Question about Home
How do I connect the chimes on my battery operated Strausberg manor wall clock?
2 Suggested Answers
escapement
  • 2334 Answers
SOURCE: Strausbourg Manor Wall Clock chime adjustment
It is normal for the average wall clock. Of course, this can be adjusted, but without watch/clockmaking knowledge it is impossible, because first you need to find out which part of the movement is causing early chiming - and there are plenty of them.
Super fine adjustment can be found only in top of the range clocks. Hundreds of hours of craftsmenship are spent to adjust and fine tune them. That's why they cost a fortune.
If you can not live with that early chiming, you have to bring your clock down to the watch/clock repair shop and ask for help. Be ready to pay quite a money, as this job takes the skill and a lot of time.
Rate me, please.
Posted on Jul 29, 2009
Where can I find parts for my strausbourg manor wall clock
Fixya is unable to suggest sources for Strausbourg Manor wall clocks parts.
Jul 05, 2018 | Home
Wall clock Ptrausboury Manor chimes on half hour instead of hour. How do I fix it?
Try to carefully remove the MINUTE hand (not the hour hand, as posted previously!) entirely from the clock then put it back in the "proper" place. for example, when it strikes at the six, remove the minute hand and put it back on pointing at the 12. Then re-set the time for half-past (or maybe quarter-till the hour by now! lol)
Mar 29, 2017 | Home
How to set a classic manor quartz west minister wall clock to chime at the correct time.
Hello Fern Hicks,
Short of ORDERING IN A NEW movement I
would rather try removing the hands... and placing them where they are chime appropriate...
I'm sure there are more convoluted ways of accomplishing the same thing... but I so old & clock oriented... I only turn clocks & timers in the FORWARD direction (very OLD school).
Remove the minutes hand (from where-ever it strikes)...
Move the hour hand (only if necessary & replace the minute hand as appropriate to the movement strike.
Classic Manor Quartz Westminster Chime Pendulum Clock0 results You may...
Carnac the Magnificent
Mar 26, 2017 | Chime Home
MINUTE HAND NOR THE HOUR HAND NOT ADVANCING AS THEY SHOULD. CLOCK STUCK AT 8:45 FOR DAYS, PENDULUM MOVEMENT OK. WHAT IS THE SOLUTION TO GETTING THESE BACK TO WORK? THIS IS ON A STRAUSBOURG MANOR...
without seeing the clock .....are you sure it isn't something as simple as the hands ( arms) detaching from the centre spindle which continues to turn but without the hands. Alternatively have the hands become stuck on something on the clock face or become intertwined themselves ? Very simplistic but all I have to offer...
Feb 24, 2015 | Watches
How do i reset the chimes for a Strausbourg Manor Quartz Movement wall clock? and what is the magnet for?
Try removing the batteries. Set clock to 5:45. Reinsert the batteries, and set to 6:00. it may take an hour for the clock to sync., but it should do the trick. The only thing I can think of for the magnet would be that it may have fallen out of the pendulum swinger where your pendulum hangs. Hope this helps. Good Luck.
Nov 07, 2014 | Home
Chimes do not work
Check for loose wires between the clock Movement and the chime box. If those are good (and the batteries have good solid connection-not lose) you probably need to replace the chime control box or the whole movement.
Timesavers.com carries replacements.
Mechanical clocks, while more in cost, will live a much longer life with proper care than battery clocks. Plus, an actual chime (not noise through a speaker) is much more pleasing to the ears.
Jan 11, 2014 | Seiko Mantel Clock
Rate me, please.
Jul 29, 2009 | Seiko Mantel Clock
Syncronize chime strokes to clock
The next time it chimes multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it chimes signaling 15 minutes after. Now put the minute hand back on pointing to 3 o'clock and replace your dial nut and you are all set.
Fix Clock That Gongs Wrong
May 26, 2009 | Seiko Mantel Clock
Salton Chiming Wall Clock is chiming inconsistently
yes .
check volume setting.
if you have a manuval volume control try to clean inside of volumecontrol.if ok fine
or
if not ok Replace volume control with same type( new one.).
Nov 10, 2008 | SkyScan 86709 Atomic Wall Clock
Home Logo
32 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
