Question about Lands Phones
My handsfree phone KX-TGA815AZ dials out & people can hear me but i can't hear them. Tried leaving a message from mobile...answering mode on & says you have reached message bank of, does not allow
  • 201 Answers
SOURCE: Stuck on Night Mode
Your phone can work on different Panasonic phone systems that program differently. I would need to know the model number of your phone system to look up specific information.
Until I get that info from you. Most systems can only be turned on and off from night mode at one phone station (usually the operator) but others will let you program a programmable key on any phone to do this. It's also possible to enter a function code from any phone on some systems.
Does it say Night Mode on a display? How do you know it is in night mode? If it is on a display, is it on all the displays or just one? If just one then that is the phone that can turn it off.
Posted on Nov 19, 2007
SOURCE: we have had a panasonic
We have this model also, and have exerienced similar problems. Try disconnecting all of the phone lines for that ph number, for a minimum of 30 seconds. Reconnect and the line should be functioning again. It always works for me.
Posted on Sep 12, 2008
  • 2460 Answers
SOURCE: Digital panasonic kx-t7633
The 7633 has a FWD/DND button. Is it blinking, lit solid or dark? It's designed to be pressed 3 times for FWD DND or OFF....It's programmed as follows, assuming that 500 is your voice mail access code:
From the intercom dial *7101. That sets DND. Dial 710x 500 # to set call forwarding where x-2 for all calls 3 for BUSY for for NO ANS 5 for BSY/NA. 7&8 are FOLOW ME commands and they have a different set of instructions ie Dial *7107 plus your extension to have calls come to the phone you're at and *7108 plus your extension to cancel it. I have never seen it used. *7100 cancels all forward and DND arrangements from your phone..
This is just hte command set for ALL CALLS. You can also set up forwarding for Outside Calls and Inside calls seperately and you can program buttons to do the forwarding.
Your Panasonic dealer has 2 manuals that you would find interesting, one is the TDA Operating Manual and the PTPM Manual. The operating manual has a complete set of programming instructions for the manager and users of TDA systems, the PTPM has a complete set of programming features that can be performed from a Panasonic 76XX display phone.
THe pdf's aren't huge and they can be sent to your email address if you provide one under the Ask Me button.
Posted on Oct 01, 2008
  • 96 Answers
SOURCE: problem is "disconnect text phone first"
U have selected text phone option in ur enhancement setting, please deactivate or change it defualt
Posted on Mar 03, 2009
SOURCE: panasonic cordless phone #KX-TGA931T
For the speakerphone switching phone off problem, substitute the 630 mAh Ni-MH battery that comes with the phone with a better Ni-Mh battery of higher mAh such as Duracell or better yet eneloop.
Posted on Apr 18, 2009
How do I activate the handsfree mute button on Norstar M7310? When I push outside line, then handsfree, I get dial tone, but cannot dial outside number. When call is incoming, after answering, I cannot...
familirize with devices user manual whether has feature functions requested. Second, ascertain that device was least malfunctioning since acquired. normally, familirising with innovative devices makes expertise in functionality.
Jul 20, 2011 | NorStar Meridian M7310 Phone
If I call an extension and they don't answer how do I program the phone so that I can leave that person a message? I'm using Panasonic KX-T7453 Thanks Chris
Press the MESSAGE button. It will light the lamp on the receiving station and when they press MESSAGE it will show that you called.
If you're trying to program "voice mail", then there are specific instructions to setting Call Forward No Answer or just dialing into the VM sytsem and dialing #6 and their extension to leave a direct message.
Dec 01, 2010 | Panasonic KX-T7453 Corded Phone
Why does the auto dial/store button lights up by itself on the kx-t7730
Get a picture of that and send it to Panasonic! Your phone would be the *ONLY* one that does, since the button has no light.
Now, the AUTO ANS/MUTE button lights up when pressed to put the intercom in the Auto Answer mode under certain conditions. That could be the one you're seeing. It either forces intercom calls into auto answer if it's a ringing call, or into handsfree answerback if it's a voice call. It also indicates a muted microphone on speakerphone calls.
Aug 17, 2010 | Panasonic KX-T7730 Corded Phone
Can't hear anything in my bluetooth headset, mic is working
try going to the settings of your BT headset... hope that works
May 25, 2009 | Cell Phones
Sony Ericsson K850I - Not being able to hear the people I call
You can reset all settings to factory simply removing the phone battery.
if that does not solve the problem, then the phone is faulty, with bad wiring to speaker or board problem.
Try if the handsfree loudspeaker works, if it does , then it is wiring to handset speaker. If it does not , then it is a faulty audio circuit on board.
Apr 25, 2009 | Sony Ericsson K850i Mobile Phone
How do I retrieve messages on the Panasonic KX-T7030 phone?
  • Call into your mailbox (usually by dialing intercom 165)
  • Press 4, and 4 again (for "Incomplete call handling")
    By default, three options are enabled:
    option #1: leave a message
    options #5: call the operator
    option #6: return to top menu
  • Follow the audible prompts to disable options 5 and 6
Here are some other features you may need
  • Make sure your Auto Answer button is lit up, so you can receive intercom announcements, and respond hands-free.
  • Use the Call Forwarding (FWD) to send un-answered calls to another phone or to voicemail
  • Press BGM (or 1 on the touch-tone pad) for background music, if your system is equipped.
  • Use Absent Messages to show text messages on other people's phones when you are away.
  • Use System Call Waiting so your phone will ring even when you're on the phone. Press Intercom and dial 7311 to set it up, or 7310 to cancel.
  • Use Do Not Disturb (DND) when you don't want to receive calls. Press Intercom, press FWD/DND and dial 1 to activate, or 0 to cancel.
  • Press MESSAGE when you call a busy intercom number. This will turn on the MESSAGE light on the other phone, and the other person can tap that button to automatically call you back.
  • If you get a busy signal when you call an intercom number, you can signal the other person by dialing 1 (if that phone is programmed for System Call Waiting (above).
  • Dial 330 to make an announcement to all phones.
  • If you want your phone to automatically select an outside line when you pick up the handset, press PROGRAM, dial 99, dial 12, press STORE, press PROGRAM
  • Feb 12, 2009 | Panasonic KX-T7030 Corded Phone
    Cannot call out or answer a call
    The only thing I can think of is you may be in the wrong dial mode. If you do not have touch tone service you will hear the tones but it will not connect. Try setting it to pulse and see if you can call out. Check you volume or see if the mute has been set. Have you tried a different phone? you might want to borrow a phone from a neighbor to see if it is a service problem or just your phone.
    Feb 01, 2008 | Panasonic KX-TG6021 Cordless Phone
    Mysterious -PRO- message on the 26510
    Could the "PRO" stand for Program Mode? Is there a Program button or selection under Menu in which you can shut off a Program Mode?
    Nov 10, 2007 | Northwestern Bell EasyTouch 26510 Corded...
    Lands Phones Logo
    Top Lands Phones Experts
    Are you a Lands Phone Expert? Answer questions, earn points and help others
