Question about Fisher and Paykel Washing Machines
What happen if my fisher and paykel washing machine start briefly and stop and start beeping
  • Fisher and P... Expert
  • 164 Answers
Fault code 130. On top of the motor stator (the copper winding) is mounted an electronic signalling device called a rotor position sensor. It sends 3 signals back to the main control board to tell it if motor is running correctly and also to aid it to start. Your RPS is faulty and sending the occasional error signal. Usually caused by corrosion. You need to get a new RPS fitted.
Posted on Dec 26, 2016
  • 2651 Answers
SOURCE: paykel fisher wash problem
its possible, depending on problem with unit, if youd like you can acess a tech sheet behind the console,theres a pretty good desription of common troubles encountered and fix it solutions.
Posted on Feb 27, 2008
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Posted on Aug 03, 2009
  • 71 Answers
SOURCE: my fisher and paykel top loader washing
Disconnect the washer for few minutes (5min) then connect it again and press cancel, before you start any cycle, good luck
Posted on Jan 06, 2010
  • 3 Answers
SOURCE: fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Posted on Feb 20, 2010
  • 4 Answers
SOURCE: fisher and paykel intuitive washing machine not spinning
to remove the pump - remove power pins. Press bayonet clip in [lhs of pump base. Twist anti clockwise. Remove blockage. Rub a smear of Vaseline on seal before re assembly
Posted on Mar 07, 2010
After starting briefly, why did it suddenly stop?
I know it is an old post but this will help the fault code lights 1 and 7
130. (10000010) Phase 1 to 6 - Single Rotor Position
Sensor Error
The Motor Control Module has found an error in the pattern received
from the Rotor Position Sensor. Likely causes of this fault are a bad
connection on the harness between the Rotor Position Sensor and the Motor Control Module, or a faulty Rotor Position Sensor.
Watch this video if you are good with fixing things
Fisher and Paykel 130 10000010 Error Code Fix
Jun 06, 2015 | Fisher and Paykel Washing Machines
What does it mean when my fisher and paykel washing machine stops mid wash cycle and starts beeping the lights that show up are 2 and 7 it's a gw611 model
I would normally say a clothes balance issue but if its happening all the time. u may have an issue with the counter balance weights or rods depending on ur type of appliance. If they go bad they tend to shut down applaince mid cycle after some amount of movement or shaking. and what happen is it contantly throw machine into unbalance position
Nov 07, 2014 | Fisher and Paykel Washing Machines
I have a Fisher and Paykel Smartdrive 9 washing machine that won't fill. It starts then stops and continues to do so, then stops altogether and beeps. Can anyone help??
The error code is displayed when its beeping.
I don't know the error code, so It can only be three things,
Out of balance switch,Lid magnetic reed switch,Or Rotor position sensor,Your error code would help me work out witch one of these are faulty. to work out your error code look at picture below.
Add up the lights that are on.
Jan 08, 2013 | Fisher and Paykel Washing Machines
Starts and stops
A failed inlet valve is not uncommon in F&P machines. The hot valve is different to the cold one, so don't exchange them. Not a big job for a tech to do in-laundry. Good luck....Nomess
Jun 11, 2010 | Fisher and Paykel Fisher & Paykel Washer
Washing machine starts and stops
Above is your service manual and a circuit diagram, Simply use the troubleshooting steps and you will soon isolate your issue and effect a repair.
May 29, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel 6.5 smart drive washer
My F & Paykel washer did this. There was a baby sock under the wash basin. I called for repairman and he found the problem.
Jan 05, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
66 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
