Question about Radio Communications
I have audio Bluetooth speaker it keeps flashing red/blue and won't connect to my iPad anymore
SOURCE: Bluetooth is flashing red and blue
sounds like your in pairing mode ... use your phone to search for the device ... when its found the system will ask you for a code ... enter "0000"
Posted on Jan 08, 2009
  • 211 Answers
SOURCE: red light keeps flashing
While I cannot find any reference to the flashing red light in the manual, it sounds like the amp is going into a protection mode. I would check the following items:
-Make sure you have the power wires connected to the battery with sufficient size to supply the load. The amplifier is rated for a 30 amp draw, and is fused at 60 amps (2x 30 amp fuses in parallel). I would recommend at least 8 gauge wire as an absolute minimum..and ideally larger than that. To troubleshoot this, try hooking a battery (with fuses inline, of course) with heavy gauge wire directly to the amp. Does the problem go away? If so, the voltage drop due to wire being too small is likely your culprit.
-Make sure your connections are clean. Corrosion at any point can rob your amp of the power it needs for sharp punch and proper operation. Be sure to also check wires at any other connection point. This includes fuse blocks, crimp terminals and at the battery itself. Keep in mind that corrosion does not have to be visible to cause problems. Soldering connections rather than just crimping them (when practical) can help overcome this, as can sealing connections that are exposed to road dirt and grime under the hood.
-Check the impedance of your speakers, and how they are wired. The manual goes into great detail on page 2 about how to properly wire speakers, and what ohm rating each should have. If you are using two 4 ohm speakers wired in parallel on one channel, this is too low impedance for the amp. Either split each 4 ohm speaker onto its own channel or switch to 8 ohm speakers.
While you might check these and still have a problem, hopefully these will eliminate some sources of problems outside of the amplifier itself. Good luck!
Posted on Feb 11, 2010
supernova278
  • 1932 Answers
SOURCE: Trying to connect Plantronic 220
1.First switch on the bluetooth in mobile phone.Keep the headset switched off.
2.Now press the call button for 2 seconds if you are paring this headset for first time,If this head set is aired already with another mobile press for 8 seconds until the headset status indicator begins to flash blue then red
3.Now search the bluetooth by your mobile device.It detects and you can pair it
Thank You
Posted on Nov 10, 2010
wb91
  • 126 Answers
SOURCE: I just purchased a Voyager
You will need to turn off your headset and then press and hold the power button until the LED starts to flash red/blue, red/blue, it will stay in this state for a few minutes.
Good luck from Headsets Direct - 800-914-7996.
Posted on Aug 19, 2011
HDI Headsets
  • 537 Answers
SOURCE: I cannot connect my 330 bluetooth to my phone, and I also cannot
Once you make your cell phone discoverable, then put the Plantronics Explorer 330 into pairing mode by holding the call control button until the headset flashes red and blue. Here is the link below for the Explorer 320 user guide which has the pairing instructions, it will be the same for the 330.
Plantronics Explorer 320
Good luck from Headsets Direct!
Posted on Oct 21, 2011
I can't get my jams hdmx speaker to pair with my iPad Pro. The speaker will not even list under "my devices."
If you can, erase the memory on the speaker and mark each Bluetooth listing on the iPad to Forget This Device. Do not be around any other Bluetooth devices. Turn your speaker and iPad off and back on. Let them discover like 1st time. Try again. Patience. Sometimes takes 20 to 30 min. RJ
Apr 25, 2016 | HDMX Audio HMDX Jam Plus blue
So it was connected for a while. but now it's not. and it's a blue color. it won't turn off, it stays blue, and my phone cannot find it anymore in the bluetooth section. How can i fix this?
Do not know this is what I found on the internet have no experience with the hv-800
To pair the headset, please keep pressing the turn on off button until the red and blue light flashing. ( I think this translates to holding the power button in for a certain time period - think it got lost in translation from chinese to english - somewhere )
on the phone search for bluetooth devices while headset in pairing mode
if asked to enter the password, please enter 0000, confirm and then the Bluetooth enabled device successfully connecting with this product. The blue light will flash two times every 5 seconds after a connnection.
