Question about Vacuums
The button on handle to engage the roller brush is not activating the roller brush
  • 1673 Answers
SOURCE: The roller brush will not stay on-& the cord rewind is stuck on
There is a reset on the power head, does the wand fit tight in the neck of the power head, if not you may have a problem there, either the wand or the neck. If the lever is stuck on, then it is jammed or broke, maybe a spring is out of place, in any event the canister will have to be taken apart to see what the problem is.
Posted on Feb 20, 2008
  • 25 Answers
Posted on Mar 31, 2008
  • 281 Answers
SOURCE: Kenmore progressive bagless brush roller won't turn
belts broke need to replace but before you put the new belt on clean the motor shaft ,broken bels usually leave burnt rubber on the motor shaft.,if you don't clean the shaft the new belt won't last long
Posted on Apr 10, 2009
  • 59 Answers
SOURCE: Roller brush will not move when vaccum is turned on
maybe the belt is broken. clean the unit and replace the belt.
Posted on May 23, 2009
SOURCE: My eureka 5902 4D bagless uprights roller brush
The same thing happened to me about a year ago with this very model.
The issue on mine was a small, copper-colored metal wheel that attaches to the end of the brush roller. You'll need to remove the top cover (there are several screws).
Once it's off, you should see the belt, the beater brush, and the metal gear. The gear didn't fit correctly - so the motor just spins without moving the brush. I ended up going to the store and buying superglue that withstands high tempuratures, then gluing the gear to the motor's shaft... and hammering the thing into place before the glue 'set' too much. ...Not fun, but it's working and has been ever after. I can take photos of the thing if need be.
Posted on Jan 03, 2010
I can't get the brush to work or suction or any air flow in the lower part of the vacuum.
Depends on what you mean by 'disconnected the lower part.'
See end of the note for a link to the manual. Dyson doesn't have it directly, and a number of places either want you to download spamware, or only have a non-english copy.
1) If you took the roller all the way out, you will have had to have eased it out of the loop for the drive band, and then eased it back through after cleaning. If it's not through the loop, no drive power. The band is stiff, so it can be a bit of a challenge to pull out far enough to get the roller back through. Use a smooth dowel or other smooth sided lever to pull band out enough to feed the roller back through. (Smooth = not cutting the band)
2) If you didn't take the roller out as in (1), or did feed it back through the belt before closing it all up, then there's a couple of possibilities. A) The brush will not spin if the unit is full-upright. Put your foot on the lower assembly, pull the handle back to the 'I'm about to vacuum something' position, and try again.
B) According to the manual, this model has an 'engage brush' button. The system should start with the brush engaged, but try toggling it with the handle not up-right.
If still not spinning, turn off and unplug. Try spinning the brush by hand. If it spins freely, the clutch to engage the brush isn't engaged. If there is resistance, then it's engaged (unsure if it auto-disengages when powered off. You's want the handle tilted back when you try this).
Manual Link:
Oct 17, 2015 | Dyson Dc-18 "the Slim" Upright Model...
How to repair windtunnel hoover agitator that will not turn
Likely a broken belt. Also check the agitator brush roll bearings (in either end under the end caps) for hair, strong, thread, etc. as this will make the brush roll harder to turn and wear/break belts prematurely. If all these check okay, then observe the tensioning roller that causes the V belt (runs from the idler pulley to the brush roller) to be sure it is swinging down when the handle is released to hold tension on the belt, causing it to rotate. These tensioning rollers can break, but often are locked into the "Bare Floor" setting without the user noticing. Slide the carpet brush roll selector (located on top, next to the floor height slide adjustment) back and forth and make certain it is all the way into the "Carpet" setting to allow the tensioning roller to engage. [Note: The tensioning roller is always retracted (in the neutral or off position) when the handle is in the upright position. You must release the handle to allow this tensioing assembly to engage.]
Sep 05, 2014 | Hoover Model U6485900 Upright Vacuum...
Why the Dyson dc 41 roller brush will not turn?
Try these steps:
  • Check the button that turns off the roller brush to make sure you didn't press it by accident.
