The screen opens black and have a text set up is starting services
    Top Expert:
  • Televison & ... Master
  • 75,025 Answers
If you wish to get some details; visit the site linked here. Pull up older posts.
Posted on Dec 26, 2016
Black square on screen
Look both in the set's menu and that of a box if used; Under closed captions in either place look for a setting labeled TEXT, that is what is bringing up the black box, feature never really used much, find TEXT in either set menu or box menu if you use one, either place can cause this, not a problem just the text feature is on. Turn it off with the remote.
Dec 14, 2012 | LG 60PK540 Plasma TV
What is the command prompt for factory settings
Command prompt is a non-graphical (DOS-like) screen and is mainly text-based.
Think about the old computers.
A command prompt can be opened in Windows, when touching the start-button(Left bottom corner), next selectng "Run" and type either "cmd" or "command" (without the quotation-marks) and push the ENTER-buton.
When performed correctly, you should see a menu to pop-up with a black screen and white text.
If you're not familiar with this command prompt, don't go for it.
It's like the operating system of the old computers, or you can think of when there was no Windows (*). This is purely text-based.
Aug 27, 2011 | Shuttle XPC SD32G2 Barebone
After being on a few minutes, the text becomes very blurry I lowered the resolution, which makes the text bigger and helps some. There is an internal adjustment, but I don't know where??
Hi hamptonwhh,
Screen resolution refers to the clarity of the text and images on your screen. At higher resolutions, items appear sharper. They also appear smaller, so more items fit on the screen. At lower resolutions, fewer items fit on the screen, but they are larger and easier to see. At very low resolutions, however, images might have jagged edges. Please follow the steps below on how to adjust your screen resolution.
Windows XP
1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
2. On the Settings tab, under Screen resolution, drag the slider, and then click Apply.
3. When prompted to apply the settings, click OK. Your screen will turn black for a moment.
4. Once your screen resolution changes, you have 15 seconds to confirm the change. Click Yes to confirm the change; click No or do nothing to revert to your previous setting.
Windows Vista/7
1. Open Display Settings by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Display Settings.
2. Under Resolution, move the slider to the resolution you want, and then click Apply.
Notes : When you change the screen resolution, it affects all users who log on to the computer.
When you set your monitor to a screen resolution that it won't support, the screen will go black for a few seconds while the monitor reverts back to the original resolution.
Hope it helps.
Thank you for using FixYa.
Jul 04, 2011 | MPC Computers Envision EN 775e 17 in.CRT...
How to I improve the contrast. Black text tends to be too grey; and the light blue text tends to be too 'white'. I am straining my eyes, often, especially when I use Picasa in Google. I have either lost,...
Change the “Contrast, on the Monitor:” Part (1) Right click on an empty area of your Desktop Screen, next click Personalize to open. Open the “Window Color and Appearance,” in the Color Scheme category, choose a “contrast settings.” Note: After making all changes to the Display settings, click on the Apply and Ok buttons to complete the adjustments, and restart the computer to finalize changes to take effect correctly. To "Fix" the (Resolution), click Display Settings; follow these steps: Adjust "resolution.” Click, Advanced Settings, select Properties, click on Drivers, “select to” Update Drivers; click “OK!” Part (2) To start, right click on Desktop screen, at the (top) of the menu, check see if the Graphic ™ Control Center is visibly present? If so, click to open; you can adjust the Graphic Settings. Click “OK” when finished!
Feb 16, 2010 | Computers & Internet
On our tv screen is a big black square on the bottom of the screen we dont have the orignal tv remote
It sounds like the set has been put into the text mode. This setting is in the CC or closed caption section of the menu. You should be able to access this with the menu button on the front of the set. Turn it off when you get to that section of the menu. This black box is where the "text" for CC would normally be written if your cable service provided it. Thanks
Nov 01, 2009 | Toshiba 36A50 36" TV
My blackberry will not let me click on anything
Usually the button membrane under the track ball goes bad. If you're out of warranty try to remove the trackball and push the membrane back in place, clean it if necessary. There is a Blackberry Repair Guide that shows how to open a Blackberry and remove the track ball yourself. Once it is open it's as easy as peeling the membrane off the logic board, scratching its bottom with a flathead screwdriver. There are also third party blackberry repair services that will do this for you.
Mar 30, 2009 | AT&T Blackberry Curve 8300 Smartphone
Blank screen
Goto settings & tools, then goto display setting, then brightness.
Then goto messaging and then setting and then callback #
Dec 30, 2008 | Motorola Mobility MOTO W755 Cellular Phone
Predictive text
Aswer is in the instructions, you can download off the internet.
1) Go to text entry screen (txt message screen)
2) Push the _ button at the very top middle of your phone.
3) The Message menu will open, go to Entry Setup and set your Primary Setup to TAP English.
This will fix your problem, I set my secondary Setup to Tap Extended.
I have just done this and have not given it a major examination, but I can send text messages now without any bother.
Sep 21, 2007 | Motorola Mobility PEBL U6 Cellular Phone
TP50H50 Black Box on screen
you may have the set in text mode (part of the closed caption menu)
Feb 07, 2007 | Toshiba TP50H50 50" Rear Projection...
Printing black
Sounds very science fiction. The easiest thing to do is to uninstall the printer(+drivers), and reinstall. Or at least it's the easiest thing for me to think of ... ;] Do you get this only with text, or also with images?
Jun 21, 2006 | HP OfficeJet d145 InkJet Printer
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
