Question about Health & Beauty
The stop button is on on my display screen on my health rider h20x. How do I get it off?
Were do I put the transaxle oil in a shop rider mobility scooter
if you can post on a health form about a scooter you can clearly go to google and type your question in there and find the answer.
Oct 23, 2017 | The Health & Beauty
What is the cheat of ghost rider
PS2: Unlimited Health
On the main menu, Hold L1 and press UP, UP, DOWN, DOWN, LEFT, RIGHT, LEFT, DOWN, LEFT, LEFT, UP. This should give your character unlimited health.
Oct 26, 2014 | Datel Ar Action Replay Max Ps2 Cd 64 Mb...
How do I unfold the health rider h75t
Guys ,
Try rewarding your body by feeding it isagenix
Warm regards
Isagenix Consultant
The Isagenix Wealth Creation solution
Cleanse for Life
The Isagenix Weight Loss Solution
The Official Site of Isagenix International
Jan 26, 2014 | HEALTHRIDER H75T Treadmill
520230. 31520193. 7Polaris 550 Xp eps 2009About 20 hours on unitStored indoorsI understand one code is Idle air and the other is power steering is disabled or not functioning. First I would try and...
Diagnostic Mode
The diagnostic mode is for informational purposes only. Please return your ATV to your dealer for all major repairs.
As long as the gauge is in the diagnostic mode, the wrench icon will remain lit.
To leave the diagnostic mode, turn the key switch off and on.
NOTE: Any movement of the tires will also take the machine out ofthe diagnostic mode.
To enter the diagnostics mode:
1. Turn the key switch off and wait 10 seconds.
2. Set the park brake and shift the transmission to neutral.
3. Hold the mode/reverse override button and turn the key switch on.
4. Release the switch as soon as the display is activated.
The initial screen display refers to the software version installed in
your ATV. This information is displayed briefly.
Use the mode/reverse override button to toggle through the diagnostic
Screen 1: Battery voltage
Screen 2: Tachometer
Screen 3: AWD diagnostic
This gauge indicates whether or not current is flowing through the
AWD coil (only on models with switchable AWD).
Screen 4: Gear circuit diagnostic
This screen displays the resistance value (in ohms) being read at thegear switch input of the gauge.
Instrument Cluster
Rider Information Center
Diagnostic Mode
Screen 5: Programmable service interval
The purpose of the programmable service interval is to provide the consumer and dealer with a convenient reminder for routine maintenance. When your vehicle leaves the factory, this feature is set at 50 hours. You must enable the programmable service interval before it
can be used.
Once the service interval mode is set with the hours when service is due, the hours of actual engine operation are subtracted from the set
hours until 0 is reached. When the counter reaches 0, the wrench icon will flash quickly for 5 seconds each time the vehicle is started as a reminder that the periodic maintenance is due.
To set the hours, press and hold the mode/override button until the wrench icon flashes. When it begins to flash, release the button. The setting will increase by one hour each time the button is pressed.
Pressing and holding the button will allow the numbers to escalate much faster. When the desired time increment is displayed, release the button and wait for the wrench to stop flashing. When the wrench stops blinking, your service hours are set.
NOTE: If you scroll past the intended number, hold the button down until the count turns over to 0. You can then reset the number.
If the service interval is enabled on your ATV and you wish to turn it off, toggle to the service interval mode. Press and hold the mode button for approximately 7 seconds until the word OFF appears in the
Rider Information Center.
Jun 28, 2013 | Polaris 2009 Sportsman 550 EFI XP With EPS
My ear thermometer is stuck on celsius
To change from Fahrenheit to Celsius or vice-versa just turn off the unit first,then press and hold the Activation Button till the 'Ready' display appears.Now press and release the Activation Button to switch from F to C or the opposite.Once the scale has been selected,wait till the LCD screen shows the full display.
Dec 25, 2012 | Health & Beauty
Aerobic rider 1 manual
Hi Robert, for more information about your question please visit the website below. Good luck and have a nice day.
Jun 10, 2012 | Motorcycles
My health rider treadmill s300se is stuck in the highest incline position. How do i get it level again?
Try putting the key in while holding the down incline button in. This resets the height mechanism. Repeat with the up incline button.
Worked for me.
Aug 11, 2009 | HEALTHRIDER S300SE TREADMILL Drive Motor
Frozen on health and safety screen, without words on bottom "press a button to continue"
Did you download the homebrew channel? or tried to?
if you did then that is probably why it freezes
May 22, 2009 | Nintendo Wii Console
Health & Beauty Logo
60 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
Are you a Health and Beauty Expert? Answer questions, earn points and help others
