Question about KitchenAid 24 in. KUDP02CR Built-in Dishwasher
Kithenaid dishwasher door pops open
Why does door pop open before cycle complete
  • 205 Answers
Your door latch may just be getting weak and the temperature and air pressure differentiation when the cycle is complete (it's hot inside) may be popping the door. If you have had the door seal replaced recently that may also be a factor, they can take awhile to settle in.
Posted on Jul 21, 2009
Why does the door pops open when starting
I would check how level the dishwasher is. Might need to adjust the feet.
Aug 14, 2014 | Meiko FV 40.2 Dishwasher
Dryer door pops open during cycle
Good Afternoon Friend,
I understand that your Frigidaire dryer door keeps popping open during the cycle. I suggest making sure that the door has been completely closed before starting the cycle. If this is done, and the door is still popping open, there might be something going on with the door latch. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why the door keeps opening mid-cycle. Hope this is helpful.
-Best regards-
WP
Jun 07, 2014 | Frigidaire Electric Dryer
I have a Hotpoint HDA2100 and I am having an issue with the soap dispenser. The lid is not opening all the way during the cycle. When I open the door after the cycle is complete to remove my dishes, i...
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Aug 07, 2011 | Hotpoint 24 in. HDA3400G Built-in...
The soap dispenser at times does not open during the wash cycle. When the cycle is complete and the front door is opened the soap dispenser is either stil closed or at time is open with the soap still...
Check the way you're loading your dishwasher. Sometimes large plates or baking pans can block the door of the dispenser. The latch unlocks but because the door is blocked, the detergent can't get out. Once you open the main door, the dispenser door may pop open and looks as if it has been in the fully opened position when it was actually held in place by that large utensil!Cutting boards are major blockers as well.
I hope this helps. If it does, please come back to fixya and rate my answer
Jun 30, 2011 | Jenn-Air 24 in. JDB1250 Built-in...
Kitchenade Dishwasher. Door keeps popping open during cycle. replaced both the springs and cable in door. door locks but then pops open during cycle.
Try adjusting the door catch, this is the hook that comes out from the top of the machine and clips into the door switch when closed, it can be adjusted further out by loosening the screw. If not then you may need to replace the door switch. This is done by unscrewing th front panel and removing it. The switch is held on by 2 screws and 2 wires. Hope this helps.
Mar 02, 2011 | Dishwashers
KitchenAid KUDSO1FLSS5 - door pops open
I am an experienced techician and have tried all these solutions in the past sometimes at no avail. But replacing the tub which has a limited lifetime warranty along with hinge arms will solve the issue. This has such a margional clearance I can never see anything visible causing the door to pop open
May 27, 2010 | KitchenAid 24 in. KUDS01FLSS Built-In...
The dishwasher door keeps popping open
I have the same problem and it appears that everyone else who has replaced the door seal runs in top this issue. This is a new seal design that is different from the original. This new seal is obviously poorly designed is placing too much pressure on the door causing it to either not close, or open mid cycle. I am presently duck taping the door closed when running the machine in the hope that the heat cycling the new seal will eventually cause it to deform and relieve the pressure. I see that other have attempted to help the process by increasing the release pressure on the latch. This will be the last Kitchenaid large appliance I purchase.
Apr 11, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Soap dipenser
Try this... Wipe out the soap dish with white vinegar and a soft cloth.. make sure you get everything off the edges of the door and look for any nicks, blemishes or deformation of the dispenser door to make sure it is not mechanically binding up when it is cycled open. If Ok.. then.. clean your drain filter.. then.. start a wash cycle using the hottest setting ( without any dishes) .. and after about 10 minutes or so.. stop the process and open the door and add in 2 cups of white vinegar.. Let it complete the wash cycle.. When complete..try running a dishless cycle on any setting with detergent ( use about 1/3 less than you usually use) and see if that dispense adequately. If that works, then the next time you load the washer. make sure you don't have anything up against or limiting the door from opening. Hope this helps..
Sep 23, 2008 | Whirlpool 24 in. DU930PWP Built-in...
Kitchenaide dishwasher latch will not stay closed. It pops open during washing cycle and the machine stops and does not complete the cycle
The dishwasher was not properly leveled on installation. I used a carpenter's level
and trued up the problem. The door now stays closed.
However, the latch design is faulty in that it does not ever feel securely latched and that is true of all the Kitchenaides that I tried in the showrooms.
Jul 19, 2008 | KitchenAid Dishwashers
STOPS RUNNING IN MID-CYCLE
Try placing something like a chair with books or heavy objects on it in front of the door. Tip it with objects under the front legs and place objects on its seat until the pressure closes the door and the dishwasher starts. Put additional objects on the seat to insure vibration doesn't make the door pop open. If the cycle completes, the problem is probably the door switch. If not, the problem may be with the timer switch. If it's the timer switch the dishwasher will probably stop at the same position each time.
Nov 30, 2007 | Dishwashers
KitchenAid 24 in. KUDP02CR Built-in Dishwasher Logo
388 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
