Question about HP Office Equipment & Supplies
Have HP3580 printer. Want to make your copy larger.
Change font on all copies and printing
You need to change the font size on the document, not the printer.
Feb 19, 2015 | Office Equipment & Supplies
Make font larger on HP1510 printer
What font are you referring to? Have you prepared a document in a word processing program, or added text to an image file, and are disappointed because you want to see the text printed larger? If so, your best solution is to edit the document or image and change to a larger text size. For example, most text documents will normally default to either a size 10 or 11 text which is readable but small. Changing to size 12 or 14 will make the text look larger onscreen, and the text will also print larger. The font name and font size should be displayed on one of your processing program's toolbars, and is easily changed to a different font name or size. If you are simply copying an already printed document and want the text to appear larger, you should refer to your printer's User Guide. If you don't have the User Guide, you can download a free copy at this link:
HP PSC 1510 All in One Printer User guides
Nov 15, 2014 | HP PSC 1510 All-In-One InkJet Printer
Epson SX405
Just set is copy as is. or one to one. Standard auto fit will always enlarge any image smaller than a full page.
Jul 16, 2014 | Office Equipment & Supplies
Can't increase a picture size
you need to be more informative
are you trying to make a larger copy? or print something from the computer?
Apr 06, 2014 | Brother MFC-290C Printer
How can I make the print larger when I make a copy or print something?
Printer preferences, both paper quality and effects can change the size of the print, to change the size of a copy this can be done in the same way or from the control panel depending on the model of the printer
May 18, 2011 | HP Office Equipment & Supplies
I have an old Konica Minolta bizhub 180 and am trying to make a copy on an 18x11 inch piece of paper with no success. Can anyone help me out?
The maximum paper size for the Bizhub 180 was 11"X17". Using a larger paper size will result in either incomplete copy or a paper jam every time.
Good Luck and Thank You for using Fixya.
Oct 14, 2010 | Konica Minolta bizhub 180 All-In-One...
When a document is copied the copy document comes out larger than the original, but the settings for reduce and enlarge is set at 100%.
sometimes the setting stays in the memory. Try shutting off the copier completely, let it rest for 3 seconds and then try again clear all buttons.
Aug 04, 2010 | Xerox 6180MFP/D Printer
Have a Dialta with a black line showing up and no visible marks on glass?
If the black line shows up when copying from the glass AND when using the document feeder then it is not the strip glass. Is it a fine line or a wider band like say 1/4 inch or larger? If it is larger then it is most likely the drum cleaning blade. You can verify it is a blade by running say 10 copies in a row. If the line gets worse as it runs copies it is the blade.
Of there is no line when using just the glass then it is something on the strip glass or scan glass.
Dec 30, 2009 | Minolta DiALTA Di183 Copier
Can not increase size of copied letters
Are you referring to magnification? Most printer/copiers don't do that. If you're trying to print out a document, just select a larger font.
Mar 26, 2009 | HP Officejet 5610 All-In-One InkJet...
HP 3200 make copy larger than original
when printer page comes up there should be an advanced tag click on this new page find box for page size select either A4 or print to page
also on the first page should be a box with number of copies always make sure 1 is in it
Jul 26, 2008 | HP LaserJet 3050 All-In-One Printer
22 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
