What is the code 10000010 - Washing Machines
What happen if my fisher and paykel washing machine start briefly and stop and start beeping
Fault code 130. On top of the motor stator (the copper winding) is mounted an electronic signalling device called a rotor position sensor. It sends 3 signals back to the main control board to tell it if motor is running correctly and also to aid it to start. Your RPS is faulty and sending the occasional error signal. Usually caused by corrosion. You need to get a new RPS fitted.
Dec 25, 2016 | Fisher and Paykel Washing Machines
What is fault code 130 and how do I fixit?
130 indicates a faulty Rotor Position Sensor (RPS) or a bad connection to the RPS. This can be a common fault on all Smart Drives. Rather than explain the the procedure you can watch this video which a kiwi guy has done on how to fix it if you are good with that sort of thing. IF you live in NZ the best deal to get a new RPS is Rotorua Appliances or search TradeMe for RPS. To watch the video click the link. Good luck https://www.youtube.com/watch?v=6FQc64aBzc0 Fisher and Paykel 130 10000010 Error Code Fix
Jun 22, 2015 | Fisher and Paykel GWL11 Top Load Washer
After starting briefly, why did it suddenly stop?
I know it is an old post but this will help the fault code lights 1 and 7
130. (10000010) Phase 1 to 6 - Single Rotor Position
Sensor Error
The Motor Control Module has found an error in the pattern received
from the Rotor Position Sensor. Likely causes of this fault are a bad
connection on the harness between the Rotor Position Sensor and the Motor Control Module, or a faulty Rotor Position Sensor.
Watch this video if you are good with fixing things
Jun 06, 2015 | Fisher and Paykel Washing Machines
Fault code 130
130. (10000010) Single Rotor Position Sensor Error
The Motor Control Module has found an error in the pattern received from the Rotor Position Sensor.
Likely causes of this fault are a bad connection on the harness between the Rotor Position Sensor and the Motor Control Module,
Primary Source: Wiring.
Action: Check for corrosion on the RAST connector of the Rotor Position Sensor and the Motor Control Module connector.
Secondary Source: Rotor Position Sensor.
Action: Check the Rotor Position Sensor with an R.P.S. tester. Replace if faulty.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
Quaternary Source: Rotor
Action: Ensure the correct rotor for this phase of machine has been fitted.
Mar 14, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
Error code 130
Position Sensor. Likely causes of this fault are a bad connection on the harness between
faulty.
Aug 11, 2012 | Fisher and Paykel IWL12 Top Load Washer
Error code 130
faulty.
Action: Ensure the correct rotor for this phase of machine has been fittedc61fd2ce-cf94-4234-8679-0e9d4724bed7.jpg
Jun 23, 2012 | Fisher and Paykel Washing Machines
What is a code 240 and a code 130
240. (11110000) Hall Out Of Order. RPS Fault
Same as previous Hall Error faults See fault code130 for directions.
faulty.
Jun 03, 2012 | Fisher and Paykel Washing Machines
What is code 240
faulty.
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
