Question about Cameras
Help. My one year old daughter slipped the card into the notes slot, how can we open the drawer without a card?
  • Bart Pulverman Jan 02, 2017
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    1) What brand and model camera are you talking about?
    2) Is the "card" you are talking about the SD or CF flash memory card?
    3) What do you mean by "notes slot"? Do you mean the memory card slot?
4 Suggested Answers
johncaman
  • 201 Answers
SOURCE: I was putting CDs in my Philips 3-CD Player and
The best solution is to open the case and manually remove/realign the jammed cd.
Posted on Mar 13, 2009
neiltoz
  • 12 Answers
SOURCE: I have a toshiba laptop (1 month old) and the
First try to copy the pictures to your hard drive; it sounds like the CD may have fallen off of its spindle. You should be able to release the tray by pushing a paperclip straight into the tiny hole next to the tray-release button. I will go in about 1/2 inch, or so, and you should feel the release mechanism operating. If it doesn't go straight in you won't feel any resistance.
Then you will probably have to shake and jiggle the computer, maybe turn it upside down to get the tray to open.
Posted on Oct 20, 2009
SOURCE: 12 year old sub-zero refer-the ice maker drawer
There is a plastic sled that fits on a wire bail, connected to a microswitch that tells the unit that the ice level is low and it needs to turn on the water to fill the ice cube trays. The wire bail falls out and catches on the drawer. If you pull too hard, you will break the plastic sled where it attaches to the bail. You can still buy the entire ice maker unit and re-install it easily, or if you are really handy, you can attempt a temporary fix with a little bit of wire at each end of the plasitc sled to keep it attached correctly to the wire bail. The older units were famous for this problem. I fixed mine, but ultimately had to replace the unit. Parts cost around $130.
Posted on Feb 20, 2010
My Emerson EM756 tablet won't stay on
Questions, Troubleshooting Help & Support - Fixya
www.fixya.com/troubleshoot
Sent money to my daughter via her cell phone. How does she ... Cd drawers won't open, may have cd stuck in #1 slot ... My Emerson EM756 tablet won't stay on.
Emerson EM743 7 - inches Android Jelly Bean Tablet With ...
www.amazon.com/Emerson...Tablet/.../B00IIHOM06
Amazon.com, Inc.Find helpful customer reviews and review ratings for Emerson EM743 7 - inches ... Google Play Store won't work with this device. ... Note, the cheapo Craig tablet with a dual core processor in my picture actually did ..... The sd card slot was improperly installed, as the sd card would not stay in place in the back of the unit.
Emerson Flat Panel Television LC320EM82 WON'T STAY ON
Dec 10, 2015 | Tablets & eReaders
Something has slipped behind the bottom drawer, a flimsy cutting board. Can the drawer be removed and how?
The drawer is easily removed. Make sure you switch off the power first and I always unplug just to be sure.
9.1 Drawer Front Removal
9.1.1 Slide open drawer.
9.1.2 Locate draw pin on either side of the tub. (These are white plastic pins, about 1.5cm diameter. You can't miss them.)
9.1.3 Using a sharp pair of long nose pliers or slip jaw pliers grasp the center dividing web of the pin and pull away from the tub to remove the pin. Support the drawer front with your hand while doing this.
Note: The pin web is vertical.
9.1.4 With both pins removed the bottom of the drawer front can now be eased out slightly.
9.1.5 Now carefully pull the drawer front down to allow it to come free from the handle and top locating slots.
9.1.6 Carefully remove the earth wire from the tab on the drawer front. (if it is an integrated model you will also need to unplug the integrated badge from the isolating module)
9.1.7 Refit in reverse manner ensuring the drawer slides are right forward and the pin secures through the hook on the front end of the slide.
Note: When reinserting the pins make sure the dividing web is
vertical.
9.2 Tub Removal
9.2.1 Open the drawer fully.
9.2.2 Depress the right-hand tub clip and push it back about 30mm (1 inch). Repeat for the left-hand side. These clips are on the runners and are usually white plastic.
9.2.3 The tub may now be lifted up off the drawer runners. It's amazing but the drawer simply lifts out.
9.2.4 Slide both runners back into the product.
9.2.5 Refit in reverse manner.
Feb 18, 2015 | Fisher and Paykel Dishwashers
How to add a card
open the case up then pull a slot out of the case then put it in put screw in card slot then power up then put in drivers for card
Aug 13, 2014 | Computers & Internet
Zillionz atm
Try and use any credit card you have and insert it. It should work.
Mar 11, 2014 | Toys
Cannot open my secret safe by justice
Reference: Paisley Electronic Push Code Safe
Item # 5661462
Purchased at Justice. May be one of the following design/colors: 1. Pink and black 2. neon green 3. tye-dye (all in zebra pattern, I believe)
To gain access to safe without code proceed with the following simple instructions:
Use a screw driver to access batteries on the bottom of the safe. Remove all three AA batteries.
WAIT AT LEAST TEN SECONDS before reinserting betteries to functional position. Replace screw. Key in default passcode "0000#" Safe will now be unlocked and upon opening you can reset passcode. Hold down the "*" and when voice prompted to "key in passcode" enter new 4 digit code followed by the # sign... HOLD "*" until completed code with "#" You will hear the voice command, "enter passcode" after each digit entered. [Press & hold "*" (1234) press "#" release "*"] Close safe and new passcode should be set and work properly. If not, enter default "0000#" and try to reset once again.
Feb 03, 2014 | Toys
2000 Buick LeSabre - Interior Drawer below Stereo
These solutions are not for the question that was asked..I am in the same bingld and need to know how to remove the drawer under the stereo without breaking it....Can anyone help us answer that question
Jul 30, 2010 | 2000 Buick LeSabre
Soap drawer is filled with water
Our 2 year old washer just started seeing this problem. After removing the detergent dispenser drawer from the washer, cleaning it and cleaning the slot it came from we stopped seeing water retention.
May 09, 2010 | LG WM-2277HW Front Load Washer
Installing sim card in sidekick II
the sim card goes on the bottom of the phone under the rubber thing (idk what to call it) you need to lift it up and you will see a pictuer of hoe to pu in your sim card and for the battery idk
Jul 05, 2008 | T-Mobile Sidekick II
A freezing nintendo lite!
The DS Card Slot may be loose. If so, try not to touch the game card while playing.
Or, there may be a piece of dust or lint in the card slot. If you can see the lint, pick it out with clean tweezers. If you cannot see it, ask a mechanic to open the Ds and pick the dust out.
Jun 10, 2008 | Nintendo DS Lite Console
Cameras Logo
44 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