  • Unplug the vacuum and clear pet hair and other debris off the roller brush. It may stop as a safety feature if the roller brush is too restricted.
  • Make sure the belt to the roller brush is placed correctly and not broken.
  • Press the roller brush reset button. It may be located on the side of the vacuum's head, or inside the handle. The switch may need to be replaced if it's defective.
  • The roller brush is disabled while the handle is in the upright position, so tilt the handle backwards while testing the roller brush.
I hope that helps you!
Jun 21, 2014 | Dyson Dc 41 Ball
Roller brush does not engage
. Turn unit on the side and inspect brush assembly for dirt, hair, etc. , also check the condition of drive belt , be sure that it is engaged with brush roller and turning freely. Also check the option of the'suction release' valve near handle which may free brush movement. good luck. a1fe9acb-d948-4a5d-a15d-619a901ba149.jpg 72bf93b5-160b-4ddd-8f56-3515fb5b8a7e.jpg 72bf93b5-160b-4ddd-8f56-3515fb5b8a7e.jpg
Jan 04, 2014 | Shark Navigator Bagless Upright Vacuum
We have power but the front brush does not turn?
Your belt is probably broken, stretched or worn. You can get a replacement belt here:
Bissell Healthy Home Replacement Belt
Nov 25, 2009 | Bissell 5770 Healthy Home Bagless Upright...
Kenmore Beltless Vacuum brush will not spin. Everything else works.
there is a reset button on the side of the lower base of the machine, plug in the unit turn on the switch to the brush and vacuum are both engaged hit the reset button, remember the roller will not engage when the handle is in the upright position, release the handle and your ready to go.let me know if that helped you . thanks renevacdoc
Jul 23, 2009 | Vacuums
I have a Electrolux , EL6988 Canister Vacum, howeveer the brushes and motor will not run when turned on. I have take the plates and cleaned around the brushes, but it will not come one. The vacum comes on...
Turn the brush unit upside down, so you can see the brush roller. Then, with the brush roller positioned nearest to you, you will find the reset button close to the rear edge, near the wheel that's on the right hand side as you look at it.
Good luck! I hope this works for you. I value your feedback. Please remember to rate this response.
Feb 19, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Dyson DC07 Vaccum - brush will not turn
Your Dyson has A clutch unit this engages the brush roller when you pull the handle back to vacuum.
Check the clutch control knob which is at the bottom left side of machine looking from the front.
It should rotate to drive position when handle is pulled back.
If it doesnt turn the knob by hand to drive & try the machine.
If you still have no brush rotation after doing all this then UNPLUG machine from mains supply.
Now lay machine on its side & remove the sole plate, This is the cover over the brush roller.
Turn the 3 plastic screws to unlock postition & lift sole plate off.
Now try to yurn brush roller using your hand. It should turn freely if it is difficult to turn look for any foriegn object obstructing the roller.
If no obstruction found then remove the brush roller from the machine & check the bearings in the ends of the brush roller one or both may be siezed up if they are then new brush roller will solve the problem.
If bearings are good then either the clutch is faulty or the second belt which goes clutch to motor has snapped & will need replacing.
It is difficult to fully explain the clutch removing procedure,
But there are service manuals available for these repairs at this site
Jun 15, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Roller not moving when on
Your Dyson will have A clutch unit this engages the brush roller when you pull the handle back to vacuum.
Check the clutch control knob which is at the bottom left side of machine looking from the front rotates to drive position when handle is pulled back.
If it doesnt turn the knob by hand to drive.
If you still have no brush rotation after doing all this then either the clutch is faulty or the second belt which goes clutch to motor has snapped & will need replacing.
There are service manuals available for these repairs at this site
May 23, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Brush roller won't turn
On my Dyson, there is a brush reset button on the top right hand side (if you are looking at the front) that you can press to reset the brush. I was vacuuming and too lazy to move a toy and this worked for me once I freed the rope from the brush.
May 18, 2008 | Dyson DC07 All Floors Bagless Upright...
Vacuums Logo
23 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
