Homeworx antenna no tv pic at all only fuzz said check connections... they are good what next?
4 Suggested Answers
jimbo4026
  • 50 Answers
SOURCE: programming
can you enter channel 4 manually and get picture
Posted on Nov 20, 2007
  • 6 Answers
SOURCE: I have a jensen ts275oj
try going into menu and check the reception option try air or catv maybe that might work
Posted on Mar 17, 2009
skywavebe
  • 1267 Answers
SOURCE: ge antenna 24700
Hi Patrick,
A fuzzy signal on a plasma TV is not common anymore as with the lack of analog TV transmission the signal is either there or it is not.
A amplified HD TV antenna is not always a solution and often times to get a good HD type reception a good outside antenna is required. I have two $100 antennas high up on my roof and still you can get a loss of data stream when the weather is bad. I also use distribution amplifiers to feed several TV's
In the case that the picture is fuzzy but still there it might be a resolution setting that is wrong so hit the menu button on the remote and see if that display is clear- if it is then try setting a different resolution for the input that you are getting fuzzy signal on.
Posted on Aug 11, 2012
My samsung plasma tv powers on has sound and a picture, but is snowy, and coloring is slightly off. I have opened the tv to check for bulging caps and have found no obvious culprits. what next?
Snowy pics are not the symptom of bulging caps.
you must mention what type of source produces 'snowy' pics.
have you tried with other sources and ports ?
I recommend, you test out the following.
- DVD with Component connection
- HDR or STB with HDMI
- TV/Antenna
Aug 15, 2016 | Samsung Televison & Video
Not working
How far are you from the TV transmitters?
Sep 30, 2014 | HomeWorX HW110AN HDTV Indoor Flat Digital...
Mintek DTV-260
The Mintek DTV-260 only has a NTSC (analog) tuner. You will need to connect your RCA antenna to a digital to analog converter box to watch TV over the air. Then connect the output of the converter box to your TV.
The common converter boxes are limited to SD output. You might be able to find an HD converter box online. (With the standard converter box, the available outputs are coaxial and composite video.) The DTV-260 has a composite video port; alternatively set the TV to channel 3 or 4 and use the coaxial (RF) input on the TV.
There may be a low-power station that still broadcasts in analog. However these are rare. You will need to switch from CATV to OTA (Air) to check for one of these stations. Analog Cable has different parameters than scanning for over the air signals.
I hope this helps.
Mar 04, 2014 | Mintek Televison & Video
Ge antenna 24700
Hi Patrick,
Aug 10, 2012 | Televison & Video
Channels 1 through 47 will come in and out but most of the time they dont come in at all. There will be fuzz for a second and then the screen turns blue. The upper channels work fine and dont cut out.
You need to check your antenna connections, and your Signal Amplifier, this sounds like that is your problem, IF you have visually and electrically proved your Antenna, cable, plugs, joints, and Amplifier are all OK, then you may have a fault in your tuner.
http://www.retrevo.com/support/JVC-AV-20D303-TVs-manual/id/279ci776/t/2/
http://www.jvc.user-manuals.com/list-of-manuals.php?page_id=702
http://elektrotanya.com/jvc_av-21bt8ens_chassis-11ak30.pdf/download.html
Bottom link is for your service manual, the next is for your user manual. Use these manuals to troubleshoot and hopefully repair.
May 19, 2010 | JVC AV-20D303 20" TV
Just getting fuzz, no picture or sound
check that the coax cable is complete and has no internal breaks. get a new piece and even paring both ends to wire you should get pic and sound even if its not clear. then attach new plugs and connect. Also check that the outside cable is still connected. If iit goes up into the roof check mice or rats have not chewed the cable.
Even a rabbits ears antenna should be able to oick up some signal even in a poor reception area.
Sometimes if it snot an antenna problem select rescan on the remote to check for signals
Aug 14, 2009 | Samsung CXJ1964 19 in. TV/VCR Combo
Picture shows snow and fuzz on channels JVC AV-32980
Sounds like U have an antenna or feeder problem. Get it checked out/ check it out. If in a strong signal area, try a simple indoor antenna for comparison. If in a marginal reception area, it could be your antenna is inadequate.
Mar 27, 2008 | JVC AV-32980 32" TV
Programming
Nov 19, 2007 | Zenith Z19A11S TV
Antenna hookup broke off
You have to re solder the connector. The other solution is to patch from the Direct TV box AV out to the AV input on the back of the TV. This will bypass the tuner and give you a cleaner picture. However, if your TV does not have an external input you must re solder the connector. As easy as it may seem, this should be done by a qualified technician. Its not as easy as it looks and requires good soldering skills.
Nov 12, 2007 | RCA F19207BC TV
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
