Question about LG Ovens
I have a LG double oven model#LDE3017ST. None of my 5 burners won't come on. I get error code F3 on all butners
SOURCE: GE Model JTP15 oven shows F3 error code
I have the same problem. I noticed that the oven gets to the selected temp ok. Then when the pilot attempts to RELIGHT, it gets the error F3. Did you get a solution? After other posts, I will see if the temp sensor is around 1100 ohm as suggested by others. Ken
Posted on Sep 24, 2007
fridgetech
  • 473 Answers
SOURCE: F3 and F2 Error Codes
If hitting clear/cancel won't clear it try unplugging and then plug it back in. My guess is the oven control is bad. Here are the fault codes for this model.
Failure
Code
Condition Check/Repair F0 or F1 Failed transistor in control If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad F2 Oven over temp - exceeded 590F with door in unlocked position or 990F with door locked If actual temp condition occurred, look for welded relay contacts or high resistance connection or any cause in the oven temperature sensor circuit F3 Open oven temperature sensor circuit Measure oven temperature sensor circuit at oven temperature sensor (should be approx 1100 ohms at room temp); check for cut or pinched wire or loss of contact F4 Shorted oven temperature sensor circuit Same as above; check for melted connector or both leads shorted to ground F8 Component failure within Electronic Range Control (ERC) effecting temp processing circuits Replace Electronic Range Control (ERC) F9 Problem with door lock circuit such as pinched wire between Electronic Range Control (ERC) and door lock switch Check wiring and test operation of switch
Posted on Jul 15, 2008
  • 19 Answers
SOURCE: F2 and F3 error codes in GE electric wall oven
Call GE answer center 1-800-626-2000 ask for tech help, Have you Model # off you data plate ready.
Posted on May 09, 2009
  • 172 Answers
SOURCE: i have an amana electric stove (manual 35-315017-05-0)
The f3 error code is a communication error between the control and the temperature sensor. The temp sensor is a small pencil shaped thing in the top of the oven. You will see in when you look inside and at the top back part. You will have to get to the back of the oven to replace the sensor should that need to be done. First thing to do is to turn off the power or unplug the unit. Pull it out and take the back off. Locate the temp probe inside the oven. Then from the back remove the sensor and unplug it. It is an easy fix and most people can do it themselves. If you need a sensor sent to you. I do have them in stock and ready to ship. They are $65.00 including shipping. Thanks and good luck..
Michael Anderson
Anderson Appliance
(865)945-3808
Also on Ebay AndersonAppliance2009
Posted on Feb 10, 2010
rylee_smith
  • 8619 Answers
SOURCE: How to Fix Code F3 on GE Oven
Hi
Thanks for using FixYa. Error F3 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 04, 2010
Fault code E4 F3
The F3 codes mean that the oven temperature sensor has a problem. In the case of the E4 error, it is an open circuit. (If the GR465XLS0 is a double oven model, it's the lower oven with the problem with the sensor.)
You need to replace the sensor. Unfortunately, I'm not sure that you have provided the correct model number. Most Whirlpool ovens have an extra character in the model number. If your model is the GR465LXLS0, the temperature sensor will cost ~$65. One source is http://www.appliancepartspros.com/Appliance-Parts/whirlpool-oven-sensor-assembly-item-number-ap4326911.aspx .
I hope this helps.
Sep 07, 2012 | Whirlpool Ovens
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
My frigerdaire oven heats for a while about 15-30 minutes then shuts down with a beeping noise and a f3 code.
Good Afternoon Friend,
I see that your Frigidaire double oven heats up for about 15-30 minutes, then shuts down and begins beeping while showing an F3error code. The F3 states that the oven is sensing a potential runaway temperature. This is possibly a sensor issue or it could be a false error code.
I suggest giving your double oven a hard reset by cutting the power at the circuit breaker for at least 2-3 minutes.
After restoring power you will need to reset the clock. You will do this by entering in the time and pressing start.
Let the oven heat up, and if you are still receiving an F3 error code, I suggest either contacting the manufacturer or contacting your local authorized technician to diagnose your appliance. Hope this helps.
-Best Regards-
WP
Jan 27, 2012 | Frigidaire 30 in. Electric Gallery Series...
E1 F3 error code
F3
- E1 Oven temperature sensor (RTD) shorted
(upper oven, if double oven)
Replace
Note: Applies to all
F3-E... codes
Feb 08, 2011 | Kenmore 47702 / 47704 / 47709 Electric...
I keep getting an error code ED-F3
The F3 - E0 means Oven temperature sensor (RTD) opened (upper oven, if double oven) Replace Oven temperature sensor (RTD)
Note: Applies to all F3-E... codes.
Nov 26, 2010 | Whirlpool Ovens
Kenmore wall oven keeps showing error codes f5 and f3. Unit will not say on.
oven went into E2 F3 oven code while cooking a chicken and broil burner came on turned off oven but broil burner stayed lit, then had to unplug
Nov 13, 2009 | Kenmore 47702 / 47704 / 47709 Electric...
Kitchenaid oven says Error code F3E0, oven sensor-upper what'sup
It means the sensor that lets the thermostat know what the temperature of the oven is has failed. You need a new sensor.
F3 - E0 Oven temperature sensor (RTD) opened (upper oven, if double oven) Replace Oven temperature sensor (RTD)
From KitchenAid themselves
F3 E0
Get one from the people in the first video. Very easy fix.
https://www.youtube.com/watch?v=VZKHpduF9RI
kitchenaid oven temperature sensor replacement Google Search
Sep 17, 2009 | KitchenAid Ovens
F3 error in roper model B9757XO
Hi. This F-3 code is representing a malfunction within the oven temperature sensor. It is open at the moment and unable to transfer data at this time.
You can test by Measuring the oven temperature sensor resistance, should be1100 ohms. If not, replace sensor.
May 16, 2009 | Ovens
Error codes
Hello raco1
Welcome
I need your model number to look up the fault code !!!!
You said , you see fault codes, FD F3 and E2 F3 is showing up on display pane
Looks like this may be your problem
F3 - E2 - Oven to hot -Replace oven temperature sensor
Waiting for your response.
When responding send me this whole communication . Not just your answer!
Thank you Huuum.
Oct 03, 2008 | Whirlpool RBD305PD Electric Double Oven
Ovens Logo
59 people viewed this question
Top LG Ovens Experts
pawnpower
Dave Harrison
Are you a LG Oven Expert? Answer questions, earn points and help others
