Is it safe to use a window A/C unit if there is mold still embedded in the styrafoam after cleaning?
I cleaned my window unit thoroughly with bleach and let it dry to find that no matter how much I scrubbed thre was parts of the styrafoam where the mold would not come off. I sprayed the parts with mold with a clear acrylic paint to hopefully prevent any future growth and let it dry a few more days. Is it safe to use or should I get a new unit?
SOURCE: smells of mildew and so do clothes
There is another product out there that seems to work real well.... it is called "AFFRESH" and it is for He front load washers... Its available at Lowes for about $6.50
Posted on May 29, 2008
SOURCE: LG Dishwasher model LDF7811 doesn't clean
LG DOES ****. We had this dishwasher and from the very beginning it didn't seem to dry and within a few months it was not cleaning as well as we had hoped. Within 9 months it had gotten so bad that we were really unhappy and then we got an error code. LG arranged for a local repair company to take a look at it. They ended up replacing EVERY part of the dishwasher except the tub itself. They replace the pump, the heater, the whole door assembly, the wiring harness (the wires had started melting into the sound proofing material), the electronics. Literally everything. From that point on we really noticed that we were getting food chunks on everything. Not only that, all the dishes were greasy and it wasn't even coming close to drying. There was mildew and mold growing inside the tub! Finally I got fed up and threw a fit with LG. They sent another repair guy out and he told us it was going to take 3 weeks to get a brand new pump and heater because the replaced heater had failed. After I complained to LG the repair guy got the parts in a week. He quickly replaced it and tested it and it flooded our kitchen (hardwood flooring) and leaked through the floor to the ceiling downstairs. The new heater was faulty. Not only that, the repair guy told us that the first repair, 9 months earlier, had not been completed and our turbulence detector had never been hooked up. Our solution? We fought with LG and Home Depot, where we got it, and LG offered to replace it with a new dishwasher. I said forget it, we didn't ever want an LG dishwasher again. Home Depot stepped up and took back our 2 year old dishwasher and refunded all our money. We bought a KitchenAid and we LOVE IT!
Posted on Oct 12, 2008
SOURCE: Mold on gasket
Maytag settled a lawsuit a few years ago for the same problem. We missed the boat and after battling it I'm just going to replace the gasket. I've tried everything from Windex to straight tea tree oil. The best thing actually, I've found is using something sharp to literally scrape the mold off. I just can't find a part number for the brush part that goes around the drum.
Posted on May 25, 2009
jyackle5
  • 8197 Answers
SOURCE: I have 2 Wagner power painters, neither work at
I have had that happen to me you need to rebuild the diaphragm to **** up the paint.
Good luck
Posted on Sep 30, 2009
blueextc3221
  • 15935 Answers
SOURCE: foul odor
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*&^%4
Posted on Sep 28, 2010
Mold
Techniques for Cleaning Surface Mold
Surface molds grow in just about any damp location, such as the grout lines of a ceramic tiled shower. They\'re easy to scrub away with a mixture of 1/2 cup bleach, 1 qt. water and a little detergent. The bleach in the cleaning mixture kills the mold, and the detergent helps lift it off the surface so you can rinse it away so it won\'t return as fast. You can also buy a mildew cleaner at hardware stores, paint stores and most home centers.
Even for simple cleaning, protect yourself from contact with mold and the bleach solution by wearing a long-sleeve shirt and long pants as well as plastic or rubber gloves and goggles.
If the mold doesn\'t disappear after light scrubbing, reapply the cleaning mix and let it sit for a minute or two. Then lightly scrub again.
Seal the clean surfaces when they\'re thoroughly dry to slow future moisture penetration. Apply a grout sealer (available at tile shops and home centers) to tile joints.
Caution!
Don\'t mix ammonia or any detergent containing ammonia with bleach. The combination forms a poisonous gas.
Read more: http://www.familyhandyman.com/cleaning/mold-and-mildew/how-to-remove-mold/view-all#ixzz39zX8rYj8
Aug 10, 2014 | Tools & Hardware - Others
Mold removal
Bleach and water (50/50 mix) put it in a spray bottle . shake, and spray it down, be generous. wipe it down spray it again. and if you can set it out in the sun and let it dry. bleach and water kills almost all molds. all the molds you and i would run into
May 01, 2014 | Exercise & Fitness
Is it safe to clean my cats litter box with bleach?
