Question about LG Washing Machines
What does it mean when the washing machine suddenly stops and says "UE"?
It stops and the "UE" appears while spin process. my washing machine is : LG 8.0 Kg fuzzy logic.
    President:
  • 3,074 Answers
This will help, for today and into the future, MERRY CHRISTMAS, Tim:
http://manuals.appliancesonline.com.au/wth550/wth550.pdf
Posted on Dec 25, 2016
Machine displays UE when spinning and turns off the machine, this occurs even when the machine is empty
UE means uneven for LG washing machine. Could you please using water level to make sure it is level. May I know if the drum is stable while spinning by not giving any banging sound. Used to happen to my LG direct drive, and solved by replacing the suspension that supporting the drum holder. Now all good like new.
Dec 24, 2013 | LG Washing Machines
LG washing machine direct drive when i put it on it washes and goes down to 9 mins then stops, sometimes an error code comes up UE? CAN U HELP PLEASE
It means Unbalanced Error, it means the machine cant balance the load during the spin cycle, normally happens if there is too little a load i.e 1 or 2 things or overloaded. It is designed to protect the bearings. If it happens with a normal load try stopping it and re-arranging the load by hand and putting it on a spin only cycle. Hope this helps.
Feb 28, 2011 | Washing Machines
Hi,i have a samsung washing machine,p1253.model and i keep getting a code UE,and it appears not to be spinning.....please advise what this code means and is it possible to read an instruction manual on...
Hi, UE error means unbalanced load, loosen the washing and try again, if the load is to heavy take out some of the washing and spin in 2 lighter loads.
UE Happens if you overload the washing machine.
CLICK HERE for the user manual.
Hope this helps.
(Dont forget the thumbs up if this helped)
Feb 12, 2011 | Samsung Washing Machines
Lg inverter 75kg wd1238c problem, after before getting to the spin stage of the wash, it stops and the screens says UE on it and UE is flashing on and off
Error code UE cause : Load is too small, load is out of balance( 1 or 2 large items) solution: Add items to help balance the load, rearrange load to allow proper spinning.... Hope this is useful .....
Sep 18, 2010 | Washing Machines
After a wash cycle, the letters UE appeared in the timer window..
UE = Unbalance error.
try to use a low spin speed with loads like rugs, and try to get as even a load as possible. (ie: not just one rug) Don't wash rubber backed rugs, as the backing can break up and clog your machine.
Now, if you are successful washing with the lowest spin speed, you can hold the " Spin Speed " button in while pressing on the power button. Release power button. Now release the spin speed button. Now, press the spin speed button until the next higher spin speed from your last successful spin. Press start. Your washer should now pump out and attempt to reach the new spin speed, without adding any water. (usually about a 14 minute pump and spin cycle) Don't expect to be able to spin out rugs at a high spin speed.
Jul 05, 2009 | LG WM2487H Front Load Washer
Error code UE on LG Front Loading Washing Maching
this is what i just found on the internet...
With any washing machine, it is vital to ensure that the load is evenly balanced when using a spin cycle. Redistribute washing by adding or removing items to ensure a more balanced load. ... If the door remains locked and the machine is displaying UE error, please run a drain program.5 Jul 2016
My Samsung washing machine is showing a UE code during a spin ...
or try this link..
Error code UE on LG Front Loading Washing Maching Google Search
Oct 27, 2017 | LG WM1814CW Front Load Washer
LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
Apr 27, 2009 | LG WM2487H Front Load Washer
LG WM 14316FD washing machine
An UE Error Code is indicative of a “Unbalanced Error”. This indicates that the drum is not spinning in a smooth rotation. It may be necessary to rearrange the load in the drum. I found this answer on the lg web site.
Dec 01, 2007 | LG Washing Machines
Washing Machines Logo
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