Sep 04, 2015 | Unknown HV-800 Wireless Bluetooth Music...
How do I pair my I Pad with my new Philips portable speaker using bluetooth ( can connect fine using a cable)
If your portable speaker is Bluetooth-enabled, here is the general procedure:
1. Press and hold the function control button on the speaker until you see red and blue lights flashing in rapid succession on the speaker (the speaker is now in "pairing" mode).
2. Turn on Bluetooth on your iPad and then tap on Scan. iPad will begin scanning for nearby Bluetooth devices. When you see a name similar to that of your speaker, tap on it . You will be asked for a passcode/passkey to pair the iPad with the speaker. Enter '0000' or '1234' (without the quotes).
3. Once the passkey is accepted, the two devices are now paired. The light on the speaker should become a steady blue.
4. On the iPad, tap on Connect. If the iPad connects to the speaker, you will see Connected. You are done. Play some music from the iPad to see if you can hear it coming through the speaker.
You should have this procedure detailed in the set up guide that came with the speaker. Please note that pairing is required only for the first time you try to connect the two devices, to get them "acquainted" to each other. After that, all you need is to connect the iPad to the speaker every time you want to listen to your iPad through the speaker.
Nov 30, 2014 | Philips Audio Players & Recorders
How to get bluetooth speaker to connect already apired and is showing but wont connect
Hello, I have already met this issue: after pairing a bluetooth speaker on a first host (computer or iPad), then pairing it on a second device (as another computer for example), when I try to pair it again to its original host device, it doesn't work.
The solution consist in
1) on the host computer, in the list of the Bluetooth devices, delete the line of the bluetooth speaker and forget this bluetooth device,
2) push on the Bluetooth detect button on Bluetooth speaker,
3) scan the bluetooth devices on your computer host, and when you see the bluetooth speaker in the list, select it.
Jul 28, 2014 | Toshiba Satellite Laptop with AMD Athlon...
Hi,Just purchased 2 antec gain Bluetooth receivers type bxr 100. Operating instructions are not included. Maybe it's just me, but i'm not succeeding in getting them to work. No lights at all when they
Make sure that the unit is fully charged by a micro USB the light on it will be red until it's fully charged put phone in search mode and press the center button until the light flashes red and blue after the phone finds it you should have an option to auto pair when it's not in use it will turn off when paired and working pressing either track button will start the music player then just play with the buttons and see what it does you can stop anything from the phone controls
Mar 18, 2014 | Antec BXR-100 Gry Audio...
Isound will not connect
Just hold the Bluetooth bottom while trying to connect to phone
Nov 28, 2013 | iSOUND 1690 TWIST WIRELESS SPEAKER &...
My iPad won't find my Bluetooth speaker
Go to settings, General, blue tooth and remove any "other" previous paired BT devices & Turn off BT, then go to Sett. General, scroll down to reset and reset network settings, this will not delete anything. Power off BT speaker. after iPad re-boots turn on BT Speaker First, make sure BT is off on iPad as well as WIFI-wait like 10-15 seconds and then turn BT on in iPad it should see your speaker now and let you pair it up.
Jan 14, 2013 | Harman Kardon JBL Flip black
Can not connect my 9xxBackbeat bluetooth headphone to my laptop. My OS (Win 7 x32) recognize this device but then it says it can download the driver to run this device
In order to use this headset, your built-in Bluetooth in your PC needs to support the hands free profile, audio and A2DP profile. If it does, all you need to do is hold in the power button on the headset until you see the light on the headset flashing red/blue, red/blue. If it doesn't you'll need to load it onto your computer. Once the headset is flashing red/blue your computer should find it.
Sep 22, 2011 | Plantronics Backbeat 903 Bluetooth...
I just purchased a Voyager Pro. When trying to pair it with my Blackberry, I turned the device on and held the button down waiting for the LED to flash red/blue. The device turn on blue, then flashed red...
Aug 08, 2011 | Plantronics Voyager PRO Bluetooth Headset
Jan 08, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