Yes, regular household bleach is safe to use when cleaning your cats litter box. Just make sure to rinse the box thoroughly after cleaning.
Aug 14, 2012 | Cats
How do I get the mold off the rubber piece on the door can I use terpintine?
Turpitine may damage the seal.Vinegar should safely and effictivly clean mold
Aug 12, 2011 | Frigidaire Washing Machines
Have possible mold in window unit a/c with 10500 BTU. Model # AEW10AMG1. Mfg. 01/09. Can I remove/snap off front vent to clean unit with bleach?
You should be able to clean the mold from the coils with a bleach and water solution without any concern for damage to the unit. However.. there are products designed for this job. If you insist on using bleach I strongly suggest that you remove the unit from the window and perform the cleaning in an area where the bleach solution can drain out of the unit without dripping on and ruining carpeting, etc. inside or killing plants outdoors.
Below is a reply I gave to someone asking about cleaning coils. You might want to do this too, and these cleaners are designed for the task - and will remove the bleach smell at the same time.
Both the evaporator and condenser coils (inside and outside) can be safely cleaned with products specifically made for the job. Clean evaporator and condenser coils mean more efficient cooling - which means lower operating costs. Cleaning the coils can remove stale or other less desirable odors that originate from your air conditioner. An example of such a cleaner is made by Thermwell which is available at Lowes and other hardware and home improvement stores. There are many different manufacturers of the cleaners - so if this particular brand isn't available at the store you shop, another will do. Different brands and types have different application methods - so you should read and follow the directions on the can. Many of the canned foaming / spray type cleaners are "rinse free" - meaning it is not required to rinse the foam off - as running the unit will allow the condensation that forms of the coils to do the rinsing for you. If you remove the unit an clean outdoors - or driveway, etc. then go ahead and gently rinse with a garden hose. Keep the water from the inside electrical and electronic controls. It should be noted that window / thru the wall types and other non-central air conditioning units should be tilted so that the condensation and chemicals drain outside - not into the house. If your AC hasn't been dripping water inside, it should be fine. Usually all that is needed is to remove the front grill and filter to access the coil. With the unit off (preferably unplugged) spray the foaming cleaner into the coil and let it sit to work on the dirt, grime, mold, nicotine, etc. that has collected on the coil. When the last step of the can's printed directions are complete - the job is done. You can find some helpful videos on Youtube to show how the cleaning is done on the larger, central air type units.
Please rate this reply if it was helpful to you - good luck!
Aug 12, 2010 | GE Heating & Cooling
Cleaning internal humidifier
Try using vinegar and distilled water.
If this does not work try using a little bleach and water. Repeat till mildew is gone.
Rinse thoroughly Again & Again.
Everyday humidifiers should be cleaned.
After your last uses try blow drying it. Before you put it away. If it's dry it will not mold or mildew.
Mold & mildew will cause you to get very sick.
If the mildew does not go away replace your unit.
May 19, 2010 | Humidifiers
How to clean a moldy humidifer?
Bleach is a good way to clean a mold humidifier or you can buy additive expecially made for humidifiers to fight mold.
Dec 20, 2009 | Humidifiers
Black mold in broken Dishwasher
bleach is always good i suggest you cover the dishwasher with a good plastic film after you spay it with bleach to keep the mould inside it till you can remove it
Dec 17, 2009 | Dishwashers
I have discovered mold growing inside the chamber that mist emits from. how do i thoroughly clean it. how often should i clean it?
The best thing around your house is bleach, it kills mold dead. Mold needs moisture, food, air so removing any one of those will kill it. I would try cleaning with soap and water with a little bleach every two weeks and see how it goes, they increase or decrease the time between cleanings as determined necessary. Remmeber bleach stains anything it comes in contact so be careful with it.
Good Luck,
Gilshultz
Dec 01, 2009 | Vicks V4500 1 Gallon Humidifier
Maytag Neptune Washer dispenser unit has mold and mildew inside top of dispenser compartment.
You can pour the bleach in the drawer every time you do white loads and it will stay clear too!
Just flush it out good before you do colored clothes or you may get a small bleach spot on a red shirt !
Neil
Ps. Give me a problem solved rating here on fixya.com
Aug 19, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
