Question about HP Officejet Pro 8500A Wireless All-in-One Inkjet Printer
Printer I replaced Printer Heads and now it flashes 0081
Printer is 8500A
WHEN PRINTING I HAVE RED HORIZONTAL RED LINES CLEAR THROUGH THE DOCUMENT
Becky, a "stuck" nozzle can cause that. Depending on the make and model of your printer, replacing the cart may fix it, or may not. Some printers include print heads with nozzles, so have separately replaceable heads, and some have permanent heads. Most HP printers put heads in carts. Most Canon printers have separately replaceable heads, and most Epson printers cost more to replace heads than to replace the printer.
Feb 15, 2016 | Office Equipment & Supplies
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
Computer wont recognize printer,power light flashing
The flashing of the power light indicates a problem in the cartridge/s. Try to remove your cartridges from the printer > close the printer cover > unplug and re-plug the printer into the power source to reset > when the printer turns on, reinsert one cartridge first > check the behavior of the power light. If power light does not blink, open the printer cover again and reinsert the other cartridge. Replace whichever cartridge is causing the power light to blink with a new genuine Lexmark supply.
Dec 22, 2011 | Lexmark Z2300 InkJet Printer
I have a Norelco arcitec 1050 electric razor and I have lost my instructions. What does it mean when the red light starts flashing (picture of razor heads)?
Means that the the replacement heads indicator flashing, it's time to replace new heads. That Norelco RQ10 heads for Norelco arcitec 1050 electric razorreplacement parts.
Aug 15, 2011 | Health & Beauty
The power button is flashing and it does not respond
Check your printer cartridge heads if they are clean or replace them ;)
May 21, 2010 | Lexmark X2350 All-In-One InkJet Printer
Canon i350 printer won't print; alternates flashing green/orange.
Sounds like the printer head is clogged or damaged.
I believe that sequence stands for (error sending data to print head). Not sure if it can be repaired or not, its hit or miss with the canon printers.
The ip series, the heads were removable and the whole section could be replaced. Give canon a call and see if thats possible with the i350 series. Worse case you will have to replace the whole printer.
Hope this helps.
Oct 25, 2009 | Canon Office Equipment & Supplies
I have problems aligning printer heads on my Canon i850. I have clean the printer heads, replaced cartdridges, re-aligned them, but I still get lines through the printed material (phots mostly). No...
Please try to uninstall and reinstall your printer.
Clean your printer heads.
Perform a hard reset to your printer.
Print a test page.
Try using a different bond paper.
Make sure you are using original canon cartridge
If still you get an error. Replace your printer heads.
Aug 30, 2009 | Canon i850 InkJet Photo Printer
Flashing KY. I cleaned the print heads and
this is the time the board of your printer short circuit. theres is not problem with your ink or even you replaced it is still there... try to look for technician.
Jun 16, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
How turn attention light off after replacing ink and cleaning printing heads
Press Menu to display the Main Menu.
2 Press �� until Reset All Settings is selected.
3 Press OK.
This is the reset for this device
Hope it helps
Regards
Ric.
Apr 13, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Clogged printer heads
Try this:
Put paper in the printer.
Turn the printer on.
Hold the resumebutton till the powerlamp has flashed 2 times, release the resumebutton.
Printhead cleaning and nozzlepattern-printout will follow.
Nov 07, 2007 | Canon PIXMA iP90 InkJet Printer
HP Officejet Pro 8500A Wireless All-in-One Inkjet Printer Logo
Ben Johnson
