Wave length selector button replacement if possible please and also only stays on for 30 secs then goes dead light off has a newish battery and is,fully charged.
    Top Expert:
  • Computers & ... Master
  • 24,759 Answers
Make, model and OS of laptop please.
Posted on Dec 26, 2016
  • 16 Answers
SOURCE: Dell Inspiron Battery problem
Try this trick. Remove the battery from the laptop and make sure the ac adapter is not plugged in also. Hold the power button for 30 seconds. Place the battery back in and see if it powers on. If not let me know.
Hope this helps.
Posted on Oct 29, 2008
  • 52 Answers
SOURCE: I have a flashing/blinking orange battery light.
Most likely you have a problem with the battery or electric circut in your laptop. Unfortunatly there is not much you can do, except taking it professional repair service.
Posted on Mar 19, 2009
  • 629 Answers
SOURCE: I have a Dell XPS
this is either a motherboard, AC or battery problem. Isolate it by removing all attached devices, then emove the battery and power on the computer with just the AC adapter. If that does not work, remove try to use another AC, and another battery. if using another AC and another battery does not work, run the diagnostics on the dell laptop. press and hold the FN key, then press the power button. see if that will give you any error and take note if any of the lock lights will come up and/or blink.
Posted on Apr 08, 2009
  • 313 Answers
SOURCE: Battery fully charged, icon says fully charged but
sounds like you "MIGHT" have a bad battery. But before you go shopping try to reset you battery..
  1. I have had the same problem and emailed Acer. You need to upgrade your BIOS settings and it will be fixed.
    This was acers response:
    Dear customer,
    Recently it was identified that a small number customers were experiencing a problem with the battery where it would not hold a reasonable amount of charge. We have released an update that should be applied to your computer to resolve this issue. Please complete the processes below and should you have any problems please do not hesitate to contact Acer support on 1300 365 100 or log a service request online at
    Thank you, Acer Support
    THey also sent me a word doc with the process and a zip file with the BIOS update. I can not upload the up on these forums but if you go to acer they should respond within 1 hr. I sent my request at 1700hrs on a Sturday afternoon and got a response within 40 mins.
    ** if you need help with that then, this is how you do it. **** After download Acer Aspire one – battery not charging.
    Solution: Update the bios as follows:
    1. Go to
    2. Click on Driver & Downloads
    3. Select Product Family “Netbook”
    4. Select Product Line Aspire One
    5. Select your Product Model i.e.: AOA150 (located after MFG.Date:xxxx AOA 150 – xxxx)
    6. Click on the BIOS tab below
  1. Just a little more information on the Acer Aspire One Battery not charging issue:
    BIOS revision 3309 (and later) has a fix for battery charging particularly the 6-cell batteries, however if you have the latest BIOS and your battery still isn't charging a good solution is to power down the computer, remove the battery and unplug the AC power cable then push and hold the power button for a whole 2 minutes (nothing will happen, we're trying to completely drain all residual voltage from the mainboard to reset it), then release the power button, install the battery and power up the computer, it should now recognize the battery and begin a normal charge cycle.
    I have read other posts that claim to hold the power button in for 1 minute which I tried and it did not work, you must hold it in for the whole 2 minutes. (which is probably what you were advised to do,as you mentioned.I just like to cover all the bases,)
I know it is a lot. But I hope it helps
Posted on Oct 27, 2009
Testimonial: "So helpful,thanks will try this first- saw other posting bout 'BIO', Acer said hold for 30 secs- then post back under warranty- not keen"
  • 177 Answers
SOURCE: My dell D810 won't power up.
Please try the following troubleshooting steps:
1 Disconnect the battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Connect the charger (don't connect the battery yet) and try to start by pressing the power button.
Let me know if everything remain same.
Posted on Feb 18, 2010
My acer aspire v5-531 will not turn on and no lights at all when connected to tested power supply
kindly remove the battery n check with power, if possible get checked the power connector of the power supply, with a multi meter, if its ok then its a main board issue. u have to change the main board
Jul 16, 2016 | Acer Aspire Laptop PC V5-531-4636
Have garmin ique 3600 possibly deleted os light stays on and unit does not power on or resei
Please remove the battery from the back of your garmin and then insert it back in after 30min .Next press and hold the power button for 30 sec and it wwill turn on.
Let me know the result.
Sep 30, 2008 | Garmin Computers & Internet
Better to pull up the error codes. Following areas can also be checked:
1. Fuel pump control circuit
2. Electronic throttle control system
3. Immobilizer
4. Crankshaft position sensor circuit
5. Short circuit.
7. ECM.
Feb 27, 2014 | Toyota Prius Cars & Trucks
Acer aspire 5336 black screen...when i turn on the paltop the acer logo comes on and it boots up , while it is booting up the screen goes black, i can barley see the icons on screen underneath..if i...
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :-
Jul 26, 2012 | Acer Aspire One PC Notebook
I have a mk3 golf gti 16v sometimes it starts revs once then cuts out and won't fire up! i leave it for a few hours then it starts no problem!
you need to reset the alarm/immobiliser system...put key in drivers door and unlock/hold key over,windows will go down,wait 30 secs.
then,lock/hold key over ,windows will go up,wait 30 secs then press/hold unlock button on remote to reset system.(if you have,nt got a remote,you will HAVE to buy one)and make sure you have newish batteries in remote.
you can buy a "superchip" for this car @volkstuning,goes like stink....
Sep 02, 2010 | Volkswagen Golf Cars & Trucks
My computer will not turn on
connect a power cable to the slot and then try.
If it still fails than take out the battery and press the power button for approx. 15 sec . put the battery in and then try.
Feb 26, 2010 | Lenovo IdeaPad Y530-5243U
I Press The power Butten the lights Blink once then it just has this light That looks like a circle with a Z in it stay on and battery light and plugged in light stay on nothing else happens doesn't go any...
I suggest you try a manual reset. Please remove battery and AC Adapter and hold down power button for 30 sec. and then put battery back in and AC adapter and try starting.
Feb 06, 2010 | IBM Lenovo ThinkPad R61i Notebook
Laptop won't start-up
Can you tell me if the status lights on the power adapter and/or the battery turns on? Because you are telling me the status lights only stay on for 30 seconds, this should be a power connection problem.
One other possibility: can you tell me the climate environment of where you use your laptop?
Nov 16, 2008 | Dell Inspiron E1505 Notebook
Computers & Internet Logo
David Payne
David Payne
