Question about Cell Phones
Hi my home and back buttons on my oukitel k6000 have stopped working help
How can i upload pictures from my oukitel u20plus phone to my laptop? when I plug in usb it charges but does not give me the option to upload pictures.
You should have a notice on the home screen that says USB connection, click on that and you should then have 3 options, change the current option from charge only to MTP to transfer files. If you have no options on your home screen then you will need to open all apps and scroll to your settings app, open that and scroll to the storage option and choose USB connection and make the MTP your choice. If you are unable to find the option as described above then you have to turn on USB Debugging by going into settings, scroll to the bottom tab " about phone" click on software tab and find build number , click on that about 10 times and you should see a message that says you are ? 4,3,2,1, away from developer, and when the message goes away, press the back button and you should have a new option under settings which is entitled "developer options" click that and select USB debugging and a message will pop up to confirm, press OK and now you should be able to transfer files or have option on the home screen to change your selection to MTP from charge only.
Sep 19, 2017 | Cell Phones
APPLICATION HOME HAS STOPPED
More information is needed to solve your issues..Ty
But in the mean time this may help.
Double click the Home button, & Swipe up.
This would close the application...Thus resetting it.
If not, switch the phone off & then back on again.
Hope this helps.
Mar 18, 2015 | Apple iPhone 5S
Help!! Bought a leappad 2 for my daughter was working fine one min then the next it stopped working and the screen won't turn on we have had it on charge the lights comes on them goes off we can only get...
Hi Jemma, Can you try this procedure:
hold down the "Power" and "Home" buttons at the same time for 10 seconds, then releasing both buttons. Wait for a second and then press the "Power" button.
Hopefully this will work!
Jan 01, 2015 | Cell Phones
Hi, guys my LG Home theater 357 stopped working, there is no more out put from the speakers and the eject button no longer respond just over night. pls i need help...
I think if you configure everything from software and check out everything i.e. plug in, plug out cord. If everything is okay then the problem is hardware/device. As a result, you need to go to repair center. Thanks
Dec 14, 2014 | LG Audio Players & Recorders
Hi there. I have a Samsung HT-D4500 home blu-ray system. It has been working perfectly and bang just stopped working. I have replaced the fuses and the changed the plug and still no joy. I am wondering if...
Have you tried resetting it? Take any disc out, unplug power, press stop button and plug power in. Wait 8 seconds and release stop button. If that does not work, it sounds like a transformer issue.
Oct 29, 2013 | Samsung HTD4500 Theater System
Iphone 4 menu button not responding It will work for a day then all of a sudden stop functioning until I hook it to the computer. Any ideas?
Hi
iphone menu(home) button have pin type connection so sometime when we press it hardly.pin stop making contact. you may have to replace home button.
thank you.
Sep 04, 2011 | Apple iPhone 4 Black Smartphone
How to pair the samsung wep450 with another cell phone
samsung wep450 bluetooth headset
This device is connected all mob. device and all androids,
How To Connect: You Need first power off and after 5 sec. Power on button press 10 sec. continue, and this time search or refresh your mobile Bluetooth . and Connect .
Nov 21, 2010 | Samsung WEP450 Bluetooth Headset - Retail...
HI,my iphone got stuck in DFU mode and have no clue how to get it back....please HELP!!!!!!!!
Hold Home button and Start/Stop for 30-60 seconds and the iPhone should reboot (show the Apple logo). Let go of both buttons then.
OR...
Run quickpwn, it will detect your phone and ask you to hold home and power buttons for 15 seconds. Then release the buttons, press power button again for 2 seconds and it should be working after this.
Mar 20, 2010 | Apple iPhone Smartphone
Help!
i have the exact same camera as you..
i had the exact same problem as you did too..i got so mad
this worked for me, so i think it will work for you
1.take the batteries out of the camera
2.hold the power button for 30 seconds
3.let go of the power button, and wait 1 minute
4.stick the batteries back in
5.turn the power on, and it should stop acting crazy
if this helped, great
Oct 04, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Cell Phones Logo
69 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
