Question about Spalding Sport & Outdoor - Others
Why wont Spalding 44" lock when trying to adjust different heights
Adjustable basketball hoop
push on the back board up to get it to lock. Use the catch plate to bring it down.
Jun 14, 2016 | Spalding 72351 Portable Adjustable...
I have a Spalding 60 inch glass basketball system. It was lowered all the way down and now it can't be raised because it's too low. How do I fix this?
In-ground Basketball Goals: Spalding 88369 NBA ...
www.atlantahoops.com > In-Ground Basketball Goals
The Spalding 88369 NBA Inground Basketball Goal System includes a 60'W x 36'H Pro style extruded aluminum framed Tempered Glass or Acrylic backboard ... Click here to download the Spalding 88369 Basketball Goal Owner's Manual
Jul 26, 2015 | Spalding 79307 Basketball Backboard and...
Height adjustment does not work
Hello! The vacuum does not move up and down when you change the height setting. When the handle is reclined is when the height of the nozzle will adjust. Hope this was helpful!
Jun 26, 2014 | Hoover Tempo Widepath Upright Vacuum -...
Should Spaulding 44" model # 77537T be filled with water or sand?
Hi, according to Amazon (see link below), that model can be filled with either water or sand. My only thought was that water would be much easier to remove than sand if you ever wanted to empty out the tank.
http://www.amazon.com/Spalding-77351-Portable-Basketball-System/dp/B0027HDIAI
Oct 26, 2013 | Lifetime 3819 Impact 44" Basketball...
Front wheels on manual mower lock when pushing for awhile.
1 Locate the height adjustment lever on the inside of the left rear wheel.
2 Kneel next to the mower and push the left height adjustment lever toward the center of the mower. This will unlock the lever from the locking pin on which the height is currently set.
Read more: How do I Adjust the Height on a Great States Reel Mower? ' eHow.com http://www.ehow.com/how_6834215_do-great-states-reel-mower_.html#ixzz21NOr1e8d
3Rotate the lever toward the front of the mower to lower the height of cut, or toward the rear of the mower to raise the height of cut.
4 Release the lever over the locking pin closest to the desired height of cut.
5 Repeat these steps with the adjustment lever on the right-side rear wheel. Be sure to set the right wheel lever to the same position as the left-side wheel's lever for an even cut.
Jul 22, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lifetime Portable Basketball System- The pole are stuck.
Deddy456 was spot-on with dropping the poles from waist level. Worked for our Spalding that looked hopeless. Thanks!
Jul 04, 2010 | Lifetime 3819 Impact 44" Basketball...
Sport & Outdoor - Others Logo
363 people viewed this question
Top Spalding Sport & Outdoor - Others Experts
Bill Eager
Are you a Spalding Sport and Outdoor - Other Expert? Answer questions, earn points and help others
