Question about Plumbing
My 1/2hp deep well jet pump will not prime, or pump water. The pump runs, but no water. I can hear what sounds like air bubbles being pushed into the pressure tank. Thanks for any help.
Things I have tried, another pump (not new), Pulled the lines out of the well to check for cracks and to check the ejector assy. and foot valve. Everything seems in working order.
  • 104 Answers
SOURCE: Flotec Shallow Well Jet Pump won't pump water
The tank is an air tank, it works like a cushon and accumulator.
Have you reconnceted the pump? If not fill the pipe that goes to the well with water. It should not drain down, there should be a foot valve that prevents the water from running back into the well. So if the foot valve is working it should not take a lot of water to do this.
Pour water into the suction side of the pump until the pump is as full as you can get it, reconnect the pump and start it up. Yes it does need to be primed
Good luck
Posted on Mar 17, 2009
SOURCE: new 1/2 hp jet pump with tank not working
Your hose size is to small. Use a 2in black plastic line out to the lake. Inspect your foot valve, and
take your pump apart to see if you may have a pebble stuck in it, and remove the inner workings
and clean. Contaminates build up inside and need to be flushed out. Remember to replace the
gasket. Tighten all your hose clamps. Once your ready to start, spray shaving cream on your
fittings to see if your sucking air. I've been through it all and my pump works fine.
Posted on Jul 06, 2009
  • 1114 Answers
SOURCE: My new AO Smith 2HP pool pump won't pump water, just hums
I'm guessing that you replaced the motor that goes to the pump, not the pump itself. You know the motor works just fine. Is the motor rotating in the correct manner(clockwise or counterclockwise) in relation to the rotation of the pump? Have you checked the pump to see if the impeller is working/rotating? Is the motor hooked up to the pump correctly, so that the motor is turning the impeller? Are all connections to the pump tight, so there are no suction leaks? Have you primed the pump and purged it of any air locks?
Posted on Aug 11, 2009
SOURCE: Cabin pump, primed fine only goes to28psi and keeps running
Sounds like the injector nozzle is plugged. This nozzle is directly inside the influent line on single line jets and down in the well on two-line jets. I'm assuming you have it primed correctly. If this happened suddenly the it'd definitely the injector nozzle. It it was a gradual process over time then I would say it's either a badly worn nozzle or worn impeller.
Posted on Sep 08, 2009
  • 523 Answers
SOURCE: gould 1/2hp submergible well pump cycles on and
My first thought was that of a water logged tank which causes short cycling, from your notes the tank is good (the tank may be partially water logged though) If the tank is ok and your getting short cycling (and the switch is good) I would guess your check valve down the well has failed. As the pump creates pressure then shuts off the water may be going right back down the well causing the pump to cycle again. This could also account for the poor water pressure as the check valve may be stuck slightly open allowing the system to loose pressure but only allowing a small amount of flow by when running. There could be a leak within the pumps drop-pipe and your loosing pressure through this leak. I expect you'll have to have the pump pulled.
I hope this may have helped,
Posted on Oct 12, 2009
I have a utilitech 1 hr convertible jet pump. My well is 58 feet. My foot valve is at 68 feet. My pump is primed. But it still won't pump water. And it us set up for deep well. Any suggestions?
I think you mean your well is 68 feet and your foot valve is at 58 feet. To properly prime a deep well jet system you must completely fill not only the pump but the entire casing also. This should take about 5 gallons of water. If you are not using anywhere near that much water to prime it may be the well casing is air locked which means the air in the well has no place to go and won't allow water in if there is a plug on top of the well adapter remove it and then try to prime system. Another method is to run the pump while priming to help break the airlock. Hope this helps.
Jul 26, 2015 | Jet Plumbing
Shallow well and deep well packer installation will not stay primed
Do you have a check valve installed? If not, your water will be flowing back down the well and taking the prime with it.
Jun 21, 2011 | Simer ACE5C ACE5C Pump 1/2HP Deep Well...
Yes!!! I have used that type of pump as a booster pump many will work just fine...
In fact it makes priming the pump much easier as you can let the water flow trough and push the air out before turning it on...
Feb 06, 2011 | Flotec Corrosion Resistant Shallow Well...
My flotec well pump will squirt water and then stop . I keep feeding it water slowly but it won;t prime. What should I be doing?
Check for an air leak in your siphon line. It can be very small and totally prevent the pump from priming.
Jun 08, 2010 | Flotec Corrosion Resistant Shallow Well...
Water is coming from well to pump, but pump will not pick up the water when trying to prime
If well is too deep for the pump, sometimes a foot valve is needed.
ALSO check that there is no back pressure on the output side.
Oct 31, 2009 | Flotec Corrosion Resistant Shallow Well...
Jet pump does not pump water
I had a similar problem and as a last resort took the pump apart and cleaned it and the jet. It's a very old pump but works ok now.
Jun 18, 2009 | Flotec Corrosion Resistant Shallow Well...
Shallow well pump made by wayne well is 22 feet deep pump runs no
Inspect the jet thru the suction pipe or the removable plug if the pipe isn't inline with the center of the impeller. The jet is very small, and easy to get something stuck in there. Then prime and leave the pressure pipe closest to the outlet slightly loose to let air out. Once you get good pressure you can tighten the pipe. Sometimes you have to prime more than once to get all the air out of the well pipe.
Mar 21, 2009 | Flotec Corrosion Resistant Shallow Well...
Pump works but is not pumping water
Jan 11, 2009 | Flotec Corrosion Resistant Shallow Well...
Plumbing Logo
77 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
