Question about Refrigerators
Hi, have a waeco cf60 as soon as the ambient temp gets above 35c fridge flashes error code and turns off, i suspect fridge is overheating but why now, fridge has worked fine for years until now,Thanks
  • 139 Answers
SOURCE: i have a raypak heater. when i turn it on it heats
could be a plugged heat exchanger due to insufficient gas pressure at manifold
Posted on Jun 21, 2009
  • 35 Answers
SOURCE: FRS26ZSE fridge too warm, but freezer works fine.
it is either froze up you can tell if you look at the back panel if dont see any thing you can remove it but make sure the fan is running before you remove the panel if it isnt the motor is bad it is get a volt meter and find the wires to the heater and unplug them you should beep if it dont the heater is bad if it does the deforst timer is bad
Posted on Jul 23, 2009
  • 653 Answers
SOURCE: error code CF60
Try check the cleaner unit of process unit whether it is full of toner that resulting the recycle toner transport area is locked thus CF60 sign on.
Posted on Sep 15, 2009
  • 2926 Answers
SOURCE: 2006 dodge charger 3.5 high
The thermostat should have been replaced during the radiator install and would have been easier to do since the engine coolant was already drained. If the water pump is not showing any signs of leaking, it is most likely ok at this point. I would do the easiest step, that being the thermostat.
Also verify the cooling fan is operating and running during high temperature. Don't run the engine too hot too many times.
Posted on Nov 21, 2010
  • 5370 Answers
SOURCE: 2001 Tahoe LT 5.3.
There's a feed from the engine coolant temperature sensor into the AC controller as if the controller thinks the engine is overheating it'll shut down the AC to reduce the load on the cooling system
Try unplugging the cooling sensor on the engine ( follow the radiator top hose back to the engine as the sensor is close to this) and see if this replicates the problem, if it does then you know thats the issue.so the coolant temperature sensor needs to be replaced.
Also the possibility is faulty evaporator temp sensor.It may be sending a false signal to the climate control module that the evap is around freezing temperature thus shutting down the compressor. The evaporator temp sensor is located on the evaporator housing, in the a/c system, and monitors the temp to prevent the evaporator from freezing up. If the AC control module sees the temp going too low, it will send a communication message to the pcm to turn off the a/c compressor until the evap temp returns to an acceptable range. The other possibility is the high pressure switch located on the line in the right hand side whell arch. Why I mentioned the high pressure switch because as the temp increases the pressure in the system increases and if the ECU sees this signal from that pressure switch in the wheel well on the a/c line it will shut down the compressor. You can test this with a digital voltmeter or install a set of gauges to the high and low side service ports and see where the pressure go. It also may be the temp sensor element on the compressor itself. ----------- This should help.Thanks.Helpmech.
Posted on May 29, 2011
Hw do i remove error code E4
E4: Indicates lack of refrigerant, or the compressor is not running, or the thermistor is out of
calibration.
Action: Check that the compressor is running by listening.
If it is apparent that the compressor is running, then check the
temperature difference across the evaporator.
i.e. Measure temperature of return air at inlet filters and
measure temp. of discharge air at grilles. This temp diff.
should be 14 to 18 C. with fan on hi speed. If temp diff. is less than this,
suspect lack of refrigerant.
Fit a suction gauge to access valve at rear of unit. See fig 12. On a 35C
outside temp. then suction should be 380 to 450Kpa.
Good luck
Feb 14, 2015 | Heating & Cooling
During cold weather the fridge in my cabin stops working... anyone know why?
nearly all fridges are made for domestic kitchen environments,where the ambient temp is around +10C to +35C,so anything colder/hotter and the gas/system used is not able to extract the latent heat out of the interior of the fridge and dissipate it to the exterior.you may need to buy a garage conversion for your particular unit.(these units are NOT available in the U.K.where i live,but im informed ARE available for the American/Canadian market)......in other words if you warm up the room its in, it will work fine.
Nov 15, 2010 | Amana Refrigerators
Can this GE TFX side by side be used as an extra frig in a garage that gets very hot in summer
most (not all) f/f can be used in ambient temps from about +5C to +35C,but use a seperate thermometer to keep the interior temps at +5C for a fridge and -18C for a freezer.
Oct 31, 2010 | GE GSH22JFR Side by Side Refrigerator
Error code CF60
Mar 12, 2009 | Toshiba e-Studio 350 Copier
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
