Question about Garden
How to do a water pump replacement troy bilt pressure washer model 020416
SOURCE: Troy bilt pressure washer 2200 psi
inlet valve connected to water inlet is stopped-up. Unscrew it, take a safety pin run through valve then take the pin and push through valve connected to pump. should do the trick. (the valve the suction hose for the soap is connect to)
Posted on Apr 08, 2009
  • 76 Answers
SOURCE: Troy Bilt pressure washer model 020209 has very
you are going to need a pump seal kit or they may call it a rebuild kit but this sort of thing happens often and you should not have any trouble getting the parts you need with the kit should come a exploded view diagram but request one just to make sure be careful when putting it back together if gyou damage any of the brass or neoprene parts you will be putting it together for nothing lay out your parts on a clean towel keep all dirt and grime away and clean your pump housing really good before you put the new parts in and i mean clean enough to eat off of if you do all of these things your rebuild will probably last longer the the original good luck and get back with me if you need help with the rebuild
Posted on Jun 29, 2009
  • 4090 Answers
SOURCE: pressure washer not working
sketchy info here....
Remove the hose and gun to see if water is flowing....
if it is that means there is no blockage in the hose or gun. When its connected if it runs at the same rate as without the hose and you have set it into pressure clean mode, then the pressure valve and seal have collapsed. Estimated repair cost is $200 and about $100 of that is labor. It is not a DIY unless you know your way around and have the right tools. Having it repaired professionally gives you 3 months warranty as well. Do it yourself and you could end up losing some of the small screws and other nylon components that tend to drop out and get lost when you open it up!
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Posted on Sep 13, 2009
Testimonial: "Very quick reply,very informative,very helpful. Thank you."
  • 468 Answers
SOURCE: Troy Bilt Tiller and Pressure Washer
The carbs are plugged. Take the bowl off the carburetor by loosening the nut on the bottom. You'll want to clamp the fuel line before you do this. That nut has a small hole that goes through the nut from side to side, and one that connects them in the center. Use a wire brush to knock all the deposits loose, making sure that the holes are clean and free of obstruction. Put it all back together, and it should run fine.
Posted on Feb 01, 2010
SOURCE: oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
Posted on Apr 18, 2010
All outflow stops when I start the motor on my Troy-bilt 2600 pressure washer. What's up?
Could also be crack/leak in HP pump. If it were left in cold weather without antifreeze, I'd check there first. Part + labor might warrant new washer if more than a couple years old.
Sorry.
Aug 11, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Power washer wont pump
Call us when you can be at the washer so we can trouble shoot it with you over the phone.
http://www.ppe-pressure-washer-parts.com/troy-bilt-020416-1-pressure-washer-parts
Mar 20, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Drive system not working
I'm not sure what you are expressing. Give us a call when you can be at the washer so we can diagnose it over the phone.
Dec 15, 2013 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Troy-Bilt pressure washer does not provide pressure
Sounds like your pressure pump is shot. Replace it.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/anthony_e4f197748c31eabd
Aug 29, 2017 | Briggs & Stratton Garden
I have a 2600 Troy bilt pressure washer.When I start the pressure washer,no water comes out the nozzle and the nozzle is not clogged either.I took the nozzle/gun off and there still was'nt any wat
If when you take the High Pressure water hose off the pressure washer pump no water will come out they you may simple have the bypass valve stuck. You may need to just remove the outlet fitting and clean the bypass valve.
It would be helpful to know the model number of the pressure washer or the pump.
Mar 29, 2012 | Garden
Troy-bilt 2200 psi pressure washer
I have a Troybilt Model 2200 PSI Pressure Washer in which I have used only 2 times in the past 2 1/2 years. Went to use it this past weekend and the pump in not working. Water shoots out of the side. I bought this brand and model as I thought Troybilt was suppose to be so good. Went back to where it was purchased and had no success but to say I could buy another pump or take it in to be repaired. I believe that this power washer should be replaced at no charge. 2 uses does not constitute a few hundreds of dollars.
Have you to heard anything concerning pump problems on this particular model? Thanks for any advice. .
Jul 09, 2009 | Garden
Oil for a troy bilt 2550 psi pressure washer pump
May 17, 2009 | Briggs & Stratton Garden
You need to replace parts 37 thru 41 on the pump breakdown.
Click this link for the breakdown.
Mar 17, 2009 | Garden
Turn Black cone shaped valve clockwise to increase pressure there will be a small +/- plus will increase and give you pressure.
TK U
Mar 17, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
