Question about DeLonghi Coffee Makers & Espresso Machines
Delonghi perfecta - milk spits out of the tube when pushing the clean button after mile frothing. Milk frothing works fine - it's a new lid.
My Delonghi Perfecta Cappuccino machine work fine EXCEPT that after it is done and I push the "clean" button on the milk container, milk comes out when I release the clean button. At first it appears to clean out the tube properly (steam and water come out), but when I release the button more milk comes out, defeating the entire clean.
2 Suggested Answers
thehardwa922
  • 4 Answers
SOURCE: Cappucinatore won't pull milk through the tube
Right end button is the Milk Frothing button.Press once then dip the tube into a pot of milk, it will **** up to the frothing fixture on the left.If don't work press or turn the fixture deeper to activate the suction action needed to **** up the milk.Wash or put a muck of clean water to wash the fixture.After that pull the fixture to wash under the tap.
Posted on Oct 14, 2012
Why is Delonghi Perfecta not producing steam to froth milk.Nothing at all happens when cappacino button is pushed
At wits' end DeLonghi Magnifica steam function - Coffee Forum
www.coffeeforums.com/.../9427-wits-end-delonghi-magnifica-steam-fun...
Jun 1, 2012 - While I quite like the coffee it produces, the steam function seems to be ... it with the magic DeLonghi descaling solution, so I'm certain this is not ...
DeLonghi not producing steam Questions & Answers - Fixya
www.fixya.com > Forum > Tags > not producing steam
Ask your DeLonghi not producing steam questions. Get free help, advice ... Ad. Question about Esclusivo Magnifica ESAM3300 Espresso Machine. 3 Answers ...
Delonghi 3500s coffee machine not producing hot water or ...
Dec 06, 2015 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Delonghi esam 5600 will not froth milk
Here is the manual:
http://www.delonghi.com/Global/InstructionManuals/EN/ESAM5600%20Intro%20EN.pdf
Two causes from the troubleshooting section:
The froth regulator is incorrectly adjusted. • Adjust following the instructions in the section on preparing drinks with milk.
The milk container lid is dirty. • Clean the milkcontainer lidasdescribedin the section "Cleaning the milk container".
Feb 19, 2015 | DeLonghi Coffee Makers & Espresso Machines
Delonghi perfecta milk not hot enough
Ummn - something in your Q. seems not right. The milk is not heated directly - its only heated by the steam as it passes by (and picks up) by the milk using a venturi effect - same as a spray bottle attached to a garden hose. You say you have froth - but you can only get that if you have steam... (it does not just blow air thru to create bubbles). So froth = steam & steam = heat... so milk must be hot.
Suggest you check manual for the 'heat' settings for your expresso as this may have been changed. While this is adjustable, the milk is not.
Also always heat your cups before using them - the silver cup 'holder' at the top does a reasonable job but boiling water does far better.
Cheers Mike
May 31, 2014 | DeLonghi ESAM6600 Espresso Machine
Delonghi Perfecta won't froth milk or allow hot water to come out from waterspout
Aug 20, 2012 | DeLonghi Perfecta ESAM5500 Fully Automatic...
DeLonghi Perfecta ESAM5500 when trying to make a cappucino it wont **** up the milk any ideas thanks
Had this exact problem a few times on a cleaned well maintained milk jug top with an ESAM5500M. Delonghi 'repaired' it by sending a new milk jug frothing top.
It's caused by milk fat deposits, the frother part on the milk jug may look clean but deep inside it's not. I clean mine with pipe cleaners, detergent and hot water and still it wouldn't froth.
The problem re-occurs for me every 6 months or so. You could buy the milk fat remover solution to clean it. Personally I just boil the whole milk jug frother in detergent and the again in descaling solution, that's fixed this problem twice now, although I think it will eventually corrode the 'o' rings on the frother, still cheaper than buying a new frother part each time though.
If it still doesn't work after that, the only other reason for this problem I found mention of was caused by a broken rubber seal where the milk jug fits to the machine. It's most likely to be milk fat deposits inside the frother though.
Jan 25, 2011 | DeLonghi Coffee Makers & Espresso Machines
I have a Delonghi Prima Donna. Blows lots of stem but wont froth milk. The 3 orings have been replaced and the fittings cleaned, but still no frothing. I pulled the lid apart and it seems ok. Any...
Where is it blowing steam from? If it is coming from the milk spout then it most likely that the milk jug is blocked somewhere. If it is coming from where the jug connects to the machine (coupling) then you might need to change the complete coupling (assuming you used the correct orings). The biggest cause of frothing problems with these machines is lack of cleaning of the milk jug. Soak the top in quality milk cleaner for at least an hour and rinse thoroughly. Also run cleaner through it regularly using the milk only function.
Nov 19, 2010 | DeLonghi Prima Donna Avante ESAM6700...
I have a Delonghi Magnifica Rialto EAM4500 coffee maker. Recently it has stopped frothing milk. Per delonghi I have replaced all of the gaskets that connect between the milk container and the unit. When we...
I purchased a unit second hand for my wife's birthday today. It's only 4 months old, got it home, tested it, same problem... No froth!
I've read all the posts here and all were very helpful troubleshooting guides however they did not solve the issue.
Understanding how the frothing mechanism functions is half the battle in figuring out the solution. It's a simple vacuum type system. No doubt you've read about checking the orings. This is definately the first thing to check however if this is not the reason then consider the following.
The larger of the white tubes that has the red and black oring inserts deep into its port on the tap. Why? It pushes steam past the milk pipe directly into the chrome frothing tube which causes a vacuum essentially drawing milk up it's hose creating the froth. What you can't see without further investigation is that on the underside of the tube centered between the red and black orings is a small hole. This hole is responsible for drawing the milk upwards. If this is blocked, and it probably is then no milk and no froth. Use a really small screwdriver to carefully clean the white tube both from the front and the little hole underneath.
So in conclusion. Any air leak between the red and black orings will prevent the vacuum required to draw milk up the tube and alternatively any blockage of the milk channel will also obviously prevent the flow into the frothing mechanism. Hope this helps.
Apr 09, 2009 | DeLonghi Coffee Makers & Espresso Machines
Milk not frothing
Jun 29, 2008 | DeLonghi EAM3500 Espresso Machine/Coffee...
Coffee Makers & Espresso Machines Logo
37 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
83bj60
Level 1 Expert
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
