Question about Bella Watches
Need instructions for setting day & date on Bella & Rose watch Ref: CD187
  • 17 Answers
SOURCE: Adidas watch
hold right side buttons . time will flash set using top button, then use lower button to move through each aspect of menu. You use the top button to make changes then bottom to go to next option. Lower left button to exit
Hope it helps
Posted on Jul 30, 2008
  • 43 Answers
SOURCE: nelsonic watch with no instructions
Copy and paste this link. It will take you to Bulova's service centerwhere you can download instructions for any of their watches.
If you appreciate me finding this answer for you then please rank this solution as "fixya" or at least "helpful" as what I have found for you will solve your problem. :-)
Posted on Jan 14, 2009
  • 4 Answers
SOURCE: Setting Date. Seiko SGF204 (w/ 7N43 Band) French & English Days.
If you pull out the stem 1/2 way, you set the date one direction, and the day the other. If you pull it out all the way, it moves the hands and sets the time.
Posted on Feb 03, 2009
  • 2334 Answers
SOURCE: Resetting a SEIKO watch
You may can find instructions here:
Go through the watches till you find the match.
Rate me, please.
Posted on Mar 14, 2009
  • 50 Answers
SOURCE: Need instructions for setting a Sharp watch model # 2092
All the settings seem to go through the start/stop button. If you hold it down for 3 (not 2, not 4, but 3) seconds, it toggles in and out of "set the watch mode". You can tell you are in it because the seconds at the bottom go all blinky. Use (quick press) start/stop to move from seconds, to minutes, to hours, to year, to month, to day. Mode subtracts, reset adds. To set alarms, etc, first put the watch into Alarm Mode (Mode button, again).
Use the reset button to move to the selected alarm (1-5).
Hold the start/stop button for 3 seconds to toggle into "set the alarm mode".
Quick press of start/stop moves between things to set (kind of alarm, hours, minutes).
3 second hold of start/stop takes you out of setting mode.
Posted on Nov 06, 2010
Invicta model 12983, how to set day on the subdial
View the instruction manuals - Invicta
Enter your 4 or 5 digit model number to locate your watch. RECEIVE THE NEWSLETTER SOCIAL MEDIA · Terms & Conditions Customer Service Service ...Missing: 12983 ‎subdial
Setting Time Date Invicta Watch Chronograph - SmartBargains
Know how to set time, day, and date in the Invicta Watch Chronograph. ... Invicta sells several different kinds of chronograph watches, with the two main ... and the Invicta Big Date and Day chronograph - the subdials that measure seconds and ...Missing: 12983
Invicta Reserve 48mm Octane Swiss Made Quartz ...
Jan 16, 2016 | Invicta Reserve Mens Arsenal Swiss Quartz...
How do you change the day of the week and the date on Vintage rose 6752
Push in that small indentation with a pin tip until it's on the date you want, quick , but took me 4 months to figure out...
Jan 12, 2014 | Invicta Mens 6752 Vintage Rose Dial Black...
Setting day and date
Pull out the Crown half way to adjust the Date, all the way adjusted the Time.
Dec 27, 2013 | Invicta Mens 6752 Vintage Rose Dial Black...
I need to change the date on my watch and don't have the instruction manual. Thanks!
mcdevito75 here, Sounds like you have the time set, but the date is a fifferent matter, Here"s what to do, the stem (winder) of your watch has 2 positions, slip a fingernail just under the stem, and gently lift the stem to it;'s first position, this position allows you to change the date without so many cycles of the entire watch, it"s a little tricky but you"ll get used to it. Once you get this first position set the date to 1 day before the date you want, now pull the stem out to set the time of day, go thru 1, 24 hour cycle to set the date you want and time of day. The date is now set and will change on time, approx. Mid nite. Hope this helps.
Aug 03, 2010 | Watches
Westclox model LTX271 instructions for setting day
mcdevito75 here, The stem on your westclox has 2 positions, First pull the stem out to set the time of day, keep cycleing the watch until you come to 1 day before the day you want. NOW! push the stem back in. NOW! slip a finger nail just under the crown and gently, gently kift the crown to it"s first position, it may take a little practice so be patient, once in it's first position you can change the DATE easily, change the DATE to 1 DATE before the DA you want, push the syem back in and pull the stem back out and set the day/date and time of day. Your watch is set and will change on time a little past mid nite.
Jul 22, 2010 | Bulova Watch
My me1020 came without instructions and i do not know how to set the date, min nor theday please help
Actually there is no instruction manual for ME1020 available on Fossil website except for how to replace the battery. When you try to match ME1020 model with the available diagrams, there is no match (4 eyes). To set the time, pull the crown out to the second position. Now set the min/hour hands. Date hand is linked to it so keep rotating the crown till the date is set is set correctly. Now remaining is the day setting. Notice that the day changes every 24 hour mark on the 24 Hour sub-dial, so cross this mark to change the day. Go reverse & again cross the 24 hour mark to get the next day. Repeat this till you get the correct day setting. Now your day is also set along with date & time!
Feb 14, 2010 | Fossil ME1020 watch
Just been given an Audemars watch - don't know how to set it.
I was unable to find any instructions on their web site, so if you haven't got the instructions, then I suggest you try ringing them on one of the numbers below. (You might ask them for a set of instructions as well as how to solve your problem).
Toll Free: (800) 595-5330
Phone: (239) 262-4545
Jan 31, 2010 | Audemars Piguet Watch
Dec 01, 2008 | Seiko SGF204 Wrist Watch
Need help with Kenneth Cole Reaction Watch - setting date/time.
for a watch face that has a day of week, date, and moon calendar: There are two click points on the set-pin. pull out 1 click to access date/moon calendar; spin clockwise to set the moon calendar. spin counterclockwise to set date.
pull out pin 2 clicks to set time, just like any other watch
Mar 06, 2008 | Watches
Watches Logo
Top Bella Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Bella Watch Expert? Answer questions, earn points and help others
