Question about Hobart Ovens
I have a hobart oven model hec 3018 i needs to kmnow the inicials in control panel what they mean exemple a1 sv
Can you explain the control panel ofr hobart oven model hec 3018
4 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: Control panel on oven not working (clock/heat time, etc..) (model fgf326a)
HI, this control(clock/timer), will need to be replaced at this time. this code represent a control fault within the chip set(logic). this control has failed.
Posted on Jun 01, 2009
marka19
  • 1430 Answers
SOURCE: I have a Magtag wall oven MEW6530DDS model. The
The control board. As long as none of the buttons appear to be stuck. Press each button one at a time feeling for the retraction or click. If this checks good replace the control board. Here is a link that should help http://appliancehelponline.com/ovenerc.html
Posted on Sep 18, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore oven Model 911.30169792 Control panel lights are on
It appears your ERC/CLOCK has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
What does E2 -F 1- mean?
It helps to know make and model in such questions.
Whirlpool Oven...what does E2 F1 mean on the clock/control panel ...
https://www.shopyourway.com/questions/1183452
Aug 27, 2012 - The "E1 F1" fault code indicates an Electronic control board malfunction. This means that the control board will need to replaced. I'm not able to provide a part number because there was not a model number submitted.I added an image of from the technical data sheet in reference to the "E1-F1" fault code. Whirlpool Gold Oven Error Code F1 E2
25 Jun 2013
Whirlpool Oven (GBS307PDQ0) Fault Code E3 (amber ...
17 Sep 2012
What does error code F1 mean on my Whirlpool ...
1 answer
14 May 2010
What does E2 F1 mean on a Kenmore electric range ...
1 answer
25 Mar 2009
More results from www.shopyourway.com
Whirlpool Oven...what does E2 F1 mean on the ... - Shop Your Way
https://www.shopyourway.com/m/questions/1183452 Aug 28, 2012 - Control panel for Whirlpool Gold double oven. 2 answers. whirlpool range, clock/oven control goes into alarm. 4 answers. Whirlpool Gold Oven Error Code F1 E2.
Whirlpool Gold Oven Error Code F1 E2 ' Shop Your Way: Online ...
https://www.shopyourway.com/m/questions/1218462 The F1 E2 error code indicates an oven control failure. Try disconnecting power to the range for 20-30 minutes, then restore the power. If this does not help, I suspect that the oven control will need to be replaced.
Whirlpool Appliance Fault Codes ' PartSelect.com
https://www.partselect.com/JustForFun/Whirlpool-Appliance-Fault-Codes.aspx Whirpool Oven/Range/Stove Fault Codes (Including 2 and 4 digit codes). Note: Depending upon the brand of appliance, there can be many different names for the 'clock' component. Electronic Range Control, ERC, Electronic Oven Control, EOC, control board, and clock all refer to the same part. 4 Digit Fault Codes. F1-E0 ...
Mar 24, 2018 | Whirlpool Ovens
Electric Phases for Hobart Oven
you must understand this : your electric oven must be indicate if it is a single phase( use 3 wires for 230 2 hot wires + 1 Neutral see the diagram like dryer? you must sure about this. Normally any appliance for home are single phase NOT 3 phase.
2) If you electric oven, say 3 PHASES( use 4 WIRES, 3 hot wires+1 Neutral wires) this for industrial application +comercial 270266c5-a0ad-44dc-9f40-e963255d47f5.jpgNOT for home
However if you system is 3 phase you must need to install 3phase transformer.ba1c9d4d-85e3-4744-8ce5-2f25c6e34ad3.jpg
Jul 18, 2013 | Hobart HEC501-240V Electric Oven
The top display says F2:E1 and the oven won't function. How do I fix this?
This is not exactly a solution, but it does explain what F2:E1 means. According to this page, it is a control panel malfunction. It may be caused by a shorted wire, but it may just be the control panel malfunctioning on its own.
Nov 04, 2010 | KitchenAid Architect Series KEMC308KSS...
Hobart electric convection oven model #cn90 ser. # 07-007-968-nj
Have you tried shutting down all power to your oven at the electrical panel, waiting 10 minutes and then returning power to the unit? Procedure could reset the defaults. Best of luck.
Apr 09, 2010 | Hobart HEC501-240V Electric Oven
MODEL NUMBER HR7E SERIAL NUMBER 46-2000-893 DOUBLE DECK OVEN GIVEN A FAULT OF PHE.... WHAT DOES THIS MEAN?
ON START UP WHEN OVEN IS COLD IT WIL DISPLAY PHE TIL IT REACH A CERTIAN TEMP IF IT KEEP ON DISPLAYING PHE REPLACE YOUR TEMP PROBE
Jan 28, 2010 | Hobart HR7E Electric Single Oven
Need to change oven from 440 3 phase to 220 single phase hobart cn90 oven
It can be done with a transformer, 480/ 240 single phase transformer to get the lower voltage. Then the oven will require some wiring changes to get all the elements and controls connected to two hot wires instead of three. The transformed will be sized to the wattage rating of the oven. This is a only basic description of what needs to take place.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 05, 2009 | Hobart Ovens
Jun 01, 2009 | Frigidaire FGB24S5A Gas Single Oven
I need parts for a old covection oven made by hobart it is a large stack with no model # commercial stainless any suggestions
Remove the lower panel under the doors. You should find the data plate on the back of the panel. What country are you in?.
Feb 24, 2009 | Hobart DEC502 Electric Double Oven
Control panel of Defy Multi Function Oven not working
If the control panel has delaminated they are covering this under warranty from what I have seen.
Hope this helps Ya
Jun 17, 2008 | Hobart DEC502 Electric Double Oven
Ovens Logo
32 people viewed this question
Top Hobart Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you a Hobart Oven Expert? Answer questions, earn points and help others
