Question about Photography
What is the capacity of a 12.1 digital photo frame from AVLabs? Have loaded some photos but it appears to be full. A much smaller model had heaps more capacity. Does this one require an SD card?
SOURCE: sizing digital photos to display in digital frames
Use the 16:9/4:3 key on the remote to toggle between widescreen and normal view. Most digital camera photos look fine at 4:3.
Posted on Jan 01, 2008
SOURCE: Matsui 7" digital photo frame
I got one for xmas and pics download easily every time. I connect my camera to the laptop then load the shots I want onto the SD card on the camera, disconnect and remove the SD card from the camera then insert in the frame. I have had no problems with photo size or downloading time. I do have a problem when I remove images from the SD card however. The frame still displays images that I deleted and are not showing when I connect to the laptop!  Can anyone help?
Posted on Jan 07, 2008
  • 7 Answers
SOURCE: card read error
Put the card back into the camera and off load/take off your pictures (Put them on the computer). Then, put the card back into the camera and go to your options menu. Find the format feature, and format the card. Take some new pictures and then try putting the card back into the picture frame. Does it work? If so, transfer the images from your computer back to the card. If it continues to work, then Great! If not, more than likely there is an improper or corrupt file among your photos.
Good Luck!
Posted on Dec 12, 2008
SOURCE: Saving photos to internal memory on ultech digital photo frame
go to http://camera.manualsonline.com/ex/thread/view/idthread/1339017
lots of good instructions, I got mine working already
Posted on Feb 01, 2009
  • 14 Answers
SOURCE: I want to transfer photos from my imac (usb) to an
You need an SD Card, an SD Card reader and a photo frame with an SD card slot. Put the SD card into the SD card reader and plug that into your imac, transfer your photos to the card and then remove the card and put it in the photo frame
Posted on Nov 22, 2010
Please provide Instructions for AVLabs Hi-Res Digital Photo Frame - 15
go google and type in -user manual for avlabs hi-res digital photo frame --- and if there is one it will be a pdf version download
Aug 13, 2016 | Photography
Why is the photo frame not reading my sd card
Try a different card, with less than 4gb capacity. If the problem persists, it's the frame. If the problem disappears, it's the card.
Some devices have a capacity limit. 4 GB is one such limit. Trying a 32 GB card in a frame only designed for 4 GB is sure to give trouble.
If so, either get a newer frame, or use your computer to transfer photos to a smaller card.
Mar 17, 2015 | Photography
How do i download photos from pc to digital photo frame
1. Connect the digital photo frame to an available USB port on the PC. Turn on the PC and the digital photo frame. Connect one end of the USB cable to the USB port on the digital photo frame (this end is usually smaller) and connect the other end to the USB port on the PC itself.
2. Wait for the PC to automatically detect the USB-connected digital photo frame.
3. Move any photo files that you want to display on the digital photo frame. Do so by copying and pasting each file into the connected USB device that you can view in "my computer". Many photo frames have built-in memory for this feature.
Jan 07, 2011 | Microsoft Computers & Internet
I have a digital photo frame Coby DP-5588. I bought a sd card Kington 4GB when I insert the card in the photo frame appears a message "wrong Card" and it doesn't read the card content. What can I...
Your 4GB card is actually an SDHC card, not an SD card. While SDHC cards will fit into SD slots, they are electronically incompatible and will not work. You need to use an SD (or MMC or xD or MS), 2GB and smaller.
Dec 05, 2010 | Coby DP-5588 5.6-Inch (4:3) Clock &...
How do you add new photos to the digital picture frame?
Most digital photo frames come with an SD (memory) card that you can plug into a computer and copy the photo's you want from the computer to the memory card. Once done you pop the card back in the frame and your done.
Please be aware that the SD card maybe of limited capacity so you might not be able to get all the photo's you want on it unless you purchase a larger capacity card.
Regards.
May 26, 2010 | Coby DIGITAL FRAME COBY DP102 RTL
Logik PF-A850WD photo frame not showing all photos
Have you tried GOOGLing that model and checking the info ?
Dec 10, 2017 | Electronics - Others
I can't load photos onto my digital photo frame
The  A701 is  a bit cranky.  I've found that it prefers  USB  flash sticks of upto  2GB. It likes the flash stick formatting  before use.  And it prefers  jpg files  added  to the root directory of the flash stick -  so  no images in folders. Finally but probably least important, it's not much point uploading  2MB  jpgs as  the screen  is pretty much  72DPI  smaller size JPGS  lead to a faster loading. ( try  around 900x 600 dpi )
Nov 17, 2008 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
Sizing digital photos to display in digital frames
Dec 26, 2007 | Cameras
Photography Logo
Top Photography Experts
pontelemon
pontelemon
Tony
Are you a Photography Expert? Answer questions, earn points and help others
