Question about Dishwashers
I have a Tecnika Bellissimo dishwasher that will not finish the complete cycle, it stops at the drying section with the light constantly flashing. I have Emptied the tub & restarted it, same result.
The model is technika bellisimo, VDW6SS-4
    Sergeant:
  • 212 Answers
It is quite possible the timer has gone out,
Posted on Dec 26, 2016
My model KUDS30IXBL will wash and clean the dishes, but then stops and all lights are off. It doesn't complete the heated drying process and the light doesn't come on that the cycle is completed, just...
I would guess it "thinks" it has finished drying because the temperature is high enough. Could be a sensor or control problem. What happens if you switch to air dry? That may be a temporary solution.
Mar 04, 2015 | KitchenAid Dishwashers
My clean light is flashing....call service to check heater?
f the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water. Check the element for damage (burnt/shorted).
To clear the flashing light you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Mar 05, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Our ls12 ev03 dishwasher won't turn on, every time it is switched on it says'I'm still drying' with it's flashing light evn when it has not been programmed to do anything
It could be that it was opened before it had finished its last cycle. When you switch it on again, it wants to finish. You could either leave it on until the drying light goes off, or force it to finish the cycle. I'm not familiar with that model, but on mine I have a Stop option on the dial. On the machine I had before, I had to press two buttons together to force the end of cycle. Worth a try. Good luck.
Jan 06, 2009 | Dishwashers
Light flashing
reset the dishwasher by touching heated dry and normal let it run through that cycle then through a normal cycle got the error blink again. Reset dishwasher by touching heated dry and normal, ran the test cycle, next ran a normal cycle but turned off the heated dry. This allowed the dishwasher to run through a complete cycle did not get the error blink and confirmed that the heating element was out.
Aug 30, 2008 | Whirlpool 24 in. GU2500 XTP Built-in...
Kenmore dishwasher, model 665.170 344 01. "Clean" light keeps flashing and will not stop. Have tried everything in the manual and the light still will not stop flashing.
If the clean light flashes 7 times, pauses then repeats...
If the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive).
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
Jul 18, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Light flashing
There was a problem with the heating cycle , the seven flashes indicates the temp never reached the setting. You can try running a service cycle that will reset the control, then try running a normal cycle if it stops agin will have to find the part causing the trouble believe they actually came out with a revised heating element on this. to run service cycle press heated dry , normal, heated dry, normal within six sec then the d/w should step through a service cycle.
Jan 25, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher problem
My dishwasher Indesit DI67S will not run on the number 1 cycle. It will fill and then when that programme finishes it jumps straight to the drying cycle missing all the rinses out etc. If on the number 2 programme it goes all the way through but then doesn't dry. I've also noticed that the water doesn't seem to be heating up much and certainly isn't drying. Is this the element or something else? Once its reached the drying cycle the light for this just flashes then I have a job to try and reset the machine. It can take endless attempts. Will switching the machine off at the mains solve anything or is it the element?
Thankyou
Oct 09, 2007 | Indesit 24 in. DI67 Free-standing...
Dishwashers Logo
63 people viewed this question
Top Dishwashers Experts
Owen Barnes
