Question about Home
I have a Thetford C400. Have fitted a SOG vent system and now I can only flush with Flap shut.
Have changed over the wires thinking that would do it but no. Fan runs fine when I open the flap and shuts off when shut. Our toilet water is feed from the main water pump of the Van. Can you hell? Cheers les
erpaalai
  • 999 Answers
SOURCE: When it is windy outside the flap on my exhaust
Not likely, Just a condition of the location of the vent and the wind direction.Putting a secondary larger hood over the outside exposure will sometimes help alleviate this.
Eric
Posted on Oct 13, 2009
shastalaker7
  • 1515 Answers
SOURCE: My toilet flushes inconsistenly. one time it goes
I have worked on these for many years. The flapper that's attached to the chain and handle, sometimes drops to soon before the tank gets to fill up enough to flush completely. If the flapper has not been changed for some time, it would be a good time now. I wouldn't change out the toilet unless it is cracked. This is a well made one, and I would want to keep it.
Posted on Nov 24, 2009
  • 290 Answers
SOURCE: 99 jeep cherokee problem w/ heat
It could be a flap but more likely you have a air trapped in the heater core or the hoses connecting the heater core when refilled the system after your repair.
Loosen the supply hose that go to the heater core at the highest point and run engine until coolant comes out.
Posted on Jan 05, 2010
  • 150 Answers
SOURCE: Toilet flushing problem!
The siphon mechanism works on a vacuum principle. If there is the slightest damage to the siphon membrane you will experience the problem you describe. A new siphon is required.
Posted on Jan 20, 2010
SOURCE: soap dispenser flap not opening
Not a solution but exactly the same problem. I should have sent the machine back (I bought mine about 2008 too) but by now, 2010, the machine is a complete waste of time and money. The soap dispenser fails to open every time, wasting money, water and my patience because I then have to hand wash after all. will try the suggested oil trick, but it was obviously a bad design to start with.
Posted on Jul 26, 2010
My Thetford Silence 12 volt. Tecma toilet flushes ok but builds up pressure in the holding tank stopping it of flushing.
check that if there is a solenoid operated vent valve that that section is working to allow venting during the flushing process
Jun 05, 2017 | Home
Why does the flap close before water flushes
the flapper is pushed down too far on the vent tube. leave about 1/2 inch of space between the bottom of the flapper flange when you seat it over the vent tube. make sure the flapper is level. if the flapper is too close to the bottom of the vent tube, it will slam shut before the flush is finished.
Jul 24, 2014 | Fluidmaster Duo Flush Toilet Kit
Thetford porta potti not flushing. Can anybody advise me what i can do to correct this.
Check the bellows has no cracks and that the top rinse tank is full of water & rinse solution.
Apr 13, 2014 | Thetford Porta Potti
Our electric flush toilet growls when the flap is being open and when it closes
Growl is the masticator chewing up solids. There is no flap so to speak, but a pump carrying waste to holding tank. Sound is normal.
Sep 02, 2012 | Thetford Porta Potti
Manual for 1992 Fiamma porta potti
Sorry, don't mean to be pedantic but Fiamma is just a potti not a Thetford Porta Potti. (TM)
I only have experience with Thetford.
Nov 07, 2011 | Thetford Porta Potti
I have no heat in my 2002 jaguar s type. had new thermostat put in at beginning of summer, new coolant resivior and system flushed. hadn't needed heat till now. also fan continues to run for about 3-5...
likely to be paddle flap motor died, they used to be manual, so the vent is letting in cool air only, the flap changes position for the heat to enter, the flap on yours is not moving, so likely to be the motor
Mar 06, 2018 | Jaguar S-Type Cars & Trucks
Toilet won't flush. New pump fitted fuses ok.
Thetford Model Cass C2 L TC WHI - Toilet won't flush. There is power to the switch and flasher. Any ideas?
Jul 30, 2009 | Thetford Porta Potti
Im trying to find the wiring am for a thetford C2 porto potti
Go to www.thetford.com.
Click Customer Support then Product manuals and download manual in PDF format.
Wiring of C2 has fuse, safety switch, flush switch and flush pump in series. If fuse is blown you probably need to replace pump. Instructions come with replacement pump.
Jun 04, 2009 | Thetford Porta Potti
Dryer's vent hose Problem
Wait for the dryer to cool. Unplug the vent hose and inspect its entire length for snags in the pipe. Make sure the vent is not obstructed on the outside wall, and fit a flap or screen to keep out small animals. If your vent pipe is punctured or damaged, you should replace it.
Aug 27, 2008 | Elements of Design DS492 1/2" Inlet Copper...
Home Logo
47 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
