Brivis ducted heating & refrig air. No zones appear on Networker controller. Want to use cooling. Last summer we had zones A & B for cooling, so it is definitely zoned. How can we reset for cooling?
2 Suggested Answers
  • 117 Answers
SOURCE: Zone cooling not delivering adequate air to both zones simultaneo
You need to have someone evaluate the ductwork for the home. With all zones calling, there should be an even balance of airflow. And when only one zone is calling, there should not be the tornado effect you describe.
The dampers feeding each zone may be of the wrong size. It also sounds as though you are also having a problem with your bypass damper. This damper is designed to bypass excess air when only one zone is calling. It is operated typically off the airflow alone.
Have it check out. You definitely have a problem. I would recommend getting it looked at by a company other than the installing company to remove any bias judgment or diagnosis.
Posted on Aug 01, 2010
I have the temp set at 77 in zone 3, (have 4 zones), but temp is 73 with the ac dumping cold air in the zone. how do I fix this?
It's possible that your "slave controller" is malfunctioning. There are 4 thermostats, 1 master & 3 slave controllers(not slang but actually what they call them and I don't know why). The #3 that shows 73° actual temp, and set at 77°, is probably malfunctioning. Remove the R or Y wire inside the #3 t-stat and see if the airflow stops "dumping" in that area. Also possible that the damper controller in the duct has malfunctioned. This will take some experience to know what to do, not easy to explain.
Aug 22, 2017 | Heating & Cooling
Zone control
reset the zone system and see if it still flashes
May 23, 2014 | Fujitsu Heating & Cooling
Brivis ducted Heater won't get above 19 degrees ,
could be broken ducting letting hot air escape or on the intake side drawing too much outside air in. could be the fan unit not pushing enough air
Jul 26, 2013 | Cars & Trucks
Had a power outage a while ago for 24hrs, so I went around and turned everything off and once the power came back on I went and turn the heating back on at the mains switch. Now it is coming up with...
Pull the controller off the wall, press 3+5 buttons down, then replace on wall while still pushing buttons in.... a group of 5-6 bars will appear, then when it says type in address -turn dial to 1. this will re set it.
Dec 24, 2010 | Heating & Cooling
Brivis Buffalo 85 ducted heating unit, fan is always on
On the unit outside there is a button that says "push man. pull auto" if it is set to push man then the fan will go constantly.
Sep 22, 2009 | Heating & Cooling
Zoning not programmed
Hi ill be honest this is a little tricky
There are many variations depending on a few things.
Is it heating only or add on refrig as well?
Is there a common zone or an area constantly open?
How many networker controls 1 or 2
So any way this is the set up for heating only 2 zones and common zone.
Turn the networker wall control off
in the off screen press the clock key (the time will flash)
hold down the 2 & 4 keys for about 5 seconds
depending on the model and what other appliances are lincked to it it will display either
H01 ID01 1500 (NC3 2004 onward)
1500 01 H01 (NC1&2 pre 2004)
press the (M or mode) button till you get to the N1 parameters eg N1 ID01 01
press the number 1 key or on older models top key
should then display should read
N01 ID15 01(COMMON ZONE)
Then using the dial to change the setting to read the same as below once done press the number 1 key or top key to advance to the next setting
N01 ID16 01(NETWORKER NUMBER)
N01 ID17 01(ZONE A)
N01 ID18 01(RELAY NUMBER ZONE 1)
N01 ID19 01(NETWORKER NUMBER)
N01 ID20 02(RELAY NUMBER ZONE 2)
N01 ID21 01(NEWORKER NUMBER)
then press the number 1 key followed by the on off button then, provided its all been installed correctly zones should appear and operate :-) good luck and i hope this helps.
May 18, 2009 | House Brand Heating&Air Conditioning...
Brivis central heating fan will not switch off runs continuous
brivis wombat 2P 20 ducted heater, gas fires up but fan not starting
Any suggestions...???
May 12, 2009 | Heating & Cooling
Goodman with 2 thermostats, freezes in summer, no heat in winter
is the system zoned? if so maybe the zoning control board to the damper motor is wired improperly. when a system freezez its because of 1- restricted air flow across coil, (maybe dirty filter) or 2-low refrigerant charge. again could depend on how its zoned.
Feb 16, 2009 | Goodman PHKJ048-1 Air Conditioner
Vulcan-Bonaire : summer breeze
This unit is a cooling unit only. I don't know what switch you are looking at but I don't think it's for the evap. cooler(swamp cooler). I am in the Phoenix, Arizona area and it's very common to have a evap. cooler and a seperate heat/cool system as on the hottest days the evap. cooler doesn't cool enough. I hope this helps. Please give me a positive rating. Thank you.
Jan 27, 2009 | Mastercool 67471 Evaporative Cooler Air...
Heat on bottom floor no heat on top floor
pretty vague, but i'll give it a shot. i assume that your upper and lower floors are heated by the same unit. of course if your not sure you better check to see if there is a second t stat for up stairs in case there is a second unit that heats it. there may also be a zoning system that seals off upstairs ducts unless the zone stat for that area is calling for heat. so look for a second stat upstairs if you think it may be zoned. now to you original question. lets assume the unit is not zoned and only one unit heats both. then you may have a mechanical damper in the ductwork ,usually located close to the indoor blower that shifts to force more air upstairs in summer and more air downstairs in winter, these can usually be shifted as needed to control air to upper lower and are usually marked upstairs dornstairs etc. if you have no dampers etc, then you have reason to suspect the ductwork has come apart or been crushed before it gets upstairs. you'll have to go up or under the house etc and try to find duct problems.good luck
Oct 28, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
