Question about Toys
My john deere 625i gator doesn't always start. When I turn key fuel pump doesn't always come on and it has too in order to start the gator.. fuel injected... anybideas?
  • 156 Answers
SOURCE: John Deere Gator 4x2 - Left Wheel doesn't move when in 2nd gear
I would replace the high/low switch and the reverse switch. One time a replaced the high/low switch and the reverse switch quit on me 2 weeks later.
You can also get the Peg Perego Gator Shifter that upgrades the vehicle.
You can get the parts and repair help at this site
They have helped me several times.
Hope this helps
Posted on May 26, 2009
  • 156 Answers
SOURCE: How to do a Seat belt retrofit on older John Deere Gator??
The seat belt should just attach to each side of the seat between the green handles on each side, as long as it is a Peg Perego Brand.
I would also contact
for additinal questions. They always help me out.
Hope this helps
Posted on Jun 15, 2009
  • 670 Answers
SOURCE: battery is charged but car is still not working,
I have the switch go bad on the gas pedal. You can find a replacement here
Posted on Dec 24, 2009
  • 156 Answers
SOURCE: help for my childs John Deer Gator
the peg perego gators have two switches in the shifter that need replaced.
I have replaced them before on my grandkid's gator.
Here is the website I get my parts from
You can also call them direct at 1.801.655.0800.
They seem to always know which part I need and I have always been very happy with their service.
Hope this helps
Posted on Mar 18, 2010
  • 19 Answers
SOURCE: john deere gator 1999 4x6 overheating.replaced
bleed air out of cooling system contact dealer for instructoins
Posted on Aug 17, 2010
My john deere 625i gator is over heating.warning light comrs on,over flow reservoir fills, and fan comes on. What can be the causes of my problem?
Blown head gasket might be the problem or plugged radiator . wash it out or blow it down with leaf blower
Oct 11, 2017 | John Toys
Need to know where the fuse is for the fuel pump for my 625i to fix my fuel pump
Troubleshooting - Operator's Manual - John Deere
Fuel shut-off valve turned off (if equipped). · No fuel or ... Open-circuit in wiring. Engine is hard to ... Fuel pump output not adjusted to specification. · Improper fuel ...images for john deere 625i wiringimages for john deere 625i wiring
Dec 05, 2015 | Peg Perego John Deere Gator HPX Ride on...
I suspect I have a faulty Electric Fuel Pump on my 6X4 John Deere Gator. I need specific information as to where it is located, how to get to it, etc., etc.
im not sure how old your unit is but if you follow the fuel line from the tank you should find it. id replace fuel filter before i did the pump. most people dont change them often enough and use fuel out of a gas can that usually has some trash/debris in it.
Sep 14, 2014 | Cars & Trucks
How do i adjust the throttle position switches on a john deere gator 620i
YOU DONT! Factory specs are need to test and set it!
First off what is the problem you are having????
All the TPS does is switch from one timing curve to the other on the cdi, and is also connected to the fuel management computer to tell it when to increase fuel delivery.
If you are having running problems start with old fuel, fuel pump pressure, and last if you have modified the airbox or exhaust in any way it will run like crap! On fuel injection you have to get a tunable fuel management computer when increasing air-flow or exhaust flow. The fuel injection is set from the factory based on the OEM parameters.
How many hours/ miles on your unit?
Have the valves been adjusted if it has over 200 hours of use?
are there any codes being flashed on display when key is turned to on position but not running?
Aug 29, 2014 | John Deere 2008 Gator XUV 4x4 620i
Have john deere gator cx it won't start, I have
My older cx won't even turn over.. Totally dead..
lights work so ignition system ok..
battery is new and hot..
fuses all ok..
Stated and ran fine through two pastures.. Turned off to fix fence..
now not a peep..
Aug 18, 2013 | John Deere 420,1020,2010,2020,2510,2520...
Toys Logo
60 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
