Question about Samsung Televison & Video
Just received SUHD TV 8 series for Christmas. went to set it up and it's missing the 2 legs /stand so now I can't even set it up to watch. what do I do so I can at least set it up to watch o
Missing stand legs on Samsung SUHD TV 8 series if I can't use it I will need to return to Best Buy for refund
    Master:
  • Samsung Master
  • 708 Answers
Supported Audio: LPCM,Dolby-AC3, DTS7.1, DSD/Dolby TrueHD/DTS-HD master audio,Essentially all available audio options are supported Amazon com MALLCROWN 4 Port 1080p HDMI Splitter with Ac Power adapter...
Posted on Dec 28, 2016
    Novelist:
  • Samsung Expert
  • 231 Answers
Do you have anything you can use in place of the legs? Even a few books, bricks you can use in place to level it?
Posted on Dec 25, 2016
Why does my reciever keep turning off by itself?
try looking into the Timer section on the TV. also on Dish if it is left unattended (like stay on same channel etc) it will go in to sleep mode, U then just hit the Select button.. U can go in the Dish menu and set the Sleep mode (inactivate mode ) to a longer time, I usually set my for 8 hours.
Jul 09, 2014 | DISH Network DVR-625 DTV Receiver /...
I need instructions to put Wilton's 3 tier party stand together
According to Wilton:
You should have 8" plate, 10" plate and 12" plate
Match the sizes with rings and legs on table.
Attach legs to serving rings,twist threaded end securely into housing on each serving ring. Tighten using wrench.
Attach 8 1/4 Serving ring to Center Footed Base Ring -Position serving ring with footed leg out. Line up the other 2 legs with the correct housing on the base ring, the width between housing should be same as that between legs.. Insert end of legs into housing.
Next attach 10 1/4 Serving ring to Base Ring, You will need to move clockwise around base ring to attach this ring. line up legs and insert legs and tighten.
Attach 12 1/4 serving ring to base ring. Insert legs into last pair of housing on the base ring.
Position plates so lip edge rests inside serving ring.
Apr 16, 2013 | Wilton WHITE 3-TIER CUPCAKE STAND...
Missing part
I thought the same with mine but the little square part you looking for is in a piece of the styrofoam
Dec 29, 2012 | Polaroid 22 Class 720p 60hz LCD HDTV/DVD...
NO PICTURE TV TURNS ON
Lets try something ,turn the set on and put you forearm in the face of the picture tube if your hair stand to static it means you have high voltage and your set is missing possible the screen or filaments volts,if the hair in your arm does not stand your set is missing the high voltage and the problem is related to the flyback but it does not mean is bad ,it could have a loose conection in one of the legs or in the near area,next time it happens tap on the side of the set to see if it reacts if it does you know you have a loose conection.If you are familiar with tv service this will be a good place to start but if you are not too familiar be safe and call for assistance from a servicer.Let Us know if you need more information and how it goes.
Nov 28, 2012 | RCA 36V430T 36" TV
Can you record a program and watch live TV at the same time?
If you have a dual receiver, you can record to TV 2 and watch any program on TV 1. If you have 2 recordings taking place at the same time, you can only watch what is being recorded.
With a dual receiver, you can place the receiver in single mode and watch a different program even if 2 recording are taking place. In single mode both TV 1 and TV 2 will be watching the same program.
A solo DVR you can record to tuner 2 and watch what you want on TV 1. With the VIP 622 receiver, you have the Record Plus option, you can have all recording go to TV 2. If 2 recordings take place, then TV 1 and TV 2 are used.
Jun 29, 2011 | DISH Network ViP622 DVR DTV Receiver /...
How do you remove base from tv
if its like my p50dhm just remove 6-8(each leg) screws on back located at legs of stand pretty obvious....stand will try to hang-up plus must come off equal on each side or will bind
Feb 07, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
One fuse keeps blowing
what size fuse is it usually you use at least a 40
Feb 09, 2008 | Sony XM-2252HX Car Audio Amplifier
TV powers on but NO screen pops on.
1 check remote control. 2 tv comes to stand by to protect itself 3 there might be problem in power supply section 4 & if it is ok check horizontal section. 5 call skilled tech to fix it. 6 it is not a major problem.
Sep 26, 2007 | Sony FD Trinitron KD-36XS955 36" TV
Televison & Video Logo
Henry  Thomas
Henry Thomas
