My letters or numbers do not display so I can't see wen I put the timer on for washing or drying ,the light displays but no numbers washer /dryer combo Samsung / model WD8602R8U please help
  • 37 Answers
SOURCE: Frigidaire Washer/dryer combo
Dtronics,
A part called a (wig-wag) its a part that consists of two selonoids, one is bad. It switches the transmission from the wash cycle to the spin cycle,at the same time it opens the pump for draining.
hope this is helpful
handiman518
Posted on Jan 17, 2008
SOURCE: Bosch washer/dryer
I also have the same washer and same problem, and it is not due to clogged filters nor due to low pressure!
Any solutions so far?
I wish I had read these posts before buying it. :(
Posted on Nov 01, 2008
  • 100 Answers
SOURCE: Hotpoint Washer Dryer WD865 - Dryer Problems
thermister blown or thermal fuse which is a black plug in the top of the dryer box or yellow sleeved wire, if it was noisy maybe the fan has come loose from it's motor. you will need to remove the dryer box on top of the drum to see if the fan is binding. you can push it back to where its not binding and tighten the nut-ANTICLOCKWISE, LEFT HAND THREAD.
usually the machine runs through a check before starting a cycle and will see an f13 and not start even a wash., so you will need to replace the blown parts.
Posted on Jan 28, 2009
  • 25 Answers
SOURCE: F13 error during drying cycle
Hi, that indicates that either the fan motor is not working/ blocked or the dryer thermistor (thermostatic sensor) is playing up. Of course, the pcb reads the sensor so it could also be that causing the error.
Posted on Jun 03, 2009
SOURCE: Frigidaire stackable washer-dryer
I would check the manual.
Posted on Mar 14, 2010
It only wash & don't spin? Then it stops and leak water by the door....
LG Washer & Dryer 7 (WD12331AD)
Its is a direct drive front loader with 7kg capacity for washing and 3.5kg capacity for drying.
when new
thats 7 kg with wet clothes and water
and only 3.5 kg wet clothes to dry
the older it gets the less weight it can wash and dry
worn motor or drum overload if it doesnt want to spin at all
leak at the door . replace the door seal ..is a most common fix
extra info
It has 9 preset settings, 400 - 1200 RPM, 5 temperature settings, digital display and delayed start timer.
Sep 20, 2016 | LG Washing Machines
HI would you what know what error code Er13 is?? on a Logik L614WD13 washer dryer?
Feature : Error Code-control panel display "Er13"
  • Answer : Reason:Drying heater element error. Sometimes caused by to much load during the drying cycle. Washer dryers can only dry half the wash load.
Nov 03, 2014 | Washing Machines
My washer is in french wdd960 how do i get it in english?
To change the language on the Hotpoint WDD960P/G/A/K washer dryer.
The official manual is slightly wrong!!
So Follow these steps:
With the machine in the "OFF" position (NO display) Simultaneously press and hold the Delay+Temp+Spin buttons until you hear a bleep and a language is displayed. Let go of the buttons and scroll to your desired language by pressing the "Spin" button until the language you want is displayed.
Inmediatly press the "Drying" button to select it and the display should say "Hello" to acknowledge the selection.
If you take too long in pressing "Drying" it reverts to the previous language.
Happy washings!!!
Feb 16, 2011 | Hotpoint Ultima WD72 Front Load...
My washer is not washing, is displays the letter F. What so I do?
my washing machine is not washing, and the buttons- intensive, rinse hold, pre wash and dry even the pause and star will not work but the pause/star light will be showing.
Oct 10, 2009 | Kenmore Elite 45986 Front Load Washer
Hotpoint aquarius wd440. Flashing lights
press and hold on off button till the display panel lights up.Then press and hold the on/off button and the start /cancel button together.You will now reset the washing machine settings.And just pick your cycle again
Oct 04, 2009 | Hotpoint Aquarius WD63 Front Load...
Timer delay displayed permanantly and beeping
the button is not stuck in is it? sometimes they get a bit sticky in kitchens.
Nov 11, 2008 | Hotpoint Ultima WD72 Front Load...
No LCD Display
they can fail try writing a letter to the manufacturer,if there a good company the will help.
Feb 11, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Help me!!!!!!!!!!!!!
Ok the washer is telling you we have a problem. I will tell you how to retrieve the code and then ill tell you what that code means
1. Wake the washer by pressing any button.
2. Wait 5 seconds.
3. Press and HOLD the Start/Pause and Cancel
buttons simultaneously. As long as the buttons are
held, the failure code will appear in the display as an
E followed by two numbers, a number and a letter or
two letters. The controlwill beep and the Door Lock,
Wash, Rinse,
and Final Spin indicator lights will
flash.
Nov 16, 2007 | Frigidaire Affinity ATF7000E Front Load...
Display panel (cont.)
hi there try pressing and holding the start button for about eight seconds
Oct 10, 2007 | Hotpoint Aquarius WD640 Front Load...
Display panel
Check to see if any water remains in the machine . SOME MACHINES IF They DO NOT DRAIN OUT ALL THE WATER WILL CONTINUE TO run until all water is drained. Also check for suds in machine if machine senses suds it will try to re rinse the clothes.If your machine has a filter at the bottom clean it out .
Oct 09, 2007 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
