Question about LG 47 Inch LED TV 47LN5200 LN5200 Series HDTV
LG LED LN5200 3 LED strips flash 3 do not. I do have sound and can see screen with flashlight and red power LED flashes 3 times.
I have my 47" LG LN5200 tore down, when powering up 3 LED strips flash with all LED's working and 3 strips do nothing. Is this possible the capacitor's for half of the LED's have failed? Note I do have sound, can see picture with flashlight and the red power light flashes 3 times. I am hopeful it is the capacitors instead of the LED's as that would be an easy cheap fix. I did do a voltage test on the capacitors with an analog tester and got a voltage spike when the working LED's Flash. One pair of capacitors spike the other pair had nothing. Thanks in advance for any help.
    Top Expert:
  • LG Master
  • 73,611 Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Posted on Dec 26, 2016
Testimonial: "Thanks so much for your input. I have watched various videos about this issue but have never seen an instant on video where half the lights work and half do not. I think I will go board shopping and then if issues are not resolved replace LED strips. Everything seems to point to a portion of the board though."
What's wrong with my LG 55LV9500 LED TV? Power on, black screen.
Hello, either the power supply is failing to power up the LED's or the LED strips in the screen have failed, a common issue with these sets. Power supply part # is EAY62169701. LED strips are only available as a complete screen assembly from LG....thanks
Apr 23, 2017 | LG Televison & Video
My LG 47LA6200-UA just went out. Turning on it flashes and goes black. Red light flashes 3 times. Flashlight shows picture, audio works. Is this the LED strips or something else? Thanks for any help!
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Dec 25, 2016 | LG 47LA6200
Have a LG 47 inch tv. 47ln5750. When I power on the LG appears on screen then shuts off. took off the back cover and when I powered on I could see the LEDs flash. problem be led board? Or Led strips?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 27, 2016 | LG 47LN5750 47" LED TV 1920x1080, 120 Hz,...
Can you tell if LED tv has bad LED strips before changing LED Board/Power Supply (as they're in one piece on a lot of TVs)?
This is not easy to diagnose, either use a meter on the power cable to the led or check the leds one at a time
Feb 24, 2016 | LG 47LN5400 47" LED TV 1920x1080, 120 Hz....
I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. Still have sound & can see a picture with a flashlight shining on the screen.
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Oct 19, 2015 | LG 47LN5750 47" LED TV 1920x1080, 120 Hz,...
LG 47LN5750 TV has no back light issue-
replace screen it's faulty period ensure it comes with T-con
Oct 03, 2015 | LG 47LN5750 47" LED TV 1920x1080, 120 Hz,...
LG 50ln5200-ub led TV . Has no picture but great sound . What is the problem ? I did the flashlight test and can see the faint picture which tells me the backlighting is out . This tv model is a Black...
usually bad power supply, Where did you source your part? return/exchange it. Bad LEDs/ possible but not as likely, Tcon working if you can see images with flashlight. You must also have backlight on signal from main board ,check for 3 to 5v on labeled connecter on power supply. UPDATE---47" & 50" LN series. This model has had LED problems if your TV acts as described by Mr. Hughes in is answer to this problem you have bad LEDs
Feb 16, 2015 | LG 50 Inch LED TV 50LN5200 LN5200 Series...
No picture on mu LG television.
Try the old flashlight test, turn off the lights in the room. Turn on the set and flash a bright flashlight on the screen. Do you see the image or is the screen totally black?? If you see the image, then most likely you have a backlight problem. Verify that you have 24V on the power supply for the inverter
May 20, 2012 | LG 19LH2000 19 in. TV
LG 47 Inch LED TV 47LN5200 LN5200 Series HDTV Logo
Computer Repairing
Computer Repairing
