Question about Radio Communications
Can you program a icom f3011 for marine band channel 14. I have this radio just sitting in the closet and could be using it
  • Bobby Horsley Dec 27, 2016
    Will I have to buy program disc and cables to do this or is there a place I can send it for someone to put it on the radio
    Master:
  • Radio Commun... Master
  • 541 Answers
156.700 does not seem to have power limits. This is for the USA?
I think you can do it legally. Without opening up the software, there is a good chance.
Posted on Dec 27, 2016
SOURCE: icom IC-F1020 and icom ic-f3
cqham.ru
Posted on Apr 13, 2008
  • 3 Answers
SOURCE: Programming an ICOM F4S
Hi....
if you go to the FCC website and look up the FRS/GMRS info you will find a listing to links that can show you the frequiences for the two radio services...or you can look up Midland model GXT900/950 /series radios and in their specifications gives a frequency chart. the link is WWW.midlandradio.com
Posted on Mar 17, 2009
SOURCE: memory program ch no# on icom u or h16
I had the same problem. I solved it by going into program mode, then while holding down the function key, input one of the missing channel numbers. The channel should appear but is flashing. Now input a frequency for the channel and exit program mode. Repeat the sequence for the other missing channels. This procedure worked for me. Good luck.
Posted on Apr 09, 2009
  • 67 Answers
SOURCE: Trying to convert marine radio to ham band ? Cybernet CTX 1200
big shuift 156 MHz to 144 MHz !!
Posted on Jul 28, 2009
  • 12 Answers
SOURCE: ICOM IC-F21 (400-430MHz): Programming problem
When programming the radios the green light will flash when uploading or downloading data. The red light flashes when the battery is low. Maybe they are happening at the same time. As for the error message I would need to know what it said. Carl
Posted on Sep 14, 2009
Icom f3011 range diminished
Are the batteries old an need replacement? Have tried another antenna, many times they break the center conductor inside from being bent over? Have you went into the menu an checked the power setting? My guess is antenna, but many other things could be at fault
Mar 25, 2014 | Icom Ic-f3011, F3013, F4011, F4013 Manual,...
How to connect sb-200 to ic-7600
you really need a amp keyer interface, these new radios are voltage sensitive, I use ameritrons http://www.ameritron.com/Product.php?productid=ARB-704
Nov 19, 2013 | Icom Ic-A110 - VHF Air Band Transceiver...
Radio not receiving on any channel
Hi Mike,
The manual for this radio (in Adobe .pdf format) is available for download directly from Icom America, free of charges.
Since the "AquaQuake" function works and you do hear static when the squelch is off, that is sufficient to let us know that the voice coil of the speaker is functional and should produce sounds with the right signal applied.
The first thing to determine is if you're close enough to another operating transmitter for the radio to receive a signal. One of the 10 weather channels the radio is capable of tuning should be close enough produce some intelligible audio from the speaker - assuming the squelch setting isn't set too high.
If a WX channel works, then you'll need to see if there's a VHF Marine band transmitter operating nearby. You might need to set another Marine band radio receiver up to verify that there is indeed a signal present on the particular Marine band channel that you're monitoring. A list of frequencies is published on pg 27 (of the manual linked above) in case you need to convert between channel and frequency to tune on a non-channelized radio.
Outside of that, there's little the end user can do without specialized test equipment, schematics and of course, training. Many shops will be happy to provide an estimate for repair when provided with a small bench diagnostic fee. This fee is usually applied towards an authorized repair by most reputable repair shops.
I hope this helps & good luck!
Nov 27, 2012 | Icom Ic-m34 Vhf Waterproof Marine Two-way...
Windows 7 validation
go to control panel & install it under "install older program" & chose admin when prompted
Oct 25, 2012 | Icom CS-F3011 Programming Software v1.2
Can this radio communicate with cb channels?
hello unfortunetly not as these radios are resonating on the marine band which is vhf high band cb band is resonating on 27mhz ,marine band 157mhz so will not work .
Apr 02, 2011 | Standard Horizon HX471S (824 Channels)...
Ihave an old icom icm- 55 marine radio what ariel do i need and do i need to swr the ariel will a cb ariel work basically what do i need to do to get it working
All marine VHF radios must be licensed. A marine radio station must also have a call-sign allocated to the vessel it is installed in. Shore based stations can also be licensed but only where they are involved in marine based activities e.g Yacht Clubs, Marinas, Harbour Masters, Rescue Services etc.
In the UK ships radio licences can be obtained from Ofcom. They are free for non-commercial users.
The user must also have a Marine VHF Radio operators certificate. This requires taking an exam. In the UK contact the Royal Yachting Association for a copy of the syllabus and local examiners.
More information about the licensing rules, courses and exams can be found here. http://www.rya.org.uk/infoadvice/regssafety/Pages/licensingelec.aspx
The ICOM ICM55 is a good radio set and can still be used in an existing (marine) installation but it does not meet the standards for new installations as it does not have DSC (digital selective calling) capabilities - which all new fixed sets must now have. It is therefore very unlikely that you will be able to get a licence to install one.
To get it working you will need a proper marine band VHF aerial which operates in the frequency range 156-MHz. They usually come with cable attached but if a longer cable is needed, or the aerial is not cabled in the first place, use flexible 75 ohm co-axial cable with a copper core and braid/foil screen. Use proper aerial connectors (type F or BC are most commonly used and can be obtained from most good electronic component suppliers more cheaply than from a boat chandlers. Do not use push-fit TV aerial plugs)
Citizens Band radio works on the much lower frequency MHz band and therefore a CB aerial will not work with a marine VHF radio set. Please see this Wikipedia article for more information http://en.wikipedia.org/wiki/Marine_VHF_radio
Jan 28, 2011 | ICOM Informatique IC-F420-55 UHF...
Radio turns on , channels change, but no sound or squelch..
It sounds like your vhf speaker has failed. I recommend taking your radio to a repair shop and replacing the speaker...this should solve your problem.
Jun 16, 2010 | Icom ICM422 FixedMount Marine VHF Radio...
I have an icom m304marine vhf with a shakespeare
Sound like you have an antenna issue. Try a different antenna with coax. If the problem is still there, than you have a problem with the radio. Icom makes really good marine radios but you could have a defective one.
Jun 30, 2009 | Cobra Mr F75b Marine Vhf Radio Fixed Mount...
What's the channel frequencies for a common 22 channel motorola 2 way vhf radio?
Not sure what you want.....VHF band ius approximatly 130mhz to 175 mhz..... in that VHF band there is a commercial VHF band aprox. 155 mhz to 175...... the amateur radio vhf band is aprox. 135 to 150mhz.
With amateur radio, any freq in that range can be used...... with commercial radio the FCC cangive a company any freq. in that range also.
If you are looking for FRS/GMRS frequencies they are UHF freqs not VHF.
So I'm not sure exactly what you want......sounds like you might want to program in FRS freqs into an Icom amateur radio. If thats  the case you will need an Icom that will do UHF freqs.
Oct 12, 2007 | Unwired UFR650 (14 Channels) 2-Way Radio
Radio Communications Logo
65 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
