Question about Home
We have track lighting. They were all working for 2 months, then all lights on one track (our only track) stopped working. Did all bulbs just burn out at same time? Or is there something else?
MicrowaveSvc
  • 9098 Answers
SOURCE: Burning smell and light switch does not work
The controller needs to be repaired. We regularly repair these control board assemblies for only $32.50 nationwide, and that's much cheaper than replacing the board. For safety, disassembly and other info see http://tinyurl.com/yzjozk
Posted on Jan 15, 2007
emissionwiz
  • 79865 Answers
SOURCE: Clock light burned out
You will need to pull the clock, the bulb is on the back, any parts store will carry it, it is a mini peanut bulb.
Posted on Oct 02, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE microwave JVM1631BJ01 while replacing
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Dec 22, 2008
SOURCE: Light bulb burned out in microwave oven
Most likely you're going to have to dismount the microwave and remove the outside cover to get to the bulb. This is a fair amount of work but is not rocket science. I'm not famliar with your particular microwave, but it's probably that way. If it's any comfort to you, light bulbs are usually not covered by warranties or service contracts.
It won't hurt to run the microwave without a bulb.
Posted on Feb 04, 2009
  • 101 Answers
SOURCE: My headlights do not work on my 2002 Subaru Forester
Do you have park,signal lights ,check fuses.
Posted on Oct 02, 2009
Over the Range Light Stopped Working
It is a good chance that the bulb (s) have burned out. I would think they would last longer than that but things are not as good as they used to be. Unplug the microwave before removing the bulbs. Especially if they are the screw in type. GE usually has two bulbs in there and they could be the halogen type that just plug in or the screw in type.
Mar 28, 2014 | GE Profile JTP18 Electric Single Oven
Short in one headlight Toyota Solara
I would replace the socket for that light that is shorted.
Jan 29, 2013 | 2005 Toyota Camry Solara SLE V6
My malibu landscape 300w transformer does not want to come on
Check that power pack is getting electricity.
Power pack should make a small humming sound when on.
Scratch a wire across both terminal screws and see if there is spark.
If a bulb burns out, and is not replaced, additional voltage can burn out other bulbs.
Power pack should be unplugged if bulbs are not burning since that can burn out power pack.
Change out a couple bulbs and then plug-in power pack.
Check connections where lights tie into wire.
My power pack was doing same thing, I bought another power pack from Home Depot to check my lights. All but 2 bulbs were burned out. I replaced bulbs and returned new power pack.. and then power pack quit for good a month later.
I found tips to preserve power packs:
1) Match wattage of bulbs with wattage of power pack
-15 each X 20 watt bulbs = 300 watts, so install 300Watt power pack
2) Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
3) Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
4) When working on bulbs, unplug power pack or it may burn out.
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack
Nov 22, 2010 | Intermatic Malibu 300W Power Pack...
My lawn lights stopped working, transformer tested ok. What could be the problem?
You checked that power pack is getting electricity.
If a bulb burns out, and is not replaced, additional power can burn out other bulbs.
Nov 14, 2010 | Intermatic Malibu 300W Power Pack...
GE GTS20ICNCC Refrigerator light bulb burns out quickly
Use the correct wattage bulbs. If they fail often then you may need to get it checked by an electrician.
Filament bulbs easily burn out. What you can do is to buy cheap bulbs and replace as soon as they burn. This is the problem which is why tube lights and LEDs were invented!
Sep 07, 2009 | GE Refrigerators
Headlights high and low beams do not work
replaced both bulb sockets and bulbs sockets had loose wires causing overheating burning bulbs out
May 18, 2009 | 2003 Chevrolet Cavalier
Headlight keep burning out
you might be using a higher wattage of hallogen bulb. higher wattage bulb must have a relay so it'l stop from burning. and you save money.
Apr 15, 2009 | 2005 Kia Sorento
Bulbs burn out quickly and dimmer inoperative
huhnr
the connections at the socket are loose. remove bottom pan and squeeze the electrical connections lightly with a pair of pliers.
doc
Apr 15, 2009 | Whirlpool GH4155XP Microwave Oven
2006 Hyundai Sonata brake light problem
there is a tsb for the brake switch in 06 sonatas. it must be adjusted or replaced by dealership. is your check engine light on, if so its probably code p0504
Jun 20, 2008 | 2006 Hyundai Sonata
Light blown then fan doesn't work!
take out switch assemby and check if the track of the pcb is blown - caused by the bulb goiung. you can often repair by soldering in wire links. bet you have 12a fuse in system - should be 3a. track has blown instead of the fuse
Mar 02, 2007 | Baumatic F60 Stainless Steel Kitchen Hood
Home Logo
19 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
