Question about Cell Phones
My screen is locked and no volume button on outside. How can i do a factory rest?
    Master:
  • 222 Answers
Try pulling both the battery and the little sim card or memory card then, after two minutes, put them back in. It should make things go back to a safe mode on just about every cell. you can reset to your preferences from there.
Posted on Dec 26, 2016
I forgot security code to my HTC rezound beats audio phone
Performing a factory reset from settings
  1. From the Home screen, press MENU , and then tap Settings.
  2. Tap Storage > Factory data reset.
  3. Tap Reset phone, and then tap Erase everything.
Performing a factory reset using hardware buttons
If you can't turn HTC Rezound with Beats Audio on or access settings, you can still perform a factory reset by using the hardware buttons on HTC Rezound with Beats Audio.
  1. Remove the battery, wait for a few seconds, then reinsert the battery.
  2. Press and hold the VOLUME DOWN button, and then press and hold the POWER/LOCK button.
  3. Wait for the screen with the three Android images to appear, and then release the POWER/LOCK and VOLUME DOWN buttons.
  4. Press VOLUME DOWN to select FACTORY RESET, and then press the POWER/LOCK button.
Resetting HTC Rezound with Beats Audio
Apr 03, 2015 | HTC Cell Phones
Some one changed my password on my galaxy s5
Are you talking about the lock screen? Or your password for the Play Store?
If just the lock screen, please note that this will wipe the phone completely. If everything is backed up via your Google account, then photos and contacts should still be available. If you use an SD card then you should be safe.
Turn the Galaxy S5 off.
  • Now press and hold the Volume up button, the Home button, and the Power button together until you see the Android on screen.
  • Now use Volume down to highlight the wipe data/factory reset option and press the Power button to select it.
  • Use Volume down again to highlight Yes - delete all user data and press Power to select it.
  • Wait until you see the reboot system now option and then use the Power button to select it.
  • When the S5 restarts it should be completely wiped and ready to set up again.
  • Sep 18, 2014 | Cell Phones
    I forgot my password in my samsung GT-E2121B PASSWORD FOR PRIVACY LOCK
    You can factory reset the phone which will erase every app text contact and photo on the phone but if you have them saved on a a SD card just remove it before the rest. Depending on the phone you will hold either two or three buttons. With phone off: Volume up, the home button if applicable, and then the power button. You will know you did it right if you see small print text at the top of the screen and it will boot to the restore screen. Using the volume rocker buttons toggle to factory and outs the power button. It may give you a warning yes or no toggle to yes and then it will restore the phone to it's original factory settings.
    Jul 03, 2014 | Cell Phones
    Acer Iconia Tablet A500 won't boot past the Acer logo screen
    How do I perform a Factory Data Reset if my Acer ICONIA TAB A500 does not boot?
    The following steps will erase all of your personal information, all stored contacts and any programs you have installed on your tablet.
    1.Power off the tablet.
    2.Press and hold the Volume up button, which is located closest to the touch screen lock switch.
    3.With the Volume up button held, press and hold the Power button for 3 seconds then release it. Continue holding the Volume up button.
    4.Once the tablet vibrates, switch the touch screen lock switch on and off repeatedly while still holding the Volume up button.
    5.Release the Volume up button and stop switching the touch screen lock switch once the "Erasing Userdata..." message appears in the upper left corner of the screen.
    6.Once the factory reset has been completed your tablet will load to the Welcome screen. 7.Your Factory Data Reset has completed now follow the onscreen steps to setup your tablet.
    Mar 06, 2014 | Acer Iconia Tab A50010S32u Notebook
    I have a trio stealth g2 and have been locked out how do you rest to factory settings
    1. While the tablet is off, press the Volume Up and the Power buttons at the same time. Let go when the Android recovery screen appears
    2. Press the Power button to bring up the recovery menu.
    3. Using the Volume Down button, highlight "wipe data/factory reset"
    4. Press both volume buttons at the same to select the option.
    5. Scroll to and select "Yes - delete all user data"
    6. Once the wipe is completed, select "Reboot system now"
    Oct 25, 2013 | Tablets & eReaders
    Acer iconia a500 tablet freezes at the boot screen and does not go any further
    The following info from
    http://community.acer.com/t5/Tablets/Iconia-A500-frozen-at-Acer-logo-boot-screen/td-p/7171/page/28
    might be helpful:
    "How do I perform a Factory Data Reset if my Acer ICONIA TAB A500 does not boot?The following steps will erase all of your personal information, all stored contacts and any programs you have installed on your tablet.
    6.Once the factory reset has been completed your tablet will load to the Welcome screen. 7.Your Factory Data Reset has completed now follow the onscreen steps to setup your tablet."
    Good Luck!
    Oct 18, 2013 | Tablets & eReaders
    My acer iconia android tablet refuses to startup
    Perform a Factory Data Reset of Acer ICONIA
    The following steps will erase all of your personal information, all stored contacts and any programs you have installed on your tablet.1.Power off the tablet.
    Aug 24, 2013 | Acer ICONIA Tab W500PC52G03iss
    Unlock dot pattern lock android
    Normal way for Android is to power down and then hold the power button and the volume Up button.
    Way 2 is to hold power, vol up and vol down.
    You have to hold until the recovery console appears, so about 20 seconds.
    Only a few have a reset button inside a hole.
    However, yours is different to all the rest :>)
    Just completed this procedure and repeated to confirm: Klu by Curtis 7035-j
    1. Make sure tablet is off.
    2. Press and hold the "Volume Down" key and `Power` key
    3. When "Klu by Curtis" splash screen shows release the power key 4. A laying down android with cover open and a red triangle with an exclamation point will appear.
    5. Rock the `Volume Down` and `Volume Up` and press the `Power` keys to dislplay the BIOS screen.
    6. Use the `Volume Up/Down` keys to navigate choices (wipe data/factory reset) and the `Power` key to select the choice.
    7. The following screen will ask you to confirm your choice and warn you that this cannot be undone. Repeate step 6 to select your choice.
    8. When wiping all data is complete, select `reboot system now` to restart tablet. Done!
    Read more: How to perform a factory reset on a Curtis Klu LT7035-J tablet? - How to perform a factory reset on a curtis klu lt7035 j tablet :: Ask Me Fast at http://www.askmefast.com/How_to_perform_a_factory_reset_on_a_Curtis_Klu_LT7035J_tablet-qna6954204.html#q6015781
    Curtis Klu 7 inch Touch Screen Google Search
    Apr 23, 2017 | Curtis Klu 7-inch Touch Screen Mobile...
    How do i do a master reset?
    Performing a factory reset via settings The most convenient way to do a factory reset is via the phone settings.
    1. On the Home screen's Settings tab, tap Menu > All Settings > System > Clear Storage.
    2. Enter 1234.
    3. Tap YES to perform the reset, or tap NO to cancel the reset.
    Performing a factory reset using phone buttons If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using buttons on the phone.
    1. With your phone powered off, press and hold the VOLUME UP and VOLUME DOWN buttons.
    2. While holding the volume buttons, press the END/POWER button briefly and then release it.
    3. When you see a warning message on screen, release the VOLUME UP and VOLUME DOWN buttons.
    4. Press the VOLUME UP button to perform the reset, or press any other button to cancel the reset.
    Ref: http://www.htc.com/www/howto.aspx?p_id=297&id=182
    May 03, 2011 | HTC HD2 Smartphone
    Cell Phones Logo
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
