Question about Cycling
Im needing a wiring diagram for 212cc predator for electric starter
I have a gas bicycle that has 212cc predator engine. i recently bought 1. charging coil, 2.lighting coil,3. electric starter, 4.battery,5. chevy luv ignition switch. but dont know how to properly put them all together. will you help me out
  • 9 Answers
SOURCE: Bicycle Suspension
From Wikepedia:
Bicycle suspension can be implemented in a variety of ways:
            * Suspension front fork             * Suspension stem (although these have fallen out of favor)             * Suspension seatpost             * Rear suspension
Full information can be found here: http://en.wikipedia.org/wiki/Bicycle_suspension
Posted on Oct 29, 2008
SOURCE: Ignition switch
A kubota dealer should be able to print one for you or go on line with model # etc and you should be able to bring one up yourself. I hope this helps. donnyb60
Posted on Mar 19, 2009
  • 82 Answers
SOURCE: 49cc 2 stroke runs for 20 sec. then cuts out
20 seconds is all that is required to drain the float bowl. You have a float bowl/needle valve problem.
Posted on Apr 29, 2009
  • 6 Answers
SOURCE: 350 Chevy starter wiring diagram needed
IF YOU HAVE A POINTS TYPE DISTRIBUTER, THE WIRING WILL BE: TO ENERGIZE THE STARTER SOLENOID A LARGE, ABOUT A NUMBER 12 OR 14 GAUGE WIRE WILL GO TO THE INNER MOST SMALL TERMINAL ON THE STARTER SOLENOID. IT MAY BE PURPLE IN COLOR. THE SECOND SMALLER WIRE SHOULD GO TO THE OUTER SOLENOID TERMINAL AND GO FROM THERE TO THE + TERMINAL ON THE IGNITION COIL. THIS IS FOR BY PASSING THE RESISTOR WIRE FROM THE STARTER IGNITION SWITCH. THE LARGER BATTERY CABLE WILL GO TO THE UPPER TERMINAL ON THE STARTER SOLENOID. THERE MAY BE AN ADDITIONAL BATTERY FEED WIRE TAKE OFF FROM THE STARTER BATTERY TERMINAL POST ON THE SOLENOID FOR OTHER ACCESSORIES. THIS TYPE OF SYSTEM (POINTS TYPE) WAS TYPICALLY DONE AWAY WITH IN 1975 WHEN THE HEI DISTRIBUTOR CAME OUT.
Posted on May 05, 2009
  • 200 Answers
SOURCE: instruction manual to put bicycle together.
Too long and complicated to go over everything sooo....Google bicycle assembly and your answers are at your fingertips....good luck to you friend....Tim
Posted on May 12, 2009
98 Bonneville does nothing nothing when I attempt to start it, however the lights,radio and alarms all work. I charged the battery. No change.
Testing the electrical circuit's would need to be done to find the problem . Looking at a wiring diagram for the starter electrical circuit ,to see what all is involved in starting the vehicle. First off is the security light lit on the insturment cluster ? Check engine light ? Do you know what a automotive electrical diagram is ? Here is a web site for free wiring diagrams . http://www.bbbind.com/free_tsb.html Enter your vehicle info. Year , make , model etc.... Then click engine under system ,then charging system under subsystem . Click the search button , then the second blue link . This is the starting system wiring . Looking at the diagram you will see there is a bunch of stuff . IGN switch , starter enable relay , park neutral safety switch ,Pass-key 2 theft deterrent module , starter . Knowing how it all works an where to test is the key to fixing a no start problem . Knowing computer controlled system helps too .
Electric Testing Techniques You Need to Know
Sep 10, 2017 | Cars & Trucks
I bought used 79cc predator. Engine revs high.And no throttle how to adjust governor so it idles at normal idle.
Hi, Michael for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your problem. For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
Predator engine
AGK 99cc Predator Build Guide Affordable Go Karts
79cc Predator 4 stroke with maitc on 29 Macargi Fatal Love
Throttle Linkage for Harbor Freight Predator 79cc 99cc and 212cc motors...
Feb 28, 2016 | Motorcycles
04 Polaris predator, I bought used last week. I put a new battery and new carb on it. It doesn't have power, won't start, and no spark with kick starter. Dead. Fuses,wires, look good. Any ideas
Did it have compression before you bought it?
No power to the electric starter? Then you probably have no power to the ignition system. I'd check battery connections. Is the battery going flat overnight? Some shorts. Is there an ignition with a key? Is the switch good? or all the connections good? Corrosion does some funny things. Fuses may look good but actually are not.
Apr 02, 2015 | ATVs
Need wiring schematic for lund predator 1988
you cant get the whole elec diagram that would be 100 of pages what you can do is log on to auto zone (its free) go to vehicles and enter what you have, go to repair help, then to vehicle repair,and then to wiring diagrams ,when you ask us for help PLEASE give us 1)year-2)make-3)model-4)motor size
Sep 12, 2014 | Cars & Trucks
How to obtain fuel tank for a 212cc 6.5hp Pedator engine from harbor freight
im sure if you call them they can help, or take it to a bridgs and stration dealer and see if they have a match or can order one for you.
Sep 11, 2014 | Cars & Trucks
Nissan Altama Starter Relay electrical problems or a fuse?
Or the battery cables ! Do you know how to use a voltmeter ?
Starter Voltage Drop
Do you know how to do basic automotive electrical testing ?
How to voltage drop test starter motor circuit
Electric Testing Techniques You Need to Know Here is a place to view wiring diagrams ! http://www.bbbind.com/free_tsb.html
Apr 08, 2017 | 2004 Nissan Altima
I want to add 2 more 12v 20ah batteries to my 48w electric scooter and im not sure how to wire it and charge it.Please help
join them in parallel if there all 12 volt you could just charge the 1 battery with 12 volts and that would charge them all but all the other batterys have to be in series you cant do it if u have 2 24 volt batterys they all have to be 12 v
Dec 18, 2010 | Electric Bicycle Motor, Bike,electric...
The electric start wont work.the switch,relay,starter all good im not get current to the switch. im having a hard tracing the wire back with out taking it all apart.if i had a good wiring diagram i might...
that is the best part you can do to troubleshoot the issue, trace the cables, my bet is that there is a loose connection somewhere or a worn out harness
Dec 26, 2009 | 2006 kawasaki Z 750
Cycling Logo
210 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
