Turning off the function keys on keyboard - Computers & Internet
WHEN I PRESS U I O P J K L ON laptop, it type 4 5 6 - 1 2 3
try pushing the key marks "fn" and "F11" at the same time on your key board.
Feb 28, 2011 | Computers & Internet
My Dell laptop keyboard settings have apparently been changed-I have to hold down the Fn key to get the letters on the keyboard instead of the Fn items indicated on the keyboard. How do I fix it?
Maybe this is the result of inadvertently turning on "Sticky keys" (see the Accessibility Control Panel Help file). Try holding the Fn key down for several seconds with no other key pressed to see if that turns off the Fn lock-on. After that you can disable the Sticky Keys function in Accessibility.
Feb 09, 2011 | Dell OW7658 (J4624SK8115RT7D50) Keyboard
I use MacBook Pro (OS X version 10.5.8) in combination with LCD TV, wireless mouse and new Apple wireless keyboard. The problem is that function keys of the wireless keyboard do not respond in a same way...
Make sure to run all available software updates as there's probably a firmware update for your keyboard you need to download.
If there isn't or the problem persists afterwards, you'll need to go into Apple Menu > System Preferences > Keyboard and Mouse > Keyboard and uncheck 'Use all F1, F2 etc. keys as standard function keys.'
Nov 06, 2010 | Apple Wireless Keyboard
Scroll lock not turning off
Try holding down the function key and hitting the numlock or scroll lock key, this is usually how you engage or disengage the laptops function keys on the keyboard . Most laptops have a light that will turn on and off when you do this, indicating that the funtion keys are in use.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
May 22, 2010 | Acer NSK8458AN Keyboard
My laptop keyboard has optional "blue" upper and lower case letters and punctuation. how do i turn these on or off. they seem to work independently. i must be turning them on or off without knowing it.
Those keys with the Blue function keys only works when you press the Function Key together with it those keys in blue. . .
Check every single keyboard key. you should find "F" in blue. . .
Oct 27, 2009 | HP D8597A Keyboard
Acer Notebook Keyboard is locked
Just hold down Fn then press F7 or F8 keys to unlock keyboard.
Good luck.
Aug 14, 2009 | Acer Aspire 4315 Notebook
Function is not turning off
Mar 12, 2009 | Acer NSK8458AN Keyboard
Keyboard problems
It's your numlock that's on. It's for using your laptop as an adding machine like function. Do you see that certain letters also have numbrs on yr keyboard. Do you also see that theres the word numlock on one key. That's the key for turning on numlock ( in conjunction with the function key) so you can use those keys as an adding machine. Usually to turn numlock off and on you hold one finger on the function key and toggle the numlock key to turn it on and off. Consult your toshiba user guide for your particular model.
May 23, 2008 | Toshiba Satellite A135-S4527 Notebook
Key board turning off
what model do you have?
Nov 16, 2007 | Compaq Keyboard
Keyboard
Those keys are your function keys. They might be stuck, try turning num lock on and off. Check the manual, page 18, follow this link http://www.averatec.com/docs/3200_Series_Manual.pdf Hope this helps
Sep 14, 2007 | Averatec 3200 Notebook
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
