Question about Watches
Adp6000. Trying to set time etc. Offset keeps appearing on screen
How to switch 12 hour from 24 hour in cerruti 1881 digital watch
Hold down the C for about 2 seconds (set Hold) will appear and the time offset valve will flash on the display. Press B twice to display the screen for selecting 12-hour or 24-hour timekeeping. Press D to select (12-hour) timekeeping.
Note: The PM indicator appears between noon and 11:59 PM. After all the settings are the way you want Press C to exit the setting screen.
Jun 27, 2017 | Cerruti Watches
Silicon scientific atomic watch
Should be 4 buttons, 2 on left and 2 on right. Press bottom left 3 times and hour offset digit will be displayed. Press and hold top left until hour offset digit starts to flash. Press either top or bottom right to adjust offset hour to correspond with your time zone. Eastern -5, central -6, mountain -7, pacific -8. These are negative numbers, not positive. Then press top left button once, then press bottom left button to return to time display.
Jul 31, 2016 | ATOMIC Watches
How to set for 24 hrs.
Dec 29, 2015 | Watches
Cannot set time on my new Adidas Response ADP6005 watch. manual is useless in this regard
Just talked to Adidas. Manual is wrong on this watch type. To change time: press top-left button "set/light" and hold till "light off" appears. Then, hit bottom-left button "mode," toggling until you reach the hours/minutes/etc. Use top-right and bottom-right buttons to change numbers as needed. Hit top-left "set/light" button when finished.
Jun 16, 2011 | Watches
I just bought the adidas ADP6000 watch from argos and the manual is no help at all and i cannot work out how to change the time and date even though i have researched online :(
Okay so I had the same problem as all you guys, fiddled around with the buttons for a couple seconds (literally) and worked it out
The following instructions are for tADP6000:
1- press and hold 'SET/LIGHT' button
2- it should say 'LIGHT' and 'OFF' flashing, now press 'MODE' until you reach the screen you desire, then use the 'START/STOP' and 'LAP/RESET' to change between 12hr/24hr; time; date etc etc. hope this helps
Jun 13, 2011 | Adidas Digi III Watch
Just bought an Adidas Seoul Watch ADH2044 and can't set the time. I've looked in the manual that came with it and online and can't find anything to help. The Adidas website isn't any help either.
Figured it out - Press & hold 'A' then press 'D'. THEN press 'B' to toggle through the selections to set T1. T2 (for another time zone) is up or down in the offset. Good luck!
btw - A, B buttons are from top to bottom on left and C, D are top to bottom right
Jan 07, 2011 | Adidas ADH1572 Watch
I need help setiing the time on my adidas adh4004 watch. The manual wont help!
You are right the manual is useless.
To set the watch it needs to be in T1 setting, you can do this by using the C (top right) button, to chose just push once and the number should change, hold to set it to T1.
After that, push the A button (top left), this should hopefully display 'Light'. If it still displays 'Offset' then you are still in T2 (offset lets you offset the GMT). Try the C steps again.
Once 'light' appears you can scroll through the menu using B (bottom left), at which point you should find the time selection option. It should be flasing, use the two far right up and down buttons to then set the time/date etc. Press B to move on to the next setting. When you are done press A.
Nov 02, 2009 | Watches
I am trying to set the time zone for Adelaide South Australia which is +10.30 hours UTC. Is thereany way to add 30 min steps to the UTC time setting
Set watch to CHR mode, pull out crown, all dials will return to 0 posn. HR shoul be displayed on left digital panel. Move hour hand by turning crown to posn half way between 12 and one, press top button (MIN should appear in left panel), set min to 6 o'clock posn. Push crown back in and set time for timezone nearest to where you are that is offset by one hour.
Oct 13, 2009 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
How to set time on Diesel DZ 7071 Watch
Just figured it out!! Press and hold Set/El button. Wait until LIGHT On/Off (or similar) flashes on screen. When it does then press the Mode button to scroll through various functions including setting the time. Hope this makes sense and helps
Dec 20, 2007 | Watches
Watches Logo
19 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
