could be still clicking if faulty best thing get diagram for water level censer and do a test under 10amp load, thermostat next to element or contacts in timer melted or dry joints Re: Jeff
To remove melted crayon from upholstery:
1. Scrape away melted wax from the upholstery as much as you can using a blunt knife.
2. Put a brown paper, or butcher paper (glossy side down) on top of the affected area then using the tip of a hot flat iron, melt the crayon until it stick to the paper.
3. Let the paper cool then lift it away gently from the upholstery.
4. Dab a small amount of denatured alcohol to remove any remaining stains then finally clean the affected area with sponge and water.
Hope this help. Goodluck!
The mold heater comes on shortly before the ice is dispensed. It warms up the mold so that the ice releases. The heater, if not working could cause the water to overflow as the ice can not be ejected if the heater does not work. That woud make the appearance that the ice melted and refroze.
