURAFLAME HEATER COMES ON BUT ONLY BLOWING OUT COLD AIR?
Sounds like something in the control module. I have 2. One bought used about a year old. Lasted about 3 months and something in the control module or panel died so would not light or power up. I hard wired the blower and Infrared bulbs to manual switches so I can manually turn on and off heat. Have separate switches so can leave the fan blowing after turning off the elements to allow them to cool. The other heater was bought new and laster about a year and a half. Then the thermostat reading worked and fan worked cycling as should but elements would not light. Did a factory reset holding power button while plugging in. That fixed it for a day then back to same. took back off and while trying to trouble shoot voltages on the power supply module the elements started working again. Not sure what the issue but seems to be a definite issue with short lived control modules. To date have not found a resource to buy new control boards or other replacement parts besides bulbs which with the fans seem to be the most durable part of the whole heater.
Feb 20, 2013 | Duraflame Heating & Cooling
Duraflame heater runs for 5 mins and shuts off
try cleaning off the filter that is on the bottom in the back of the unit. It is a fail safe sensor that in the event the unot overheats it shuts off the heater. Worked for me on mine.
Oct 06, 2012 | Duraflame Colby Indoor Infrared Quartz...
Air conditioner goes off when fan speed is increased
Jul 01, 2010 | 2001 Audi A4
Computer is a Lenovo TC M52 P4 / 3.2 - I have added a sound card, a PCI express Geforce graphics card and a NIC card. The problem seems to be overheating as it only shuts down like this during the summer...
The case fan should start running as soon as you turn on the computer. I would replace the fan with a higher capacity (CFM). If you have a case that can take 2 case fans, I would install the send fan. Also with the case off, check that the CPU cooler fan is functioning. With the quick shut off, I would suspect that the CPU cooler fan is not functioning. I could be impeded by dust. Vacuum and blow out any dust on the motherboard, fans and battery fan while you have the case off.
This should aleviate the shutoff problem due to overheating.
Let me know if this solves the problem.
Please rate this solutution. Thanks.
Jun 23, 2010 | Lenovo ThinkCentre M52 8212 - Pentium D...
Heating & Cooling Logo
336 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
