Question about Home
Sharp SPC060 Alarm clock. - does it have a backup battery and if it does, how do I change it?
4 Suggested Answers
SOURCE: Sharp Atomic Alarm Clock SPC325.
go to the al mode and the just tap the set button. If you hold the set button down it will try to set the alarm. so just tap it and it will change one timezone per tap.
Posted on Jul 05, 2008
SOURCE: Atomic alarm clock-sharp spc314
The manual says to hold the snooze button down for 3 seconds. Release as soon as the satellite image pops up on your display
Posted on Aug 04, 2012
  • 2044 Answers
SOURCE: We cannot change the time on the alarm clock we have tried mode buttons taken out the batteries still cannot change its a ascot alarm clock
Mine did the same thing but I had to Push the ALARM BUTTON to get it to work. I ended up throwing mine away....
Not worth the Aggrivation
Posted on Apr 08, 2013
Need instructions setting sharp alarm clock SPC293
hi cheryl.
this is all i could find,if this does not work go to the link and the bottom.
How to set time on sharp alarm clock? Change switch to BUZZER. 3.) Press and hold the ALARM button on top of the clock. 4.) Press HOUR button until desired hour is displayed.12 Feb 2013
Sharp Alarm Clock Inustructions by Matt Boysen on Prezi Search for: How to set time on sharp alarm clock?
instructions setting sharp alarm clock SPC293 Google Search
Nov 05, 2017 | Sharp Audio Players & Recorders
Why does my nelsonic nlc690 am/fm alarm clock radio display 18:88 and not allow me to set the time?
Sounds like it is broken!
Unplug it and remove the backup battery if it has one. Count to 10 and put the battery back in and plug back in.
If that doesn't work, just buy another one as they are cheap enough!
Nelsonic Led AM FM alarm clock radio NLC690 AWESOME CONDITION
Jan 13, 2016 | Audio Players & Recorders
How do I change the time on my sharp alarm clock?
alarm clock or microwave . not same thing
Mar 08, 2015 | Sharp Microwave Ovens
The three lights across the top stay **** and shows no time and can't do anything else
Try unplugging the alarm clock and removing the 9v backup battery. Let it sit for about 60 seconds. Reinstall the battery, plug in and reset the time.
Mar 30, 2014 | Sonic Alert SBB500SS Sonic Bomb Alarm...
How do you make it work with the 9 volt battery?
The 9-volt battery is a backup battery. It will keep the clock running and the alarm working when the power goes off so you won't be late for work.
Aug 26, 2011 | GE 7-4837 Clock Radio
I need instructions for my timex clock
Here are the instructions for your clock-radio.
1* Remove unit and all packing materials from the carton. You should save packing
materials in case unit needs to be returned for service. If you do not wish to save the
materials, please dispose of them properly.
2* Place the unit on a stable, level surface, close to an AC outlet, out of direct sunlight,
and away from sources of dust, dirt, heat, water, moisture, vibration, or magnetic fields.
3* After installing the batteries (see below) and reading the Maintenance notes, plug the
AC cord into an outlet.
"Sure Alarm" Battery Backup Installation
It is strongly recommended that 2 "AA" batteries be installed into the unit, as directed below,
in order to activate this product's "Sure Alarm" Battery Backup feature. (The model should
come with two batteries already installed.) In the event that the AC power cord is disconnected
or a power failure or other interruption occurs, the "Sure Alarm" Battery Backup will maintain
clock and alarm settings for the life of the battery, ensuring that the alarm (buzzer only) will
sound at the set time. During any interruptions the time and alarm settings will be saved
and automatically restored when AC power is again active.
1* Gently turn the unit over and remove the battery
compartment door.
2. Install 2 "AA" batteries (alkaline is recommended for
longer life), while making sure that the + and - ends
match up with those inside the battery compartment.
3* Slide the battery compartment door back on, making
sure the door locks into place, and gently return the
unit to its upright position.
Aug 19, 2011 | Timex Auto-Set Dual Alarm Digital Clock...
Which the voltage of the transformer to be replaced
Your clock has a backup battery. Battery is for time backup only.
The clock and alarm memory will
be retained during a power
interruption. During battery
backup operation, the display
will not light up, but the correct
time will be maintained internally
The mains transformer inside it will be of 10.2vAC secondary to 120VAC primary. OK.
May 13, 2011 | GPX CRCD2806 Clock Radio
Unable to set the alarm
To Set the alarm time: Press and hold the ALARM button down, and then press the hour/minute buttons to obtain desired time (Note the PM indicator on the screen for PM times)
To Enable the alarm: Move the sliding switch to AUTO or ALARM (Auto is for radio wake and Alarm is for beeping noise) *remember to turn up the volume knob if using AUTO (radio) setting.
Dec 04, 2008 | Lenoxx Electronics Clock Radio With CD...
Insignia clock radio goes to 12:00 after turning off power
I found this solution by reading some reviews. A reviewer said it was caused by a weak backup battery that powers the display. He said to change the lithium backup battery of the main unit with the backup battery in the remote. I tried it and now it works. I can turn the unit on and off and it doesn't reset my memory. But this hasn't solved my problem with setting the alarm.
Nov 23, 2008 | Insignia Digital Clock Radio with Apple...
Instructions for setting Sharp Atomic clock
Remove backup battaries
and re insert new/or-goodbattaries in the battarey comportmane as correct +/- sign.
show the time if its start from 12:00AM
press startbutton -get time adjust mode -select correct Time and press set to mnormal mode.
Nov 03, 2008 | SkyScan 86709 Atomic Wall Clock
Home Logo
55 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
